查看: 3855|回复: 2
Remcom Wireless Insite 3.3.5 (2022 Version) with License and Tutorial Examples
发表于 2022-7-26 18:45:36 | 显示全部楼层 |阅读模式
REMCOM WIRELESS INSITE 3.3.5 (2022 VERSION)
Wireless InSite® is a suite of ray-tracing models and high-fidelity EM solvers for the analysis of site-specific radio wave propagation and wireless communication systems. The RF propagation software provides efficient and accurate predictions of EM propagation and communication channel characteristics in complex urban, indoor, rural and mixed path environments.
Applications
Wireless InSite provides RF engineers with the tools to design wireless links, optimize antenna coverage, and assess key channel and signal characteristics for RF and millimeter wave frequency bands.
Features
Wireless InSite's unique collection of features simplifies the analysis of even the most complex and massive propagation problems.
X3D Propagation Model X3D is a 3D propagation model with no restrictions on geometry shape or transmitter/receiver height. This accurate model includes reflections, transmissions and diffractions along with atmospheric absorption. Supports frequencies up to 100 GHz.
Diffuse Scattering Capture effects of scattering on complex impulse response and received power (including cross-polarization) for mmWave applications.
MIMO Beamforming & Spatial Multiplexing The X3D model simulates MIMO antennas for 5G, WiFi and other technologies. Using detailed multipath, it applies MIMO techniques such as beamforming, spatial multiplexing, and diversity to predict key channel metrics for one or more MIMO data streams.
Communication Systems Analysis The Communication Systems Analyzer calculates SINR, throughput, theoretical capacity, and bit error rate (BER), giving users the tools they need to visualize and assess device performance for systems with multiple base stations.
Fast Ray-Based Methods 2D site-specific propagation models designed for urban and rough terrain applications.
Empirical Propagation Models Suite of empirical models designed for urban and indoor analysis.
Feature Import Support for KMZ, COLLADA, SHP, and DXF formats for building and object import. The Geospatial Abstraction Library is used for terrain import in DTED, DEM, and TIFF formats.
Antenna Modeling  Import simulated antennas fromXFdtd or create textbook antennas for use in SISO, MIMO and Massive MIMO transmitter and receivers.
Materials Electrical properties of the scene can be defined down to the facet level. An installed database of materials includes metal, earth, concrete, brick, wood, glass, etc. at various frequencies.
Outputs Users have quick access to outputs such as received power, propagation paths, path loss etc. These ASCII-based files can be plotted in the tool or easily post-processed externally.
Geometry Caching Wireless InSite's X3D Propagation Model automatically caches processed geometry for later use. This avoids geometry processing time when multiple concurrent or subsequent jobs are run with the same geometry. Wireless InSite monitors cache validity and indicates when the cache is available. This feature is especially useful for scenarios with large urban or rural geometry when multiple concurrent or sequential jobs are being run.
Some Application Examples
·        Throughput of a 5G New Radio FD-MIMO System in an Urban Area Using Custom Beamforming
·        WiFi Performance Simulation in a House with Two Routers
·        5G mmWave Channel Modeling with Diffuse Scattering in an Office Environment
·        5G Massive MIMO Outdoor Communications Analysis
·        Modeling an Ad Hoc Network with Transceivers in an Urban Setting
If you are interested in the full licensed software   REMCOM WIRELESS INSITE 3.3.5 (2022 VERSION) with full feature license and examples, then do well to contact    fast.forever24@gmail.com
发表于 2024-5-20 14:21:59 | 显示全部楼层
发表于 2024-5-20 20:32:19 | 显示全部楼层
thanks
GMT+8, 2025-12-29 01:46 , Processed in 0.019070 second(s), 6 queries , Gzip On, Redis On.
