查看: 4277|回复: 3
R3D软件上传悬赏
发表于 2018-11-13 17:50:53 | 显示全部楼层 |阅读模式
悬赏1000资产未解决
求Silicon Frontline R3D软件和License Resistive 3D Extraction and Analysis
R3D is a resistive 3D extraction and analysis product for large resistive structures like power devices.  Efficiency and reliability are key design criteria and R3D provides a solution to calculate and optimize both.
The current density, potential distribution and sensitivity analysis provided, allows users to quickly identify the critical areas of their design and improve the design for electromigration and IR Drop, improving reliability.
By using Rdson and the RC distributed netlist, efficiency improvements are quickly achievable, reducing both static and switching losses.
R3D provides the ability to optimize metal layouts, sense device location, bondpads and metal slotting, further improving the efficiency and reliability.
发表于 2018-11-13 21:15:21 | 显示全部楼层
我再加1000
发表于 2018-11-14 15:40:13 | 显示全部楼层
发表于 2019-3-15 17:56:17 | 显示全部楼层
楼主是否已经获取了r3d的安装包和license,如果已经有了是否可以分享一下
GMT+8, 2025-12-21 22:14 , Processed in 0.018071 second(s), 4 queries , Gzip On, Redis On.
