查看: 10705|回复: 8
Spectre19无法仿真
发表于 2020-4-3 22:35:54 | 显示全部楼层 |阅读模式
Redhat8,IC617,Spectre19
运行仿真,CIW错误提示:
ERROR (WIA-1175): Cannot plot waveform signals because no waveform data is available for plotting.
One of the possible reasons can be that 'Save' check box for these signals are not selected in the Outputs Setup pane. Ensure that these check boxes are selected before you run the simulation.
ERROR (EXPLORER-5031): While simulating run ExplorerRun.0, point 1, test Sim:INV_VTH:1, received error:
Simulation Error:
Simulator failed to complete the simulation.
The simulator process returned a non-zero exit code, indicating failure.
The simulator could have crashed or intentionally returned to indicate an error.
Check the simulator log file for more information.  Common causes:
1. Simulator may have crashed during exit even after reporting success in log file.
2. Abrupt automatic simulator termination (e.g., SIGKILL) because the simulator process has
   exceeded resource limits, which can be specified in the distribution system or
   by the kernel itself (e.g., the Linux OOMKiller).
3. Manual termination of the simulator process.
./runSimulation can be manually run in this directory to check the issue.
Log file:
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
        Possible cause could be an invalid command line option for the version of the simulator
        you are running. Choose Setup->Environment and verify that the command line options
        specified in the userCmdLineOption field are supported for the simulator.
        Alternatively, run the simulator standalone using the runSimulation file in the netlist
        directory to know the exact cause of the error.
*Error*   Error ID  = 5031
*Error*   Error Msg = Simulator failed to complete the simulation.
终端运行:spectre -v
输出:/opt/cadence/SPECTRE191/tools.lnx86/spectre/bin/64bit/spectre: error while loading shared libraries: libcrypto.so.10: cannot open shared object file: No such file or directory
发表于 2020-4-4 08:14:05 | 显示全部楼层
个人觉得,换redhat7 吧,8的兼容性还得等。估计是系统的组件版本太新了。
发表于 2020-4-7 11:04:49 | 显示全部楼层
缺少库嘛,yum安装就行
发表于 2020-4-7 11:11:28 | 显示全部楼层
提示很清楚啊libcrypto.so.10: cannot open shared object file: No such file or directory
发表于 2020-4-7 13:08:47 | 显示全部楼层
发表于 2020-4-8 02:10:41 | 显示全部楼层
thank you
 楼主| 发表于 2020-4-9 15:19:17 | 显示全部楼层
安装了这个库,还是不行,大佬可以详细说一下操作方法吗,感谢。
发表于 2020-4-9 15:21:29 | 显示全部楼层
还在折腾啊...5楼不是折腾过了,似乎挺麻烦,还不一定能搞定。估计等C家官方支持红帽子8的版本吧。
发表于 2020-4-14 09:51:22 | 显示全部楼层
用IC618吧,另外19需要更新license文件
GMT+8, 2025-12-28 03:00 , Processed in 0.033892 second(s), 4 queries , Gzip On, Redis On.
