在打开schematic/layout/adexl时,CIW窗口都会报以下警告:
Loading le.cxt
GLOBALFOUNDRIES INFO: Loading libInit.il for chrt018ull_hv30v
GLOBALFOUNDRIES INFO: Loading Display Resources File '/opt/pdk/ULL_ISO_1P6M_1K_1p5fF_A_9K/chrt018ull_hv30v/../config/display.drf'
Loading chrt018ull_hv30v/loadCxt.ile ... done!
Loading context 'chrt018ull_hv30v' from library 'chrt018ull_hv30v' ... done!
Loading context 'pdkUtils' from library 'chrt018ull_hv30v' ... done!
Loading chrt018ull_hv30v/libInitCktPro.il ... done!
GLOBALFOUNDRIES INFO: Loading Utils.ils...
function Round redefined
GLOBALFOUNDRIES INFO: Loading LibUtils.ils...
*WARNING* defmethod: invalid template string ("gtl") for the method 'SetLayerMap'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetLayerMapTable'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gtt") for the method 'FilterRuleFile'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetRuleTable'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetMapTable'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gtgg") for the method 'GetDR'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetMetalStack'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gst") for the method 'GetLayerData'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gl") for the method 'GetGDS'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetLPP'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gl") for the method 'GetLPAttr'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetDeviceList'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetDeviceOptionData'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'SetBEOL'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
*WARNING* defmethod: invalid template string ("gt") for the method 'GetDevice'. When present, the method template for required arguments must consist only of "g" data type characters; for example, 'defmethod foo ((a number) b "gg") (list a b))'.
GLOBALFOUNDRIES INFO: Loading Library.ils...
GLOBALFOUNDRIES INFO: Loading Device.ils...
GLOBALFOUNDRIES INFO: Loading TechFile.ils...
GLOBALFOUNDRIES INFO: Loading CapProp.ils...
GLOBALFOUNDRIES INFO: Loading ResProp.ils...
GLOBALFOUNDRIES INFO: Loading MinMax.ils...
GLOBALFOUNDRIES INFO: Loading AbsGenStreamMap.ils...
GLOBALFOUNDRIES INFO: Loading Rules1.ils...
GLOBALFOUNDRIES INFO: Loading Rules2.ils...
GLOBALFOUNDRIES INFO: Loading Rules3.ils...
GLOBALFOUNDRIES INFO: Loading DM290_Layers.ils...
Loading oasis.cxt
GLOBALFOUNDRIES INFO: Loading 018ULL_30V_ISO_modelFile.cfg
Loading analog.cxt
Loading asimenv.cxt
Loading spectrei.cxt
Loading devCheck.cxt
Loading relXpert.cxt
Loading hspiceD.cxt
Loading spectreinl.cxt
Loading msgHandler.cxt
Loading UltraSim.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
Loading esd.cxt
*WARNING* envSetVal: Can't set the value of variable 'pinTextSamePurpose',
in tool[.partition] 'layoutXL' - it has not been registered.
Loading drdEdit.cxt
Loading leToolbox.cxt
Loading treeAssistant.cxt
Loading soi.cxt
Loading lo.cxt
Loading mpt.cxt
Loading vb.cxt
Loading see.cxt
Loading oi.cxt
Loading asst.cxt
Loading mtv.cxt
Loading lce.cxt
查看<cds_install_dir>/etc/tools/layout/.cdsenv等,没有看到'pinTextSamePurpose'这个变量;在.cdsinit中也没有找到加载.cdsenv的语句。
请问有大神遇到过此类问题吗?
