查看: 1806|回复: 4
need to run virtuoso
发表于 2017-9-16 07:02:45 | 显示全部楼层 |阅读模式
please help to get cadence licenses to run virtuoso and spectre
发表于 2017-9-18 09:30:46 | 显示全部楼层
i can !!!!!!!!!!
 楼主| 发表于 2017-9-18 12:55:17 | 显示全部楼层
回复 2# maomao198477
   thank you for reply
could I get cadence licenses for virtuoso and spectre?
发表于 2017-9-26 10:27:36 | 显示全部楼层
回复 3# xiaoyisimonguo
You need to crack software first. Then the SW will not check the hostid, and you will used common license file.
 楼主| 发表于 2017-9-27 07:18:17 | 显示全部楼层
回复 4# daviehj
   Thank you for reply, I am not sure I could crack the software, virtuoso or spectre in this case.
Could you please help?
My e-mail address: xiaoyi.guo@yahoo.com
in case you need e-mail communication
GMT+8, 2025-10-8 03:07 , Processed in 0.011981 second(s), 3 queries , Gzip On, Redis On.
