查看: 1076|回复: 0
[招聘] 国内AI芯片研发公司数字后端职位招聘
发表于 2018-9-28 16:40:35 | 显示全部楼层 |阅读模式
Senior ASIC Backend Design engineer/高级Asic后端设计工程师
RESPONSIBILITIES:
- Execute the whole Backend Design flow include Floorplan/Placement/CTS/Routing/Physical Verification
- Work with front end design Engineers to achieve timing closure for both partition level and full chip level
- IO ring design
- Cross talk Analysis
- IR Drop and Power Integrity Analysis
- Execute ECO's.
- Develop and enhance entire physical design flow from frontend (pre-layout) to backend (post-layout) at both chip and block level.
MINIMUM REQUIREMENTS:
BS or MS in Electrical Engineering or Computer Science
Relevant ASIC experience ideally with a focus in the chip integration /synthesis/formal and timing closure
Excellent scripts skills
Keep up to date with leading edge technologies
Work under pressure
GMT+8, 2025-11-10 06:54 , Processed in 0.011820 second(s), 4 queries , Gzip On, Redis On.
