楼主: liudin
5ynopsy5 pr!mes!m 2021
发表于 2021-10-4 12:11:19 | 显示全部楼层
joshjosh 发表于 2021-9-25 00:24
用了 OCAD 大大的 1patch V0.3 , 還有內附的 lic gen 配合 18版的 SCL 就行了!!
真是太棒了.
您好,能告知一下如何添加feature吗,非常感谢!!
发表于 2021-10-4 15:47:31 | 显示全部楼层
OCAD 大大的 1patch V0.3 , 內附的 lic gen 運行後就會自帶出一個 synopsys.sr修改這個 synopsys.src 即可. 只要複製 INCREMENT xxxx .. , 把xxxx 改成 想加入的 feature 即可
for example ,
INCREMENT primesim_lic   snpslmd 2030.12 30-dec-2030 99 VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=51 SN=RK:2671-0:167603:0   START=01-apr-2004  AUTH={ snpslmd=(LK=0) }
INCREMENT primesimspice_lic   snpslmd 2030.12 30-dec-2030 99 VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=51 SN=RK:2671-0:167603:0   START=01-apr-2004  AUTH={ snpslmd=(LK=0) }
发表于 2021-10-4 16:04:58 | 显示全部楼层
改 synopsys.src ,
copy 前面的 INCREMENT xxxx .... 把xxxx改成要的feature 即可
INCREMENT primesim_lic   ......
发表于 2021-10-5 10:39:33 | 显示全部楼层
license 总出错,不知哪个环节出了问题?
33:48 (snpslmd) EXITING DUE TO SIGNAL 41 Exit reason 9
9:33:48 (lmgrd) snpslmd exited with status 41 (Exited because another server was running)
9:33:48 (lmgrd) MULTIPLE "snpslmd" license server systems running.
9:33:48 (lmgrd) Please kill, and run lmreread
9:33:48 (lmgrd)
9:33:48 (lmgrd) This error probably results from either:
9:33:48 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
9:33:48 (lmgrd)   2. A prior license server manager (lmgrd) was killed with "kill -9"
9:33:48 (lmgrd)       (which would leave the vendor daemon running).
9:33:48 (lmgrd) To correct this, do a "ps -ax | grep snpslmd"
9:33:48 (lmgrd)   (or equivalent "ps" command)
9:33:48 (lmgrd) and kill the "snpslmd" process.
发表于 2021-10-6 04:06:34 | 显示全部楼层
OK>Thnx a lot!!!!!
发表于 2021-10-29 23:59:57 | 显示全部楼层
感谢分享
发表于 2021-10-30 00:14:44 | 显示全部楼层
感谢分享
发表于 2021-10-30 11:55:57 | 显示全部楼层
Would you please share the Window's version?
发表于 2021-11-14 21:39:00 | 显示全部楼层
不知道是 primesim bug , 還是破解的 patch 有些問題.
用  primesim -auto , 不能像 finesim 那樣自動找出最佳的  thread 設定.
我比過一個仿真 , finesim 6core 花 1.38hr , primesim 6 core 要 1.5hr , 8core 要兩小時 , 10 core 要6 小時..
越多 core 越慢 ...
像  .option posttop=1 postlvl=1 這類的 option 也沒有作用 .....  不知道大家用起來有沒有類似的問題.
发表于 2021-11-25 16:16:37 | 显示全部楼层
update 一下結果.   primesim -auto -np 10  ,   這個如果用大寫  -NP 10 就不 work. 小寫才行.
但是 .option posttop=1 這些不管大小寫還是不 work.
GMT+8, 2025-12-25 19:20 , Processed in 0.019240 second(s), 3 queries , Gzip On, Redis On.
