查看: 1766|回复: 3
redhat 系统下 modelsim 10.2c 安装问题请教
发表于 2019-4-30 16:35:33 | 显示全部楼层 |阅读模式
在redhat 6下,sim软件已安装,待破解,安装wine,死活装不上,各种报问题,很多的问题可以自己安装rpm解决,但是报出如下问题,我不清楚出到底安装哪个rpm,网上都搜过了也找不到答案,请大神帮帮小弟,我都搞了一天啦!这个64-bit development packages到底是个什么鬼,我在http://rpm.pbone.net/搜不到。装软件的电脑不能连外网,yum用不了,我也是没法了
以下是报出来的问题:
configure: error: X 64-bit development files not found. Wine will be built
without X support, which probably isn't what you want. You will need
to install 64-bit development packages of Xlib at the very least.
Use the --without-x option if you really want this.
发表于 2019-5-3 08:40:48 | 显示全部楼层
you know you can get modelsim for linux native?
 楼主| 发表于 2019-5-4 15:06:20 | 显示全部楼层
Thanks for your reply. Could you advise me how to get modelsim for linux native?
 楼主| 发表于 2019-5-9 15:46:01 | 显示全部楼层
问题解决了,激活没有用wine,更改windows下面的host_name和MAC,利用WIN LICENSE 去key linux下面的。
GMT+8, 2025-12-25 19:32 , Processed in 0.017080 second(s), 4 queries , Gzip On, Redis On.
