查看: 3108|回复: 3
SPECTRE读入VHDL-A报错
发表于 2020-8-29 10:16:01 | 显示全部楼层 |阅读模式
ERROR (VACOMP-2353): "/usr/cads/cds/IC618/tools/dfII/samples/artist/ahdlLib/and_gate/veriloga/veriloga.va", near line 79: GCC version mismatch found. The GCC installation is either corrupted or has been modified. To solve the issue, either use the GCC version that came packaged with the release, or reinstall the release.
如题,有解决方案吗?目测是GCC版本或配置的锅。
发表于 2020-8-31 13:26:15 来自手机 | 显示全部楼层
1.check if the env variable invlude "GCC" or  "AHDL", if yes,unset them. 2.if  not work, export CDS_AUTO_64BIT=ALL 3.still not work, run $CDSHOME/tools/bin/checkSysConf SPECTRE_VERSION(SPECTRE19.1),send info to me.
发表于 2022-10-17 16:41:58 | 显示全部楼层
open-CAD 发表于 2020-8-31 13:26
1.check if the env variable invlude "GCC" or  "AHDL", if yes,unset them. 2.if  not work, export CDS_ ...
问题解决了吗?
发表于 2024-5-29 16:49:41 | 显示全部楼层
请问这个问题解决了吗?
GMT+8, 2025-12-25 23:40 , Processed in 0.013040 second(s), 3 queries , Gzip On, Redis On.
