查看: 1528|回复: 0
[原创] 100V Input,5A Output, Synchronous Step-down Controller
发表于 2022-8-26 13:58:39 | 显示全部楼层 |阅读模式
Features
l 9V to 100V input voltage range
l 5A continuous output current
l 96% Peak Efficiency
l 600µA operating quiescent current
l Peak Current mode control
l 150 kHz Fixed Frequency
l Internal compensation for ease of use
l Up to 91% duty cycle
l 0.8V voltage reference
l 10µA shutdown current
l 150ms Hiccup mode short circuit protection Function
l Thermal shutdown Function
l QFN-20 package
Applications
l Charger in vehicle
l Battery Chargers
l Power adapter
Description
The MST8A50QN is a high voltage, synchronous step-down controller operates over a wide range input voltage 9V to 100V.
The MST8A50QN delivers 5A continuous load current with up to 96% efficiency.
The MST8A50QN operates with fixed frequency peak current control with built-in compensation eliminates the need for external components.
Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition. Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time.
The MST8A50QN exhibits protection features
that protect the load from faults like under-
voltage,over-current and over-temperature.
The MST8A50QN is available in an QFN-20.
Device Information
PART NUMBER
PACKAGE
BODY SIZE (NOM)
MST8A50QN
QFN-20
5mm*5mm
GMT+8, 2025-9-19 04:17 , Processed in 0.011098 second(s), 3 queries , Gzip On, Redis On.
