查看: 3556|回复: 5
[原创] ESD 的HBM,MM,CDM考虑
发表于 2021-11-19 16:00:50 | 显示全部楼层 |阅读模式
ESD设计过程中,怎么只考虑HBM,MM ,  CDM都不怎么考虑,这是为啥呢?MM的峰值电流不是更大,破坏力更大吗?
 楼主| 发表于 2021-11-19 16:01:44 | 显示全部楼层
另外,CDM的泄电通路都如何加?
发表于 2021-11-19 16:52:08 | 显示全部楼层
ESD  的HBM,MM,CDM考虑
https://bbs.eetop.cn/thread-917070-1-1.html
(出处: EETOP 创芯网论坛 (原名:电子顶级开发网))
回复 支持 0 反对 3
发表于 2021-12-15 09:11:07 | 显示全部楼层
wuzhuoqing 发表于 2021-11-19 16:52
ESD  的HBM,MM,CDM考虑
(出处: EETOP 创芯网论坛 (原名: ...
发表于 2021-12-15 09:41:14 | 显示全部楼层
楼主的说法与现实还是有出入的。IC的ESD保护设计要求(及趋势)是包括HBM与CDM,而CDM的考虑占比会越来越高,不再考虑MM的设计,更多的还是基于IC在使用阶段(IC封装与测试、SMT、电子产品整机组装等)ESD的主要情形:MM中的设备带静电的金属物体只要接地,就消除了,而且在电子工厂的设备设计与使用维护都会有效应对;依此类推,HBM的设计要求也会逐渐弱化;相比之下,CDM在IC使用阶段(IC封装与测试、SMT、电子产品整机组装等)的占比越来越高(现今基本超过50%),所以,IC的CDM保护设计要求会越发强化。
以下是JEDEC发布(2014年)取消MM作为IC ESD保护设计要求的背景原因:
• MM is redundant to HBM at the device level since it produces the same failure mechanisms, and the two models generally track each other in robustness and in failure modes produced.
• The MM test has more variability and, consequently, less repeatability than HBM due to the MM's greater sensitivity to parasitic effects in the tester circuitry.
• There are no significant engineering studies (with verified data) which could be used to establish a required passing level for MM.
• The test method was incorrectly given the name “machine model”, though no firm, unique connection between the model and actual machine-induced device failures was ever established.
In fact the model was developed as a “low-voltage HBM”.
• CDM does a better job of screening for fast metal-to-metal contact events than MM.
• The vast majority (> 99%) of electrical failures in manufacturing correlate to CDM or to EOS and not to MM.
• MM testing has not shown any additional failures not explained by CDM, HBM or EOS.
• MM testing consumes resources and creates time-to-market delays while providing no additional failure modes or protection strategies which have not been covered by HBM and CDM.
回复 支持 3 反对 0
发表于 2025-3-31 17:29:33 | 显示全部楼层
感谢分享
GMT+8, 2025-9-18 05:22 , Processed in 0.015467 second(s), 5 queries , Gzip On, Redis On.
