查看: 5790|回复: 4
IMST EMPIRE XPU 8.01 (Latest 2020 Version) with Full License
发表于 2020-9-19 07:39:38 | 显示全部楼层 |阅读模式
EMPIRE XPU is a 3D time domain EM modeling toolfor Antennas, Microwave Circuits, EM Chip design and much more. The IMSTinnovative & proprietary XPU technology is a smart implementation of theFinite Difference Time Domain (FDTD) algorithm on modern CPU architectures. Itcan drastically reduce simulation times while (in contrast to GPU solutions)maintaining full access to the available main memory. Hardware costs can bedrastically reduced as no expensive GPUs are needed.
  • Extremely fast and highly memory efficient solver using IMST proprietary XPU technology
  • Highest performance at all scales with full main memory support (more then 2TB on modern workstations)
  • Just-in-time code generation and caching reduce required memory by 50%
  • Interoperability with all common 3D CAD data, layout formats and vendor simulation projects
  • Intuitive 3D Design Editor with fully integrated multi-layer designer
If you are interested in the full licensed software  IMST EMPIRE XPU 8.01  then do well to contact   fast.forever24@gmail.com
发表于 2020-9-19 12:56:56 | 显示全部楼层
can you share it by Baidu netdisk ?   I will give you a praise
发表于 2021-6-4 22:28:41 | 显示全部楼层
Share medicine
发表于 2022-6-9 17:15:30 | 显示全部楼层
Can you please share?
发表于 2025-1-12 23:48:35 | 显示全部楼层
I would  be very grateful if you can provide me a download website. Thax
GMT+8, 2025-12-26 14:48 , Processed in 0.027195 second(s), 6 queries , Gzip On, Redis On.
