查看: 6066|回复: 9
有Cadence Spectre 19.1吗?可以共享吗?
发表于 2019-9-15 22:18:50 | 显示全部楼层 |阅读模式
The new release of the Spectre® X Simulator (Spectre 19.1) enables large-scale verification simulation for complex analog, RF, and mixed-signal blocks and subsystems, while maintaining the golden accuracy expected of the Spectre simulation family.
Based on the same golden Spectre accuracy customers have experienced for over 30 years, the Spectre X Simulator is a massively parallel circuit simulator that delivers 3X to 10X performance gains and can solve 5X larger designs, enabling designers to effectively simulate circuits containing millions of transistors and billions of parasitics in a post-layout verification flow.
发表于 2019-9-17 20:42:45 | 显示全部楼层
这个太新了吧?
发表于 2020-10-9 23:11:33 | 显示全部楼层
!thanks!
发表于 2020-10-10 15:47:03 | 显示全部楼层
The latest version is spectre20
发表于 2020-12-8 01:07:22 | 显示全部楼层
Dude, the latest version is spectre20 and we're talking about sharing the 17 version, the 20 version is so hard to obtain
发表于 2020-12-11 10:09:20 | 显示全部楼层
同求啊!!!另外,我是Cadence IC615,可以安装哪个版本的SPECTRE啊
发表于 2021-1-1 13:40:01 | 显示全部楼层
SPECTRE19 Simulation Result Cannot open by IC617 Viva...
发表于 2021-1-1 15:49:49 | 显示全部楼层
有,有其他eda交换吗,或PDK
发表于 2021-1-2 21:23:45 | 显示全部楼层
这个太新了吧?
发表于 2021-11-24 14:26:49 | 显示全部楼层
lanewrr 发表于 2021-1-2 21:23
这个太新了吧?
求一个spectre20,邮箱smh820smh@tju.edu.cn提前感谢了,朋友们
GMT+8, 2025-11-17 01:53 , Processed in 0.019813 second(s), 3 queries , Gzip On, Redis On.
