查看: 8515|回复: 14
Sentaurus 安装求助 (SHA256 sum mismatch)
发表于 2020-5-19 17:35:14 | 显示全部楼层 |阅读模式
版上分享的sentaurus TCAD新版本。尝试在RedHat 7系统里安装。
解压都没问题,但是Verify SHA256 sum for linux64/sentaurus.bz2文件的时候始终无法通过。
搜了一下也没有解决方案,不知大家遇到过这个报错没有,求解法 谢谢!
安装log file如下
Synopsys Installer: 5.1.0
Installation Start at: 05/19/2020 05:26:54 PM
Current Directory: /software/Sentaurus2018/SynopsysInstaller_v5.1
Extracting release information from sentaurus_vO_2018.06-SP2_linux64.spf ...
Extracting release information from sentaurus_vO_2018.06-SP2_linux64.spf successfully
Extracting release information from sentaurus_vO_2018.06-SP2_common.spf ...
Extracting release information from sentaurus_vO_2018.06-SP2_common.spf successfully
Installing O_2018.06-SP2 release of sentaurus product...
Extracting common package for O_2018.06-SP2 release of sentaurus ...
Successfully Extract sentaurus.bz2.
Extracting linux64 package for O_2018.06-SP2 release of sentaurus ...
Successfully Extract linux64/sentaurus.bz2.
Verify SHA256 sum for sentaurus.bz2...
Verify SHA256 sum for linux64/sentaurus.bz2...
Can't Install O_2018.06-SP2 release of sentaurus: SHA256 sum mismatch for file /software/Sentaurus2018/SynopsysInstaller_v5.1/snps_installer_temp_26710/linux64/sentaurus.bz2, expected 22de202c3f46158997b5465b7d1693dedf4b5cb75dd708a778cdd16af80a12dc, but found d68baaa26b24b5b97c2e516ee342fd8e5ae97cbeb7e74bd5098e0fa1b069bcb8 //software/Sentaurus2018/SynopsysInstaller_v5.1/snps_installer_temp_26710/linux64/sentaurus.bz2
Installation finished
补充内容 (2020-6-18 15:21):
problem solved 感谢楼上几位,重新下载后可以顺利安装
PS 确实奇怪,之前也怀疑是文件错误,重新下载试过还是不行,后来看了大家的意见,换了一个....
发表于 2020-5-19 19:30:49 | 显示全部楼层
是不是文件错误了?似乎是校验错误。重新下载试试?最近百度网盘抽风。
发表于 2020-5-19 19:33:07 | 显示全部楼层
repeat downloading
发表于 2020-5-19 20:18:14 | 显示全部楼层
I can install this download without any problem
发表于 2020-5-19 21:49:59 | 显示全部楼层
应该是文件错误了,重新下载安装试试。
 楼主| 发表于 2020-5-20 14:36:16 | 显示全部楼层
感谢楼上几位,重新下载后可以顺利安装
PS 确实奇怪,之前也怀疑是文件错误,重新下载试过还是不行,后来看了大家的意见,换了一个地方重新下载,再拷过来安装就可以了
发表于 2020-5-20 20:19:01 | 显示全部楼层
最近百度下载大文件经常出错,我下载win10 2004 iso,5G的文件出错了8M Byte之多
发表于 2020-6-17 15:41:14 | 显示全部楼层
求下载链接
发表于 2020-12-21 18:27:32 | 显示全部楼层
求sentaurus TCAD 2018的下载链接
发表于 2021-8-7 04:56:14 | 显示全部楼层
就是文件出错了,重新下载即可
GMT+8, 2025-12-26 09:01 , Processed in 0.017776 second(s), 3 queries , Gzip On, Redis On.
