查看: 2818|回复: 2
标准单元库怎么导入到cadence里
发表于 2021-6-10 22:31:37 | 显示全部楼层 |阅读模式
IMG20210610222429.jpg 这是pdk里提供的标准数字库,又这么多文件,我怎么样导入到cadence里,可以得到这些模块的完整的包含layout,schematic和symbol的library阿。 万分感谢
发表于 2021-6-12 03:23:15 | 显示全部楼层
This collection is Digital Stdcel Library.
PDK is another set of data, that you need alongside of these data.
These data are mostly used with digital design tools like genus / innovus from cadence, NOT the analog IC/Virtuoso package.
With analog IC/Virtuoso package, you can import the gds file from streamin menu. And spice cdl netlist of ells from spice-in menu.
发表于 2025-2-23 23:37:59 来自手机 | 显示全部楼层
同样遇到了问题,相同工艺库,请问楼主可以给这个问题解答了吗
GMT+8, 2025-10-5 15:27 , Processed in 0.017472 second(s), 4 queries , Gzip On, Redis On.
