楼主: edafolks
Systematic Design of Analog CMOS Circuits (Complete GM/ID )
发表于 2021-4-22 22:34:12 | 显示全部楼层
发表于 2021-4-23 08:09:02 | 显示全部楼层
The above- stated modeling limitations are a great nuisance when it comes to design, since the square- law hand calculations described in textbooks typically won’t match simulations for a classical flow (see Figure 1.2). Modern circuit simulation relies on complex device models such as BSIM6 [6] or PSP1 [7], which are carefully crafted to reflect the “real” device characteristic in Figure 1.1. The result is a significant disconnect between hand analysis and simulation results, and consequently,designers tend to shy away from hand- calculations and resort to a design style built on iterative and time- consuming SPICE- based “tweaking.”
发表于 2021-7-10 20:45:39 | 显示全部楼层
thanks a lot
发表于 2021-8-27 17:26:22 | 显示全部楼层
看看
发表于 2021-8-27 21:09:34 | 显示全部楼层
kankan
发表于 2021-10-11 09:36:12 | 显示全部楼层
谢谢楼主分享
发表于 2021-10-15 03:26:39 | 显示全部楼层
Thanks for the sharing!
发表于 2022-3-22 15:44:10 | 显示全部楼层
发表于 2022-3-23 09:49:00 | 显示全部楼层
Good book
发表于 2023-7-1 15:19:11 | 显示全部楼层
thanks
GMT+8, 2025-12-25 19:19 , Processed in 0.017910 second(s), 3 queries , Gzip On, Redis On.
