楼主: nathan97
S*nops*s .src sample for 2018 version to extend expiration date
发表于 2020-3-13 03:24:23 | 显示全部楼层
nathan97: thank you. I think it is better for other users too.
发表于 2020-3-13 03:25:11 | 显示全部楼层
Thank you. I think it is better for other users too.
发表于 2020-3-19 08:50:28 | 显示全部楼层
Is the src file bigger the better? Which means have quite complete features. I found the src file you attached is only 50KB. Could you share the latest src file you used to generate the license.dat
 楼主| 发表于 2020-3-19 17:39:25 | 显示全部楼层
that is the one I use
 楼主| 发表于 2020-3-19 18:12:05 | 显示全部楼层
Just for everyone's reference I add an alternate keygen which generates the SSS feature directly.
The major difference with respect to the other one is that when starting the license server it says that the features are garbled and tells you that all the revenue keys (RK)  will be disabled. But the softwares will start anyway, just make sure your license variable SNPSLMD_LICENSE_FILE is set to the port@host (e.g., 27000@<your_hostname>.
eetop.cn_scl_keygen.zip
4.87 MB, 下载次数: 73 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2020-3-22 03:53:55 | 显示全部楼层
thank you.
发表于 2020-3-24 13:13:46 | 显示全部楼层
好东西 下载试试
发表于 2020-3-24 20:26:18 | 显示全部楼层
thanks
发表于 2020-3-26 10:39:32 | 显示全部楼层
thank you, does this work with 2019 versions
 楼主| 发表于 2020-3-27 15:15:34 | 显示全部楼层
Unfortunately it does not.
GMT+8, 2025-12-14 13:03 , Processed in 0.025014 second(s), 4 queries , Gzip On, Redis On.
