查看: 4929|回复: 10
求助,tsmc18rf导入cadence失败
发表于 2020-5-24 09:01:01 | 显示全部楼层 |阅读模式
tsmc18已经做了OA转换,techfile的controls已经提到最前面,当我导入techfile文件的时候,提示warning,导入的tsmc18的器件不全,截图如下 Screenshot from 2020-05-24 08-51-46.png Screenshot from 2020-05-24 08-51-56.png Screenshot from 2020-05-24 08-52-20.png Screenshot from 2020-05-24 08-52-32.png 请问这是为什么呢,以前没遇到过
Library Manager created library "tsmc18rfLib"
Loading techComp.cxt
INFO (TECH-180006): Compiling class 'controls'....
INFO (TECH-180006): Compiling class 'layerDefinitions'....
*WARNING* (TECH-280067): The purpose 'slot' is an OA reserved purpose with purpose number -3.
The purpose number 126 of your user-defined purpose 'slot' is no longer recongnized.
Update your technology file to reference the new 'slot' purpose number:
1. Dump the technology file.
2. Change any references to the user-defined purpose number 126 to the reserved system purpose number -3.
3. Reload the technology file.
*WARNING* (TECH-200030): The purpose number for the reserved purpose 'drawing' has been reassigned to purpose number -1.
INFO (TECH-180006): Compiling class 'layerRules'....
*WARNING* (TECH-280104): The streamLayers rule is no longer supported in the technology file.
*WARNING* (TECH-280105): An equivalent layer mapping file will be automatically created.
INFO (TECH-180006): Compiling class 'physicalRules'....
。。。。。。。。。有很多warning,没有全粘贴,只粘贴了开头和结尾
Loading soi.cxt
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA23_stack_north/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA23_stack_south/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA34_stack_east/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA34_stack_west/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA45_stack_north/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA45_stack_south/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA56_stack_east/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-290136): Convert prRules: Skipping device 'VIA56_stack_west/symbolic' because the device containing the prVia cannot be found.
*WARNING* (TECH-230011): techSetLayerPairConstraint: Constraint "stackable" rule is ignored because this rule does not support two layers with the same name (METAL2).
Use constraint "stackable" with two different layers only.
*WARNING* (TECH-230011): techSetLayerPairConstraint: Constraint "stackable" rule is ignored because this rule does not support two layers with the same name (METAL3).
*WARNING* (TECH-230011): techSetLayerPairConstraint: Constraint "stackable" rule is ignored because this rule does not support two layers with the same name (METAL4).
*WARNING* (TECH-230011): techSetLayerPairConstraint: Constraint "stackable" rule is ignored because this rule does not support two layers with the same name (METAL5).
*WARNING* (TECH-290101): techSetPrGenViaRule: metalOverHang and overHang are not stored. Values are ignored for all prGenViaRules.
Loading layers.cxt
 楼主| 发表于 2020-5-24 09:21:30 | 显示全部楼层
等待大神解答中。。。。
发表于 2020-6-15 17:39:15 | 显示全部楼层
请问你解决了吗,我现在也是这样
 楼主| 发表于 2020-6-15 19:05:58 | 显示全部楼层
yond 发表于 2020-6-15 17:39
请问你解决了吗,我现在也是这样
一直没解决
 楼主| 发表于 2020-7-7 20:07:10 | 显示全部楼层
来个大神看看吧,到现在还没解决
 楼主| 发表于 2020-7-13 07:59:56 来自手机 | 显示全部楼层
没有人遇到过这个问题吗
发表于 2020-9-12 11:13:10 | 显示全部楼层
LZ解决了吗?
发表于 2020-12-5 11:54:38 | 显示全部楼层
同样的问题
 楼主| 发表于 2020-12-18 12:56:53 | 显示全部楼层
没有
发表于 2023-10-2 17:22:06 | 显示全部楼层
请问这个问题解决了吗?
GMT+8, 2025-11-25 02:58 , Processed in 0.021778 second(s), 6 queries , Gzip On, Redis On.
