查看: 4826|回复: 10
3D工艺建模仿真软件
发表于 2019-4-12 22:51:51 | 显示全部楼层 |阅读模式
可用于3D Device如FinFET, GAAFET, 以及3DIC开发
发表于 2019-4-13 03:57:51 | 显示全部楼层
Hi, Thanks for your Tutorial.
Coventor Licensing 1.005 is needed.. Coud you plz send it..
https://www.coventor.com/support/portal/licensing-current/
发表于 2019-4-13 04:00:08 | 显示全部楼层
Hi, thanks for your tutorial. Coventor Licensing 1.005 is required to run SEMulator3D 7.1. Could you plz share it.
发表于 2019-5-6 12:21:34 | 显示全部楼层
Could you share licensing daemon
 楼主| 发表于 2021-12-30 23:51:47 | 显示全部楼层
the license was expired, are you able to crack the license?
发表于 2022-1-2 09:37:55 | 显示全部楼层
Please contact me , I can patch it!
发表于 2022-1-3 19:47:46 | 显示全部楼层
哪位有 coventor 的账号,帮助下载一个支持 SEMUlator3D最新的 Coventor Licensing Manager,谢谢。
发表于 2022-1-14 11:06:29 | 显示全部楼层
can you give me a license patch.thanks
 楼主| 发表于 2022-1-14 14:37:17 | 显示全部楼层
我们是正版
发表于 2022-1-14 14:55:06 | 显示全部楼层
wzh176 发表于 2022-1-14 14:37
我们是正版
请把你的 license manager给我,谢谢。
GMT+8, 2025-12-4 19:53 , Processed in 0.018404 second(s), 2 queries , Gzip On, Redis On.
