查看: 2507|回复: 3
help about IC5141
发表于 2020-12-3 21:49:21 | 显示全部楼层 |阅读模式
I have reinstalled redhat 7.9 and IC5141, but i got some warnings when i lunch icfb.
Warning: translation table syntax error: Missing '(' while parsing action sequence
Warning: ... found while parsing '<Key>KP_Next: ActionGrab(SWDownPage)<Key>Next: ActionGrab(SWDownPage)'
Warning: String to TranslationTable conversion encountered errors
how to solve this problem? It is work well before i reinstalled redhat.
thanks a lot!
 楼主| 发表于 2020-12-4 13:34:50 | 显示全部楼层
有没有大佬帮帮忙啊?尝试虚拟机安装,没有问题。相同的系统617和618没问题。网上查说是XKeysymDB问题,但是redhat7已经没这个文件了,真是键盘问题?准备找个XKeysymDB文件放进去试试...但是感觉不对啊,之前也是相同的系统,就是电脑啥的是新装的。键盘也是新的。
发表于 2020-12-4 15:57:23 | 显示全部楼层
You can ignore all this warnings. This is known X problem.
 楼主| 发表于 2020-12-4 16:12:33 | 显示全部楼层
收到,谢谢!
GMT+8, 2025-12-21 15:23 , Processed in 0.014277 second(s), 4 queries , Gzip On, Redis On.
