查看: 3136|回复: 2
[Help] how to set finesim_mode for instance R*,L*,C*
发表于 2020-11-26 16:23:15 | 显示全部楼层 |阅读模式
Dear all,
I am newer to use finesim.
I got a problem to set finesim_mode for instances which begin with "R*" , "L*" and "C".
tried the following option.
.option finesim_mode="r*:spicead":instance
tool reported :
ERROR! unable to find instance 'r*'
Has anyone a solution ?
BTW. the following setting is no problem for custosim.
set_sim_level -level 7 -inst R*
set_sim_level -level 7 -inst L*
set_sim_level -level 7 -inst C*
发表于 2020-11-26 17:25:24 | 显示全部楼层
RLC已经是最基本的器件了,不能单独设定仿真模式,仿真模式是针对电路的,不是针对器件的。
 楼主| 发表于 2020-11-27 10:23:14 | 显示全部楼层
第二信使 发表于 2020-11-26 17:25
RLC已经是最基本的器件了,不能单独设定仿真模式,仿真模式是针对电路的,不是针对器件的。 ...
Thanks for your answer.
GMT+8, 2025-11-26 02:29 , Processed in 0.016391 second(s), 3 queries , Gzip On, Redis On.
