查看: 5168|回复: 10
Sonnet Suite Professional 17.56 (Latest 2020 Version) with License for Windows and Linux
发表于 2020-9-19 07:21:40 | 显示全部楼层 |阅读模式
SONNET SUITE PROFESSIONAL 17.56 for Windows and Linux
Sonnet Suite is one of the most powerful EM (electromagnetic) software for modeling and designing antennas and high frequency circuits such as microstrip, stripline, coplanar waveguide, vertical metal sheets (z-directed strips) and frequency analysis of printed circuit fibers. Single layer and multilayer related to high frequency circuits and internal circuit design of integrated circuits (IC and Chip Design) are used.
Sonnet's suites have developed RF modeling for the design and analysis of surface circuits and antennas (S-, Y-, Z-parameters or extracted SPICE model). To work with this software, engineers only need a physical description of their circuit. Enter the software, the physical description includes the introduction of the desired layers and the specifications of the components and insulations used in the circuit.
Sonnet's suites software has different applications in the electronics and telecommunications group, you can see some of the applications below:
• Arbitrary microstrip & stripline circuits
• Planar spiral inductors
• RFIC & MMIC circuits
• Planar filter analysis
• High Speed ​​​​​​Digital Interconnects
• High density interconnects
• Multi-layer circuits like LTCC and PCB technology
• Microwave circuit discontinuities
• Planar (patch) antennas
• Circuits with vias, vertical metal sheets (z-directed strips), and any number of layers of metal traces embedded in stratified dielectric material
If you are interested in the full license for Sonnet Suite Pro 17.56 (the latest 2020 version) then do well to contact me at fast.forever24@gmail.com
发表于 2020-9-19 12:57:43 | 显示全部楼层
can you share it by baidu netdisk? I will give you a praise.
发表于 2020-9-19 18:51:41 | 显示全部楼层
卖软件的不要在这里发信息了吧。鄙视你
发表于 2020-9-19 22:57:56 | 显示全部楼层
禁止卖软件。
发表于 2020-9-20 08:43:36 | 显示全部楼层
发表于 2020-9-23 12:52:10 | 显示全部楼层
where is it!
发表于 2020-9-24 12:28:42 | 显示全部楼层
thanks
发表于 2021-1-4 11:47:12 | 显示全部楼层
空欢喜
发表于 2021-4-30 13:07:58 | 显示全部楼层
SONNET17.52,我有,需要加我R0060006
发表于 2021-10-6 08:53:54 | 显示全部楼层
thanks
GMT+8, 2025-11-5 08:05 , Processed in 0.023112 second(s), 6 queries , Gzip On, Redis On.
