查看: 2066|回复: 3
[求助] set_input_delay -cloc clock_name 这个clock_name应该是模块内部的还是外部的那个?
发表于 2017-8-22 23:02:41 | 显示全部楼层 |阅读模式
 楼主| 发表于 2017-8-22 23:05:19 | 显示全部楼层
-clock option is used to specify the reference clock, with respect to which the delay
value is specified. This should usually refer to the name of the clock which is used
to trigger the signal that reaches this input port
发表于 2017-9-19 11:04:44 | 显示全部楼层
取决于设计input pin 驱动时钟来源于哪里。
发表于 2020-10-20 08:35:25 | 显示全部楼层
set_input_delay  为launch clock, set_output_delay 为capture clock
GMT+8, 2025-9-19 07:18 , Processed in 0.013210 second(s), 3 queries , Gzip On, Redis On.
