查看: 3344|回复: 3
Cadence IC617 + MMSIM 141 ,SPECTRE无法仿真
发表于 2020-6-22 22:18:12 | 显示全部楼层 |阅读模式
ERROR<ADE-3036>:Errors encountered during simulation. The simulator run log has not been generated.
           Possible cause could be an invalid command line option for the version of the simulator you are running. Choose Setup-            >Environment and verify that the command line options specified in the userCmdLineOption field are supported for the            simulator. Alternatively, run the simulator standalone using the runSimulation file in the netlist directory to know the              exact cause of the error.
按照网上的方法都试过了,还是没法解决,请高手帮忙啊,十分感谢
发表于 2020-6-23 05:38:00 | 显示全部楼层
按照错误信息提示,在netlist路径下直接用命令行运行runSimulation,看看会给出什么进一步的错误信息来。
首先查一下你的硬盘是不是满了,或者psf路径下的所有文件你都是有写权限的。
发表于 2020-6-23 10:40:34 | 显示全部楼层
不是提示你命令行有错误吗? 去看看log就知道了
发表于 2023-11-3 14:11:09 | 显示全部楼层
这个解决了吗??
GMT+8, 2025-11-8 20:48 , Processed in 0.017671 second(s), 4 queries , Gzip On, Redis On.
