查看: 3370|回复: 5
有偿请帮助安装下HSPICE仿真软件
发表于 2022-10-5 11:41:22 | 显示全部楼层 |阅读模式
悬赏50资产未解决
本人新手,已经下载有HSPICE 相关的软件,hspice_vS-2021.09_win,scl_v2021.03_windows,
wv_vS-2021.09_win,Synopsys Hspice 2021 Patcher,scl_keygen,安装在window端,软件安装没有问题,主要在破解过程,试过好几次都没有成功,
哪位大佬请帮忙安装下,有偿(人民币),微信:15901736799.谢谢。
按照网上教程,当前在运行IMTOOOL的时候,出现如下log错误:
11:05:29 (snpslmd) Invalid license key (inconsistent authentication code)
11:05:29 (snpslmd)         ==>INCREMENT FSPRO2XSIM snpslmd 2030.12 30-dec-2030 99 \
        VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 \
        ck=232 SN=RK:2671-0:167603:0 START=01-apr-2004 AUTH={ \
        snpslmd=( LK=9F953283B41F0C192879 SIGN="0000 1111 2222 3333 \
        4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF \
        0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB \
        CCCC DDDD") }
11:05:29 (snpslmd) License server system started on LAPTOP-N4OF9DM6
11:05:29 (snpslmd) No features to serve, exiting
11:05:29 (snpslmd) EXITING DUE TO SIGNAL 27 Exit reason 4
11:05:31 (lmgrd) snpslmd exited with status 27 (No features to serve)
11:05:31 (lmgrd) snpslmd daemon found no features.  Please correct
11:05:31 (lmgrd) license file and re-start daemons.
11:05:31 (lmgrd)
11:05:31 (lmgrd) This may be due to the fact that you are using
11:05:31 (lmgrd) a different license file from the one you expect.
11:05:31 (lmgrd) Check to make sure that:
11:05:31 (lmgrd) C:\synopsys\Hspice_S-2021.09\synopsys_lic.dat
11:05:31 (lmgrd) is the license file you want to use.
11:05:31 (lmgrd)
 楼主| 发表于 2022-10-6 08:43:46 | 显示全部楼层
已解决。
发表于 2022-10-6 09:58:25 | 显示全部楼层
顶一下
发表于 2022-10-17 17:16:20 | 显示全部楼层
大佬怎么解决的,能分享一下不
发表于 2023-2-13 13:49:48 | 显示全部楼层
同求
发表于 2024-5-17 00:43:26 | 显示全部楼层
可以教一下嗎
感謝
GMT+8, 2025-12-4 06:53 , Processed in 0.128573 second(s), 5 queries , Gzip On, Redis On.
