查看: 26899|回复: 70
[求助] 求书,Op Amps for Everyone, Fifth Edition, 2017。4#为上传图书PDF
发表于 2018-1-16 04:01:42 | 显示全部楼层 |阅读模式
请问哪位能找到这个本书,是否可上传一下,谢谢。
https://www.amazon.com/gp/product/012811648X/ref=s9u_simh_gw_i1?ie=UTF8&fpl=fresh&pd_rd_i=012811648X&pd_rd_r=298f3f00-fa2f-11e7-a77e-4f4ee7533ebd&pd_rd_w=xw9Mt&pd_rd_wg=de9fD&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=7BHYMJA4597FN9RF6CN9&pf_rd_t=36701&pf_rd_p=e6624b56-7cc1-411f-9d12-9cc8feb6c214&pf_rd_i=desktop
Op Amps for Everyone, Fifth Edition, will help you design circuits that are reliable, have low power consumption, and can be implemented in as small a size as possible at the lowest possible cost. It bridges the gap between the theoretical and practical by giving pragmatic solutions using components that are available in the real world from distributors. The book does not just give a design with a transfer function; instead, it provides design tools based on transfer function, getting you to a working circuit so you can make the right decision on which op amp is best for the job at hand.
With this book you will learn: single op amp designs that get the most out of every amplifier; which specifications are of most importance to your design, enabling you to narrow down the list of amplifiers to those few that are most suitable; strategies for making simple tweaks to the design-changes that are often apparent once a prototype has been constructed; how to design for hostile environments-extreme temperatures, high levels of shock, vibration, and radiation-by knowing which circuit parameters are likely to degrade and how to counteract that degradation.
    Features real world op amp selection guides
    Teaches which op amp is best for the job
    Includes design circuits with real world component values
    Contains guidelines for developing the entire signal chain, from specification for the transducer to power supply and data converter
    Includes new coverage of negative regulation techniques and op amp stability, negative regulation techniques, extended electronics theory and troubleshooting
Product details
  • Paperback: 484 pages
  • Publisher: Newnes; 5 edition (July 28, 2017)
  • Language: English
  • ISBN-10: 012811648X
  • ISBN-13: 978-0128116487
  •     Product Dimensions:         7.5 x 1.2 x 9.2 inches
发表于 2018-1-16 15:02:15 | 显示全部楼层
第五版基本没戏
发表于 2018-1-16 15:04:23 | 显示全部楼层
发表于 2018-1-16 15:52:53 | 显示全部楼层
回复 1# haoyun
    Bruce Carter_ Ron Mancini-Op Amps for Everyone-Newnes (2017).pdf (7.88 MB , 下载次数: 659 )
 楼主| 发表于 2018-1-16 16:36:28 | 显示全部楼层
回复 3# STSnow
    是的,论坛上有第四版,谢谢你。
 楼主| 发表于 2018-1-16 16:38:23 | 显示全部楼层
回复 2# STSnow
    第五版有高手上传了,你也赶紧下载吧。
 楼主| 发表于 2018-1-16 16:43:33 | 显示全部楼层
回复 4# edafolks
我在网上费了大劲也没能搜到,真没想到这么快就能得到您的帮助。
太感谢了,太感谢了。
发表于 2018-1-16 18:14:59 | 显示全部楼层
回复 4# edafolks
牛啊
发表于 2018-1-16 19:01:19 | 显示全部楼层
谢谢分享
发表于 2018-1-16 21:15:53 | 显示全部楼层
好书,谢谢分享
GMT+8, 2025-12-30 11:37 , Processed in 0.021707 second(s), 4 queries , Gzip On, Redis On.
