查看: 4829|回复: 10
[资料] A compact power efficient 3V CMOS Rail to Rail Input/Output Operation Amplifier
发表于 2018-7-6 22:27:16 | 显示全部楼层 |阅读模式
IEEE JOURNAL OF SOLID-STATE CIRCUITS. VOL. 29. NO I?. DECEMBER 1994A Compact Power-Efficient 3 V CMOS
Rail-to-Rail Input/Output Operational
Amplifier for VLSI Cell Libraries
Ron Hogervorst, John P. Tero, Ruud G. H. Eschauzier, and Johan H. Huijsing
Abstruct- This paper presents a two-stage, compact, powerefficient
3 V CMOS operational amplifier with rail-to-rail input
and output ranges. Because of its small die area of 0.04 mm', it is
very suitable as a VLSI library cell. The floating class-AB control Compact_op_amp_AB.pdf (926.42 KB , 下载次数: 113 )
is shifted into the summing circuit, which results in a noise and
offset of the amplifier which are comparable to that of a three
stage amplifier. A floating current source biases the combined
summing circuit and the class-AB control. This current source
has the same structure as the class-AB control which provides a
power-supply-independent quiescent current. Using the compact
architecture, a 2.6 MHz amplifier with Miller compensation and
a 6.4 MHz amplifier with cascoded-Miller compensation has been
realized. The opamps have, respectively, a bandwidth-to-supplypower
ratio of 4 MHdmW and 11 MHdmW for a capacitive
load of 10 pF
[url=]Compact_op_amp_AB.pdf[/url]
发表于 2018-7-7 21:35:10 | 显示全部楼层
looking
发表于 2018-9-11 11:51:35 | 显示全部楼层
谢谢楼主分享~ very good !!!
发表于 2018-12-26 13:31:28 | 显示全部楼层
Hogervorst的硕博士论文能下载到吗?
发表于 2019-3-7 08:01:27 | 显示全部楼层
非常感謝~~~~~
发表于 2019-8-11 16:15:10 | 显示全部楼层
thanks a lot~~~
发表于 2019-8-17 16:15:07 | 显示全部楼层
thanks a lot!
发表于 2020-5-13 11:25:49 | 显示全部楼层
非常感谢
发表于 2020-8-18 02:40:48 | 显示全部楼层
Thanks a lot
发表于 2021-8-20 11:45:01 | 显示全部楼层
不错。
GMT+8, 2025-12-14 13:09 , Processed in 0.021937 second(s), 5 queries , Gzip On, Redis On.
