查看: 10014|回复: 3
Ubuntu1604 server安装verdi2014 license socket error
发表于 2017-8-2 18:04:55 | 显示全部楼层 |阅读模式
悬赏10资产未解决
Ubuntu1604 server安装verdi2014,提示license软件lmgrd打不开socket:
12:45:03 (snpslmd) Failed to open socket to lmgrd, Exiting
使用 verdi -licdebug有如下信息:
######################### verdi -licdebug info #################
logDir = /tmp/verdi_08_02_2017_8116
Verdi Release Verdi3_I-2014.03 (RH Linux x86_64/64bit) 02/11/2014
(C) 1999 - 2014 by Synopsys, Inc.
All Rights Reserved.
www.synopsys.com
This program is proprietary and confidential information of Synopsys, Inc. and
may be used and disclosed only as authorized in a license agreement controlling
such use and disclosure.
Licensed Products communicate with Synopsys servers for the purpose of providing
software updates, detecting software piracy and verifying that customers are
using Licensed Products in conformity with the applicable License Key for such
Licensed Products. Synopsys will use information gathered in connection with
this process to deliver software updates and pursue software pirates and
infringers.
rcfile = /usr/synopsys/verdi2014.03/etc/novas.rc
guiConfFile = /home/luoy/novas.conf
FLEXnet Licensing checkout error: Cannot read data from license server system.
The license server system appears to be running, but is not
responding.  If this persists, notify the System Administrator.
(The license server manager (lmgrd) and vendor daemon processes
should be terminated and restarted.)
Feature:       Verdi
License path:  /usr/local/flexlm/licenses/license.dat
FLEXnet Licensing error:-16,10009.  System Error: 104 "Connection reset by peer"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
license file(s):  /usr/local/flexlm/licenses/license.dat
FLEXnet Licensing checkout error: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       Verdi
Server name:   uTT02
FLEXnet Licensing error:-15,570.  System Error: 115 "Operation now in progress"
[SCL] 08/02/2017 17:35:15 PID:8116 uTT02 Checkout denied Verdi 2014.03
Could not checkout Verdi license. Use Verdi -licdebug for more information.
####################### lmgrd detail log ############################
12:44:53 (lmgrd) -----------------------------------------------
12:44:53 (lmgrd)   Please Note:
12:44:53 (lmgrd)
12:44:53 (lmgrd)   This log is intended for debug purposes only.
12:44:53 (lmgrd)   In order to capture accurate license
12:44:53 (lmgrd)   usage data into an organized repository,
12:44:53 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
12:44:53 (lmgrd)   software license administration  solution,
12:44:53 (lmgrd)   FLEXnet Manager, to  readily gain visibility
12:44:53 (lmgrd)   into license usage data and to create
12:44:53 (lmgrd)   insightful reports on critical information like
12:44:53 (lmgrd)   license availability and usage. FLEXnet Manager
12:44:53 (lmgrd)   can be fully automated to run these reports on
12:44:53 (lmgrd)   schedule and can be used to track license
12:44:53 (lmgrd)   servers and usage across a heterogeneous
12:44:53 (lmgrd)   network of servers including Windows NT, Linux
12:44:53 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
12:44:53 (lmgrd)   www.acresso.com for more details on how to
12:44:53 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
12:44:53 (lmgrd)   for your enterprise.
12:44:53 (lmgrd)
12:44:53 (lmgrd)
12:44:53 (lmgrd)
12:44:53 (lmgrd) FLEXnet Licensing (v11.6.1.0 build 66138 i86_re3) started on uTT02 (linux) (8/1/2017)
12:44:53 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
12:44:53 (lmgrd) US Patents 5,390,297 and 5,671,412.
12:44:53 (lmgrd) World Wide Web:  http://www.acresso.com
12:44:53 (lmgrd) License file(s): /usr/local/flexlm/licenses/license.dat
12:44:53 (lmgrd) lmgrd tcp-port 27000
12:44:53 (lmgrd) Starting vendor daemons ...
12:44:53 (lmgrd) Started snpslmd (internet tcp_port 51446 pid 25231)
12:44:53 (snpslmd) FlexNet Licensing version v11.12.1.2 build 152538 x64_lsb
12:44:53 (snpslmd) lmgrd version 11.6, snpslmd version 11.12
08/01/2017 12:44:53 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.9
08/01/2017 12:44:55 (snpslmd) File descriptor limit (soft, hard) for snpslmd: 65536, 65536
12:44:55 (snpslmd) SLOG: Summary LOG statistics is enabled.
12:44:55 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
12:44:55 (snpslmd) SLOG: VM Status: 0
12:44:55 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT2
12:44:56 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
12:44:57 (snpslmd) Server started on uTT02 for:    SSS
12:44:57 (snpslmd) 3D        3P        AARKOS-A
12:44:57 (snpslmd) ABB_CHCRC_LIBRARY ACEX1K        ACS
12:44:57 (snpslmd) ACT2-1200XL    ACT3        AI
12:44:57 (snpslmd) ARM7TDMI    ATMEL        ATMWB_ATMLAYER
12:44:57 (snpslmd) ATMWB_UTOPIA    AU        AUSP
12:44:57 (snpslmd) AUT_NUMBER_MAJOR_PACKAGES AdvanceCalibration_all AdvancedCalibration_all
12:44:57 (snpslmd) Apollo        ApolloGA    CPI-100
12:44:57 (snpslmd) CTV-Interface    CUSTOM_LIB    CYPRESS
12:44:57 (snpslmd) Constraint_Translation Converter    Cosmos_scope
12:44:57 (snpslmd) D3        DATAIO        DB-Mode
12:44:57 (snpslmd) DE        DEMO        DF
12:44:57 (snpslmd) DIRECTMEM    Delta39k    Early-Access-Technology
12:44:57 (snpslmd) EssentialSignalAnalysis Eview        Extraction
12:44:57 (snpslmd) FAILURE_MODE    FAILURE_MODE_MEMSSE FASTPARTS
12:44:57 (snpslmd) FCII-Altera-Edition FCO        FPABP
12:44:57 (snpslmd) FPDP        FPPRT        FPTA
12:44:57 (snpslmd) FPTime        FSM-Reader    FSM-Writer
12:44:57 (snpslmd) FUSE_CHAR    FUSE_CHAR_MEMSSE Flash370i
12:44:57 (snpslmd) Floorplan-Management FusionVantageLmcInterface GENERICVSP
12:44:57 (snpslmd) GRAPHICS_INTERFACE Gaia        GuidedTraceAnalysis
12:44:57 (snpslmd) HLS-FPGA-SystemC HLS-SystemC    HSPICE_MODEL_LIBRARY
12:44:57 (snpslmd) HSPICE_MODEL_LIBRARY_MEMSSE HighLevel-Power-Analysis HighLevel-Power-Optimization
12:44:57 (snpslmd) Hsp-vacomp    ICInteractive    IC_DESIGN_LIB
12:44:57 (snpslmd) IMECH_LIBRARY    INCREMENTs    IROI
12:44:57 (snpslmd) ISExtract_all    Key-Generator    LINYE
12:44:57 (snpslmd) LO        LP        LSA
12:44:57 (snpslmd) LSA_MEMSSE    LSI-Interface    LSS4E
12:44:57 (snpslmd) Leakage-Power    Library-Compiler MAST_COMPILER
12:44:57 (snpslmd) MAdv        MCD        MD
12:44:57 (snpslmd) MDataCheck    MDataPrep    MDynLink
12:44:57 (snpslmd) MEASURE        MEASURE_MEMSSE    MEMPRO
12:44:57 (snpslmd) MEMPRO-LIB    MEMS        MENTOR_FRAMEWAY
12:44:57 (snpslmd) MENTOR_FRAMEWAY_MEMSSE MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE
12:44:57 (snpslmd) MERCURY        MG        MI
12:44:57 (snpslmd) Mars        Mentor-Interface Milkyway
12:44:57 (snpslmd) Milkyway-Interface NCX        NCX-addon
12:44:57 (snpslmd) NET-TRAN    NP        Nova-ExploreRTL-Verilog
12:44:57 (snpslmd) PAW        PC-Expert    PLACEHOLDER
12:44:57 (snpslmd) PM        PNET_LIBRARY    PNEUM_HYD_PRG1
12:44:57 (snpslmd) PNEU_HYD_LIBRARY POLARIS_SCOPE    POLARIS_X
12:44:57 (snpslmd) POWER_EXPRESS    PPPRT        PSG-SDE
12:44:57 (snpslmd) PS_CTS        PS_Extraction    PS_Noise_Optimization
12:44:57 (snpslmd) PVCSCompiler_Net PVCSRuntime_Net ParDiSo_all
12:44:57 (snpslmd) Parse-Tree-Translator Pathmill-migrate Pathmill-plus-migrate
12:44:57 (snpslmd) QLOGIC        QT        Quantum38k
12:44:57 (snpslmd) RA        RCXTEO        RMAN_RUN
12:44:57 (snpslmd) RT54SXS        RailMacro    Reusner
12:44:57 (snpslmd) RouteCompiler    RtlGateCorrelation S4
12:44:57 (snpslmd) S4ED        S4EI        SEU
12:44:57 (snpslmd) SJCL_LIBRARY    SKDB_Import    STATEBENCH
12:44:57 (snpslmd) STRESS        STRESS_MEMSSE    ST_LIBRARY
12:44:57 (snpslmd) SYNARIO        SilVE        Siloti
12:44:57 (snpslmd) Siloti_fe    Siloti_o2    SimVE
12:44:57 (snpslmd) SolarGAII    SolarII        Stamp-Compiler
12:44:57 (snpslmd) StarXtract    Sxtract_all    Syn-Library-Compiler
12:44:57 (snpslmd) T3        TA        TBS
12:44:57 (snpslmd) TC-Beta        TD        TLM_Synthesis
12:44:57 (snpslmd) TP        TR        TRUE
12:44:57 (snpslmd) TV        TimingAnalysis    TurboWave
12:44:57 (snpslmd) Ultra37000    VANTIS        VF
12:44:57 (snpslmd) VPC        VSP_DRIVER    Verdi
12:44:57 (snpslmd) Verification-Token VirSim        WRITE
12:44:57 (snpslmd) WhatIfAnalysis    aPrv        aiu_foundation
12:44:57 (snpslmd) amga        any_technology    avanwaves
12:44:57 (snpslmd) avanwaveswin    awe_rcr        cadence
12:44:57 (snpslmd) cadence_epic    cdsaavmx    cdsaawaves
12:44:57 (snpslmd) cdsmetalib    cdsnet        certify
12:44:57 (snpslmd) certifysc    chiparch_migrate chipviewer
12:44:57 (snpslmd) cxp        delaymill    eX
12:44:57 (snpslmd) edif2e        electromigration_drc encore
12:44:57 (snpslmd) encrypt        etran        example_INCREMENT
12:44:57 (snpslmd) fastspice_xa    gemini_hspice    gentech
12:44:57 (snpslmd) leda-mx        leda_checker    leda_mx
12:44:57 (snpslmd) libarc        lsim_parser    mentorf
12:44:57 (snpslmd) metaencrypt3des metawaves    metawaveswin
12:44:57 (snpslmd) mg_falcon_epic    milltools    misc
12:44:57 (snpslmd) mti_epic    nlcc        npi
12:44:57 (snpslmd) pathfinder    planet_migrate    platform_creator_sysc
12:44:57 (snpslmd) pmga        prmspx_visual_all provhdl_checker
12:44:57 (snpslmd) psf        pwga        rad
12:44:57 (snpslmd) rm_eee        route66        rslv3d
12:44:57 (snpslmd) rslv3dviewer    scratch        sda
12:44:57 (snpslmd) sharp        simif        snps_fs_nwave
12:44:57 (snpslmd) sptopography2d_all systemc_ide    tSchema
12:44:57 (snpslmd) techviewer    testing        tfm
12:44:57 (snpslmd) usb_device_vmt    vcd2e        vcsace
12:44:57 (snpslmd) verilog_writer    vertue        vhdl_compiler
12:44:57 (snpslmd) vtran        xp        vera_comp
12:44:57 (snpslmd) vera_debug    vera_ip        vera_rtime
12:44:57 (snpslmd) viewlogic    viewlogic_epic    vlog2e
12:44:57 (snpslmd) vlog_epic_pif    vlsi2000    vlsi500
12:44:57 (snpslmd) vsea-calib    vsea-calib_all    vsea-calib_ise
12:44:57 (snpslmd) vsea-calib_ise_all vsecP_OEM_VCS_FUJITSU_GEN_NL vsecP_OEM_VCS_FUJITSU_GEN_NW
12:44:57 (snpslmd) vsecP_OEM_VCS_FUJITSU_RUN_NL vsecP_OEM_VCS_FUJITSU_USE_NL vsecP_OEM_VCS_FUJITSU_USE_NW
12:44:57 (snpslmd) timemill    timemill/ace    timemill/av
12:44:57 (snpslmd) timemill/bcx    timemill/bdc    timemill/beta_status
12:44:57 (snpslmd) timemill/btm    timemill/csx    timemill/internal_use
12:44:57 (snpslmd) timemill/msx    timemill/nsaddon turboSchema
12:44:57 (snpslmd) turboState    turboTracer    turbowave_epic
12:44:57 (snpslmd) simwave        simwave_epic    sparallel
12:44:57 (snpslmd) sparallel_all    sparallel_ise    sparallel_ise_all
12:44:57 (snpslmd) spcmcalib_all    spcmlib        spcmlib_all
12:44:57 (snpslmd) spcmlib_ise    spcmlib_ise_all spcmstd
12:44:57 (snpslmd) spcmstd_all    spcmstd_ise    spcmstd_ise_all
12:44:57 (snpslmd) spcmtcl        spcmtcl_all    spcmtcl_ise
12:44:57 (snpslmd) spcmtcl_ise_all spice_explorer    spice_parser
12:44:57 (snpslmd) sprocess    sprocess-an-imp3d sprocess-an-imp3d_all
12:44:57 (snpslmd) sprocess-an-imp3d_ise sprocess-an-imp3d_ise_all sprocess-parallel4_all
12:44:57 (snpslmd) sprocess-parallel_all sprocess2d    sprocess2d_all
12:44:57 (snpslmd) sprocess2d_ise    sprocess2d_ise_all sprocess2dmc
12:44:57 (snpslmd) sprocess2dmc_all sprocess2dmc_ise sprocess2dmc_ise_all
12:44:57 (snpslmd) sprocess3d    sprocess3d_all    sprocess3d_ise
12:44:57 (snpslmd) sprocess3d_ise_all sprocess3dmc    sprocess3dmc_all
12:44:57 (snpslmd) sprocess3dmc_ise sprocess3dmc_ise_all sprocess_all
12:44:57 (snpslmd) sprocess_ise    sprocess_ise_all sprocesskmc_all
12:44:57 (snpslmd) sprocessmc    sprocessmc_all    sprocessmc_ise
12:44:57 (snpslmd) sprocessmc_ise_all sprocessmpp_all stars_analog
12:44:57 (snpslmd) stars_aryred    stars_cmi    stars_csdf
12:44:57 (snpslmd) stars_hsplnk    stars_ish    stars_linred
12:44:57 (snpslmd) stars_mr    stars_wsf    starsim
12:44:57 (snpslmd) starsimxt    start_aed    start_analysis
12:44:57 (snpslmd) start_bin    startime    sup2lig
12:44:57 (snpslmd) sup2lig_all    sup2lig_ise    sup2lig_ise_all
12:44:57 (snpslmd) swb        swb-advanced    swb-advanced_all
12:44:57 (snpslmd) swb-advanced_ise swb-advanced_ise_all swb_all
12:44:57 (snpslmd) swb_ise        swb_ise_all    sx_cdslink
12:44:57 (snpslmd) sx_chip        sx_daiclink    sx_drc
12:44:57 (snpslmd) sx_wva        synplify    synplifyasic
12:44:57 (snpslmd) synplifydspoption synplifydspsl    synplifypremier
12:44:57 (snpslmd) synplifypremierdp synplifypro    synplifypro_asix
12:44:57 (snpslmd) sdevice-optic    sdevice-optic_all sdevice-optic_ise
12:44:57 (snpslmd) sdevice-optic_ise_all sdevice-parallel sdevice-parallel4
12:44:57 (snpslmd) sdevice-parallel4_all sdevice-parallel4_ise sdevice-parallel4_ise_all
12:44:57 (snpslmd) sdevice-parallel_all sdevice-parallel_ise sdevice-parallel_ise_all
12:44:57 (snpslmd) sdevice-pmi    sdevice-pmi_all sdevice-pmi_ise
12:44:57 (snpslmd) sdevice-pmi_ise_all sdevice-radiation sdevice-radiation_all
12:44:57 (snpslmd) sdevice-radiation_ise sdevice-radiation_ise_all sdevice-reliability
12:44:57 (snpslmd) sdevice-reliability_all sdevice-reliability_ise sdevice-reliability_ise_all
12:44:57 (snpslmd) sdevice-schroedinger sdevice-schroedinger_all sdevice-schroedinger_ise
12:44:57 (snpslmd) sdevice-schroedinger_ise_all sdevice-sige    sdevice-sige_all
12:44:57 (snpslmd) sdevice-sige_ise sdevice-sige_ise_all sdevice-thermo
12:44:57 (snpslmd) sdevice-thermo_all sdevice-thermo_ise sdevice-thermo_ise_all
12:44:57 (snpslmd) sdevice-traps    sdevice-traps_all sdevice-traps_ise
12:44:57 (snpslmd) sdevice-traps_ise_all sdevice-vectoroptic sdevice-vectoroptic_all
12:44:57 (snpslmd) sdevice-vectoroptic_ise sdevice-vectoroptic_ise_all sdevice_all
12:44:57 (snpslmd) sdevice_ise    sdevice_ise_all sdevicemonosemicond
12:44:57 (snpslmd) sdevicemonosemicond_all sdevicemonosemicond_ise sdevicemonosemicond_ise_all
12:44:57 (snpslmd) sde        sde3d        sde3d_all
12:44:57 (snpslmd) sde3d_ise    sde3d_ise_all    sde_all
12:44:57 (snpslmd) sde_ise        sde_ise_all    sdevcie-laser_all
12:44:57 (snpslmd) sdevice        sdevice-3d    sdevice-3d_all
12:44:57 (snpslmd) sdevice-3d_ise    sdevice-3d_ise_all sdevice-densitygrad
12:44:57 (snpslmd) sdevice-densitygrad_all sdevice-densitygrad_ise sdevice-densitygrad_ise_all
12:44:57 (snpslmd) sdevice-ferro    sdevice-ferro_all sdevice-ferro_ise
12:44:57 (snpslmd) sdevice-ferro_ise_all sdevice-floatinggate sdevice-floatinggate_all
12:44:57 (snpslmd) sdevice-floatinggate_ise sdevice-floatinggate_ise_all sdevice-gateleakage
12:44:57 (snpslmd) sdevice-gateleakage_all sdevice-gateleakage_ise sdevice-gateleakage_ise_all
12:44:57 (snpslmd) sdevice-hetero    sdevice-hetero_all sdevice-hetero_ise
12:44:57 (snpslmd) sdevice-hetero_ise_all sdevice-hydro    sdevice-hydro_all
12:44:57 (snpslmd) sdevice-hydro_ise sdevice-hydro_ise_all sdevice-kpgain
12:44:57 (snpslmd) sdevice-kpgain_all sdevice-kpgain_ise sdevice-kpgain_ise_all
12:44:57 (snpslmd) sdevice-laser    sdevice-laser_all sdevice-laser_ise
12:44:57 (snpslmd) sdevice-laser_ise_all sdevice-led    sdevice-led_all
12:44:57 (snpslmd) sdevice-led_ise sdevice-led_ise_all sdevice-mixedmode
12:44:57 (snpslmd) sdevice-mixedmode_all sdevice-mixedmode_ise sdevice-mixedmode_ise_all
12:44:57 (snpslmd) sdevice-montecarlo sdevice-montecarlo_all sdevice-montecarlo_ise
12:44:57 (snpslmd) sdevice-montecarlo_ise_all sdevice-noise    sdevice-noise_all
12:44:57 (snpslmd) sdevice-noise_ise sdevice-noise_ise_all railmill
12:44:57 (snpslmd) railmill/ace    railmill/av    railmill/bcx
12:44:57 (snpslmd) railmill/beta_status railmill/gbx    railmill/internal_use
12:44:57 (snpslmd) railmill/msx    railmill/power    railmill/rvfp
12:44:57 (snpslmd) railmill/snx    railmill/spnx    railmill/ssnx
12:44:57 (snpslmd) pathmill    pathmill/cso    pathmill/ctx
12:44:57 (snpslmd) pathmill/dsx    pathmill/pfx    pathmill/sfx
12:44:57 (snpslmd) pathmill_plus    polaris-cbs    polaris-com
12:44:57 (snpslmd) polaris-int    polaris-mt    polaris-signalscan
12:44:57 (snpslmd) powerarc    powergate    powrmill
12:44:57 (snpslmd) powrmill/ace    powrmill/av    powrmill/bcx
12:44:57 (snpslmd) powrmill/beta_status powrmill/btm    powrmill/csx
12:44:57 (snpslmd) powrmill/internal_use powrmill/msx    powrmill/nsaddon
12:44:57 (snpslmd) powrmill/power    powrmill/svcz    powrmill/vlog_a
12:44:57 (snpslmd) primepower    primepower_beta primepower_gui
12:44:57 (snpslmd) primepower_vcd    primerail_hsim    nAnalyzer
12:44:57 (snpslmd) nBench        nClock        nCompare
12:44:57 (snpslmd) nECO        nESL        nLint
12:44:57 (snpslmd) nLint_either    nLint_mixed    nLint_sv
12:44:57 (snpslmd) nLint_verilog    nLint_vhdl    nMonitor
12:44:57 (snpslmd) nProp        nSC        nSchema
12:44:57 (snpslmd) nSchemaOnly    nState        nTE
12:44:57 (snpslmd) nTX        nTiming        nTrace
12:44:57 (snpslmd) nTree        nWave        nanochar
12:44:57 (snpslmd) nanosim        nanosim/ace    nanosim/ace_cosim
12:44:57 (snpslmd) nanosim/av    nanosim/bcx    nanosim/bdc
12:44:57 (snpslmd) nanosim/beta_status nanosim/btm    nanosim/gui
12:44:57 (snpslmd) nanosim/internal_use nanosim/msx    nanosim/postlayout_har
12:44:57 (snpslmd) nanosim/power    nanosim/vlog_a    nanosim_starsimxt
12:44:57 (snpslmd) identdebugger    identdebugger_encrypt identdebugger_xilinx
12:44:57 (snpslmd) identify_tps    identifydebugger identifydebugger_encrypt
12:44:57 (snpslmd) identifydebugger_xilinx identifyinstrumentor identifyinstrumentor_encrypt
12:44:57 (snpslmd) identifyinstrumentor_xilinx identinstrumentor identinstrumentor_encrypt
12:44:57 (snpslmd) identinstrumentor_xilinx identprodebugger identprodebugger_encrypt
12:44:57 (snpslmd) identprodebugger_xilinx identproinstrumentor identproinstrumentor_encrypt
12:44:57 (snpslmd) identproinstrumentor_xilinx ispLSI1K    ispLSI2K
12:44:57 (snpslmd) ispLSI2KE    ispLSI3K    ispLSI5000S
12:44:57 (snpslmd) ispLSI5000SE    ispLSI5K    ispLSI6K
12:44:57 (snpslmd) ispLSI8K    ispMACH4000    hd_foundation
12:44:57 (snpslmd) hd_pna        hd_special1    hd_special2
12:44:57 (snpslmd) hd_special3    hd_utils    hdlin
12:44:57 (snpslmd) hdlin_mixed    hdlin_verilog    hdlin_vhdl
12:44:57 (snpslmd) hicdr_test    hicdr_test/test1 hicdr_test/test2
12:44:57 (snpslmd) hicdr_test/test3 hicdr_test/test4 hicdr_test/test5
12:44:57 (snpslmd) hicdr_test/test6 hicdr_test/test7 hicdr_test/test8
12:44:57 (snpslmd) him_mb        him_mb_dsml    him_mm_pi
12:44:57 (snpslmd) him_mod        him_sml        hsim
12:44:57 (snpslmd) hsim-cosim    hsim-xl        hspice
12:44:57 (snpslmd) hspice-XO    hspice3des    hspice_adv
12:44:57 (snpslmd) hspice_cosim    hspice_gui    hspice_mt
12:44:57 (snpslmd) hspice_pack    hspice_rf    hspice_rf_char
12:44:57 (snpslmd) hspicecmidev    hspicecmirt    hspicemt
12:44:57 (snpslmd) hspicerf    hspiceva    hspicewin
12:44:57 (snpslmd) hspicext    hsptest        hspui
12:44:57 (snpslmd) ficdr_test    ficdr_test/gds    ficdr_test/goa
12:44:57 (snpslmd) ficdr_test/io    ficdr_test/nc    ficdr_test/poly
12:44:57 (snpslmd) ficdr_test/size ficdr_test/sizeOr ficdr_test/stmp
12:44:57 (snpslmd) ficdr_test/tio    fpc_foundation    fpc_pna
12:44:57 (snpslmd) fpc_special1    fpc_special2    fpc_special3
12:44:57 (snpslmd) fpc_utils    emw        emw-farfield
12:44:57 (snpslmd) emw-farfield_all emw-farfield_ise emw-farfield_ise_all
12:44:57 (snpslmd) emw-nonuniform-2d_all emw-nonuniform-3d emw-nonuniform-3d_all
12:44:57 (snpslmd) emw-nonuniform-3d_ise emw-nonuniform-3d_ise_all emw-sdevice
12:44:57 (snpslmd) emw-sdevice_all emw-sdevice_ise emw-sdevice_ise_all
12:44:57 (snpslmd) emw-static    emw-static_all    emw-static_ise
12:44:57 (snpslmd) emw-static_ise_all emw-thermal    emw-thermal_all
12:44:57 (snpslmd) emw-thermal_ise emw-thermal_ise_all emw-uniform-2d_all
12:44:57 (snpslmd) emw-uniform-3d    emw-uniform-3d_all emw-uniform-3d_ise
12:44:57 (snpslmd) emw-uniform-3d_ise_all emw_all        emw_ise
12:44:57 (snpslmd) emw_ise_all    c_exe_ax    c_exe_cbx
12:44:57 (snpslmd) c_exe_drc    c_exe_gx    c_exe_ipc
12:44:57 (snpslmd) c_exe_lvs    cmod        cmod/ax
12:44:57 (snpslmd) cmod/cbx    cmod/drc    cmod/gx
12:44:57 (snpslmd) cmod/gxadv    cmod/hdrc    cmod/hlvs
12:44:57 (snpslmd) cmod/ipc    cmod/lvs    cmod/viewer
12:44:57 (snpslmd) coreAssembler    coreBuilder    coreConsultant
12:44:57 (snpslmd) coreSynthesis    coremill    cosmos_other
12:44:57 (snpslmd) ace_core    acega        acehdl
12:44:57 (snpslmd) acehdl/beta_status acehdl/internal_use acehdl_beta
12:44:57 (snpslmd) acehdl_gui    alien2lig    alien2lig_all
12:44:57 (snpslmd) alien2lig_ise    alien2lig_ise_all amat-calib
12:44:57 (snpslmd) amat-calib_all    amat-calib_ise    amat-calib_ise_all
12:44:57 (snpslmd) amplify        amplifyasic    amplifyissp
12:44:57 (snpslmd) amplifyrapidchip amps        amps/cso
12:44:57 (snpslmd) amps/pfx    amps/tr        arc
12:44:57 (snpslmd) arc/bcx        arc/c2x        arc/c3x
12:44:57 (snpslmd) arc/cns        arc/dnx        arc/dpx
12:44:57 (snpslmd) arc/gds2    arc/giper    arc/lefdef
12:44:57 (snpslmd) arc/ppx        arc/pro        arc/r3x
12:44:57 (snpslmd) arc1        arc2        arcexpert
12:44:57 (snpslmd) arcfc        arcviewer    arcviewer/raph
12:44:57 (snpslmd) arcxl        XC3000        XC4000
12:44:57 (snpslmd) XC4000E        XC4000EX    XC4000L
12:44:57 (snpslmd) XC4000XL    XC4000XLA    XC4000XV
12:44:57 (snpslmd) XC5200        XC9500        XC9500XL
12:44:57 (snpslmd) XC9500XV    XVCSDebugger    XVCSiDebugger
12:44:57 (snpslmd) XVVCDebugger    WF_API_HSPICE    WF_API_HSPICE_MEMSSE
12:44:57 (snpslmd) WF_API_MEMSSE    WF_API_STARSIM    WF_API_STARSIM_MEMSSE
12:44:57 (snpslmd) VT_64Bit    VT_AssertionIP    VT_Assertions
12:44:57 (snpslmd) VT_AssertionsRuntime VT_CBUG        VT_Coverage
12:44:57 (snpslmd) VT_CoverageRuntime VT_CoverageURG    VT_DVE
12:44:57 (snpslmd) VT_DVENTB    VT_DVE_COV    VT_LCA_Assertions
12:44:57 (snpslmd) VT_LCA_Coverage VT_LCA_DEBUG    VT_LCA_Language
12:44:57 (snpslmd) VT_LCA_MixedSignal VT_LCA_Testbench VT_NTB
12:44:57 (snpslmd) VT_NativeTBDebuggerGui VT_NativeTestbench VT_OtherTechnology
12:44:57 (snpslmd) VT_PVCSCompiler_Net VT_Pioneer    VT_SDebug
12:44:57 (snpslmd) VT_SVAssertionCompiler VT_SVAssertions VT_SVDesign
12:44:57 (snpslmd) VT_SVTestbench    VT_SYSTEMC21    VT_SystemVerilog
12:44:57 (snpslmd) VT_Testbench    VT_TestbenchRuntime VT_UCLI
12:44:57 (snpslmd) VT_UnifiedCoverage VT_VCS_Advanced_INCREMENTs VT_VCS_BETA_INCREMENTs
12:44:57 (snpslmd) VT_VCS_BETA_Program VT_VCS_Checker    VT_VCS_Echo
12:44:57 (snpslmd) VT_VCS_LCA_INCREMENTs VT_VCS_NTBE    VT_VCS_Power_Management
12:44:57 (snpslmd) VT_Visual    Vera        Verilog
12:44:57 (snpslmd) Verilog-Netlist-Writer Verilog-Parser    Verilog-To-BE
12:44:57 (snpslmd) Verilog-VirSim    Vivace-Code-Generator Vivace-Core
12:44:57 (snpslmd) Vivace-Debug    Vivace-Elaborator Vivace-Expert
12:44:57 (snpslmd) Vivace-Express    Vivace-GUI    Vivace-HDL-Analyzer
12:44:57 (snpslmd) Vivace-Model-Compiler Vivace-Pro    Vivace-Simulator
12:44:57 (snpslmd) Vivace-VHDL-Analyzer VDesktop-Debug    VDesktop-GUI
12:44:57 (snpslmd) VDesktop-VCDTrans VDesktop-VHDL    VDesktop-Verilog
12:44:57 (snpslmd) VEHICLE_ELECTRIC_LIB VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY
12:44:57 (snpslmd) VENDOR_LIBRARY_MEMSSE VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR
12:44:57 (snpslmd) VHDL-Analyzer    VHDL-Compiler    VHDL-Compiler-Old
12:44:57 (snpslmd) VHDL-Compiler-Presto VHDL-Cycle-Sim    VHDL-Elaborator
12:44:57 (snpslmd) VHDL-Event-Sim    VHDL-Netlist-Writer VHDL-ScSim
12:44:57 (snpslmd) VHDL-To-BE    VHDL-Tools    VHDL-VirSim
12:44:57 (snpslmd) VHDLAMS_TAURI    VHDLAMS_TAURILI VHDLi-Elaborator
12:44:57 (snpslmd) VHDLi-Event-Sim VHMC-Eval    VHMC-GenUnlocked
12:44:57 (snpslmd) VHMC-Runtime    VIEWLOGIC_FRAMEWAY VIEWLOGIC_FRAMEWAY_MEMSSE
12:44:57 (snpslmd) VIEWLOGIC_NET    VIEWLOGIC_NET_MEMSSE VIRTEX
12:44:57 (snpslmd) VIRTEX2        VIRTEX2P    VIRTEXE
12:44:57 (snpslmd) VIRTEXEA    VMCCompiler    VMCCompiler_Net
12:44:57 (snpslmd) VMCCompiler_Node VMCCore        VMCEvaluation
12:44:57 (snpslmd) VMCEvaluation_Net VMCEvaluation_Node VMCExpress_Compiler
12:44:57 (snpslmd) VMCExpress_Compiler_Net VMCExpress_Compiler_Node VMCGeneratorUnlocked
12:44:57 (snpslmd) VMCGeneratorUnlocked_Net VMCGeneratorUnlocked_Node VMCRuntime
12:44:57 (snpslmd) VMCRuntime_Net    VMCRuntime_Node VSS-Analyzer
12:44:57 (snpslmd) VSS-Backplane    VSS-CLI        VSS-Cadence-Interface
12:44:57 (snpslmd) VSS-CompiledSim VSS-Debugger    VSS-Falcon-Interface
12:44:57 (snpslmd) VSS-GateSim    VSS-LAI-Models    VSS-LMSI
12:44:57 (snpslmd) VSS-Lib-Tools    VSS-Model-Developer VSS-NEC-Tran
12:44:57 (snpslmd) VSS-SDF-Interface VSS-SGE-Tool    VSS-SPC
12:44:57 (snpslmd) VSS-Simulator    VSS-SmartModels VSS-Tran
12:44:57 (snpslmd) VSS-Utilities    VSS-VIP-Interface VSS-Verilog-PLI
12:44:57 (snpslmd) VSS-Wave-Display VSS-XP-Accelerator VCS-Express-Compile
12:44:57 (snpslmd) VCS-Express-Runtime VCS-VERIFICATION-LIBRARY VCSAMSCompiler
12:44:57 (snpslmd) VCSAMSCompiler_Net VCSAMSRuntime    VCSAMSRuntime_Net
12:44:57 (snpslmd) VCSCompile    VCSCompile_Net    VCSCompile_Node
12:44:57 (snpslmd) VCSCompiler    VCSCompiler_Net VCSCompiler_Node
12:44:57 (snpslmd) VCSDebugger    VCSDebugger_Net VCSDebugger_Node
12:44:57 (snpslmd) VCSMXRunTime_Net VCSMXiRunTime_Net VCSNativeCode
12:44:57 (snpslmd) VCSNativeCode_Net VCSNativeCode_Node VCSOldPostProcDebugger_Net
12:44:57 (snpslmd) VCSOldPostProcDebugger_Node VCSParallelCompiler VCSParallelCompiler_Net
12:44:57 (snpslmd) VCSParallelCompiler_Node VCSParallelRuntime VCSParallelRuntime_Net
12:44:57 (snpslmd) VCSParallelRuntime_Node VCSParallelThread VCSParallelThread_Net
12:44:57 (snpslmd) VCSParallelThread_Node VCSPostProcDebugger VCSPostProcDebugger_Net
12:44:57 (snpslmd) VCSPostProcDebugger_Node VCSRuntime    VCSRuntimeLimited
12:44:57 (snpslmd) VCSRuntimeLimited_Net VCSRuntimeLimited_Node VCSRuntime_Net
12:44:57 (snpslmd) VCSRuntime_Node VCSStd        VCSStd_Net
12:44:57 (snpslmd) VCSStd_Node    VCSTools    VCSTools_Net
12:44:57 (snpslmd) VCSTools_Node    VCSiCompile    VCSiCompile_Net
12:44:57 (snpslmd) VCSiCompile_Node VCSiCompiler    VCSiCompiler_Net
12:44:57 (snpslmd) VCSiCompiler_Node VCSiDebugger    VCSiDebugger_Net
12:44:57 (snpslmd) VCSiDebugger_Node VCSiRuntime    VCSiRuntimeLimited
12:44:57 (snpslmd) VCSiRuntimeLimited_Net VCSiRuntimeLimited_Node VCSiRuntime_Net
12:44:57 (snpslmd) VCSiRuntime_Net(3) VCSiRuntime_Node VCSlm_Hm
12:44:57 (snpslmd) VCSlm_Hm_Net    VCSlm_Hm_Node    TBM-Manager-UI
12:44:57 (snpslmd) TBM-VSS-Check    TDL-Interface    TDL-Reader
12:44:57 (snpslmd) TDL-Writer    TESTIFY        TESTIFY_MEMSSE
12:44:57 (snpslmd) TESTIFY_NETLISTER TESTIFY_NETLISTER_MEMSSE THERM_TOOL
12:44:57 (snpslmd) THERM_TOOL_MEMSSE TLU_TOOL    TLU_TOOL_MEMSSE
12:44:57 (snpslmd) TR_ANALYSIS    TR_ANALYSIS_MEMSSE Tdx
12:44:57 (snpslmd) Tdx_all        Tdx_ise        Tdx_ise_all
12:44:57 (snpslmd) Tecplot        TecplotSmall_all Tecplot_all
12:44:57 (snpslmd) Tecplot_ise    Tecplot_ise_all Ted
12:44:57 (snpslmd) TedSmall_all    Ted_all        Ted_ise
12:44:57 (snpslmd) Ted_ise_all    Test-ATPG    Test-ATPG-30
12:44:57 (snpslmd) Test-ATPG-Limited Test-ATPG-Max    Test-ATPG-PRO
12:44:57 (snpslmd) Test-ATPG-Ultra Test-ATPG-XP    Test-Accelerate-Max
12:44:57 (snpslmd) Test-Accelerator Test-Analysis    Test-Analysis-GUI
12:44:57 (snpslmd) Test-Analysis-RTL Test-BIST    Test-BSDL
12:44:57 (snpslmd) Test-Beta    Test-Beta-2    Test-Beta-3
12:44:57 (snpslmd) Test-Beta-4    Test-Beta-5    Test-Beta-6
12:44:57 (snpslmd) Test-Beta-7    Test-Beta-8    Test-Beta-9
12:44:57 (snpslmd) Test-CA        Test-CA-2    Test-CA-3
12:44:57 (snpslmd) Test-CA-4    Test-CTL-Model    Test-Compile
12:44:57 (snpslmd) Test-Compile-Max Test-Compile-Remodel Test-Compile-Share
12:44:57 (snpslmd) Test-Compiler    Test-Compiler-Plus Test-Compiler-Remodel
12:44:57 (snpslmd) Test-Compression-ATPG Test-Compression-Synthesis Test-CompressionPlus-ATPG
12:44:57 (snpslmd) Test-CompressionPlus-Syn Test-Core-Integration Test-Core-Wrapper
12:44:57 (snpslmd) Test-Custom-Protocols Test-DFT-Top    Test-DFTC-TMAX
12:44:57 (snpslmd) Test-Delay    Test-Diagnosis    Test-Eval
12:44:57 (snpslmd) Test-Fault-Max    Test-Faultsim    Test-Faultsim-8L
12:44:57 (snpslmd) Test-Format    Test-IDDQ    Test-IEEE-Std-1149-1
12:44:57 (snpslmd) Test-LBIST-ATPG Test-LBIST-Integration Test-LBIST-Synthesis
12:44:57 (snpslmd) Test-Library    Test-MBIST-Integration Test-Map
12:44:57 (snpslmd) Test-Mbist    Test-Mbist-Algorithm Test-Mbist-Bitstream
12:44:57 (snpslmd) Test-Mbist-CAM    Test-Mbist-DRAM Test-Mbist-Diagnosis
12:44:57 (snpslmd) Test-Mbist-FLASH Test-Mbist-Multiport Test-Mbist-Program
12:44:57 (snpslmd) Test-PR-1    Test-PR-2    Test-PR-3
12:44:57 (snpslmd) Test-PR-4    Test-Physical    Test-Power
12:44:57 (snpslmd) Test-RTL-Check    Test-RTL-Tristate Test-SDD-Timing
12:44:57 (snpslmd) Test-STDVR    Test-ScanRoute    Test-Validate
12:44:57 (snpslmd) TestDesignCorrelation TestManager    TestSim
12:44:57 (snpslmd) TestVE        SNPS-Assertions SNPS-CSL
12:44:57 (snpslmd) SNPS-Keygen    SNPS-MOTIVE    SPARTAN
12:44:57 (snpslmd) SPARTAN2    SPARTAN2E    SPARTANXL
12:44:57 (snpslmd) SPECTRAL    SPECTRAL_MEMSSE STAR-ASCII
12:44:57 (snpslmd) STAR-CR        STAR-DC        STAR-EX
12:44:57 (snpslmd) STAR-EX_ERC    STAR-FILTER    STAR-GAZER
12:44:57 (snpslmd) STAR-LD2LTL    STAR-R        STAR-R-GUI
12:44:57 (snpslmd) STAR-RC        STAR-RC-GUI    STAR-RC2
12:44:57 (snpslmd) STAR-RC2-AEO    STAR-RC2-ANAL    STAR-RC2-ASCII
12:44:57 (snpslmd) STAR-RC2-CLOCK    STAR-RC2-DB    STAR-RC2-DEBUG
12:44:57 (snpslmd) STAR-RC2-DISTRIB10 STAR-RC2-GUI    STAR-RC2-NETLIST
12:44:57 (snpslmd) STAR-RC2-PROBER STAR-RC2-TCAD    STAR-RC2-VIEWER
12:44:57 (snpslmd) STAR-RC2-XSTOR1 STAR-RC2-XSTOR2 STAR-RC2-XTR-AEO
12:44:57 (snpslmd) STAR-RC2-XTRACT STAR-RC2_MANAGER STAR-SYN2STAR
12:44:57 (snpslmd) STAR-TCAD    STAR-XREF    SYMLIB
12:44:57 (snpslmd) SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE SYMLIB_MEMSSE
12:44:57 (snpslmd) SYMLIB_PLUS    SYMLIB_PLUS_MEMSSE SYMLIB_POWER
12:44:57 (snpslmd) SYMLIB_POWER_MEMSSE ShortCut-DC-Expert ShortCut-DC-Pro
12:44:57 (snpslmd) Shortcut-FPGA    SynLib-ALU    SynLib-AdvMath
12:44:57 (snpslmd) SynLib-Control    SynLib-DSPFIR    SynLib-Eval
12:44:57 (snpslmd) SynLib-FltTol    SynLib-PCIbasic SynLib-Seq
12:44:57 (snpslmd) SynLib-VHDLSimMdl SynLib-VerilogSimMdl Synopsys
12:44:57 (snpslmd) Synopsys-Queue    Synopsys-Release Synopsys_VCS_cmv
12:44:57 (snpslmd) SK_sdevice    SK_sdevice-3d    SK_sdevice-3d_all
12:44:57 (snpslmd) SK_sdevice-densitygrad SK_sdevice-densitygrad_all SK_sdevice-ferro
12:44:57 (snpslmd) SK_sdevice-ferro_all SK_sdevice-floatinggate SK_sdevice-floatinggate_all
12:44:57 (snpslmd) SK_sdevice-gateleakage SK_sdevice-gateleakage_all SK_sdevice-hetero
12:44:57 (snpslmd) SK_sdevice-hetero_all SK_sdevice-hydro SK_sdevice-hydro_all
12:44:57 (snpslmd) SK_sdevice-kpgain SK_sdevice-kpgain_all SK_sdevice-laser
12:44:57 (snpslmd) SK_sdevice-laser_all SK_sdevice-led    SK_sdevice-led_all
12:44:57 (snpslmd) SK_sdevice-mixedmode SK_sdevice-mixedmode_all SK_sdevice-montecarlo
12:44:57 (snpslmd) SK_sdevice-montecarlo_all SK_sdevice-noise SK_sdevice-noise_all
12:44:57 (snpslmd) SK_sdevice-optic SK_sdevice-optic_all SK_sdevice-parallel
12:44:57 (snpslmd) SK_sdevice-parallel4 SK_sdevice-parallel4_all SK_sdevice-parallel_all
12:44:57 (snpslmd) SK_sdevice-pmi    SK_sdevice-pmi_all SK_sdevice-radiation
12:44:57 (snpslmd) SK_sdevice-radiation_all SK_sdevice-reliability SK_sdevice-reliability_all
12:44:57 (snpslmd) SK_sdevice-schroedinger SK_sdevice-schroedinger_all SK_sdevice-sige
12:44:57 (snpslmd) SK_sdevice-sige_all SK_sdevice-thermo SK_sdevice-thermo_all
12:44:57 (snpslmd) SK_sdevice-traps SK_sdevice-traps_all SK_sdevice-vectoroptic
12:44:57 (snpslmd) SK_sdevice-vectoroptic_all SK_sdevice_all    SK_sdevicemonosemicond
12:44:57 (snpslmd) SK_sdevicemonosemicond_all SK_sparallel    SK_sparallel_all
12:44:57 (snpslmd) SK_spcmlib    SK_spcmlib_all    SK_spcmstd
12:44:57 (snpslmd) SK_spcmstd_all    SK_spcmtcl    SK_spcmtcl_all
12:44:57 (snpslmd) SK_sprocess    SK_sprocess-an-imp3d SK_sprocess-an-imp3d_all
12:44:57 (snpslmd) SK_sprocess2d    SK_sprocess2d_all SK_sprocess2dmc
12:44:57 (snpslmd) SK_sprocess2dmc_all SK_sprocess3d    SK_sprocess3d_all
12:44:57 (snpslmd) SK_sprocess3dmc SK_sprocess3dmc_all SK_sprocess_all
12:44:57 (snpslmd) SK_sprocessmc    SK_sprocessmc_all SK_sup2lig
12:44:57 (snpslmd) SK_sup2lig_all    SK_swb        SK_swb-advanced
12:44:57 (snpslmd) SK_swb-advanced_all SK_swb_all    SK_vsea-calib
12:44:57 (snpslmd) SK_vsea-calib_all SK_Devise    SK_Devise-3D
12:44:57 (snpslmd) SK_Devise-3D_all SK_Devise_all    SK_Dfisetools
12:44:57 (snpslmd) SK_Dfisetools_all SK_Dip        SK_Dip_all
12:44:57 (snpslmd) SK_Emlab    SK_Emlab-Dessis SK_Emlab-Dessis_all
12:44:57 (snpslmd) SK_Emlab-Farfield SK_Emlab-Farfield_all SK_Emlab-Nonuniform-2D
12:44:57 (snpslmd) SK_Emlab-Nonuniform-2D_all SK_Emlab-Nonuniform-3D SK_Emlab-Nonuniform-3D_all
12:44:57 (snpslmd) SK_Emlab-Static SK_Emlab-Static_all SK_Emlab-Thermal
12:44:57 (snpslmd) SK_Emlab-Thermal_all SK_Emlab-Uniform-2D SK_Emlab-Uniform-2D_all
12:44:57 (snpslmd) SK_Emlab-Uniform-3D SK_Emlab-Uniform-3D_all SK_Emlab_all
12:44:57 (snpslmd) SK_Floops-1D    SK_Floops-1D-MC SK_Floops-1D-MC_all
12:44:57 (snpslmd) SK_Floops-1D_all SK_Floops-2D    SK_Floops-2D-MC
12:44:57 (snpslmd) SK_Floops-2D-MC_all SK_Floops-2D_all SK_Floops-3D
12:44:57 (snpslmd) SK_Floops-3D-MC SK_Floops-3D-MC_all SK_Floops-3D_all
12:44:57 (snpslmd) SK_GENESISe    SK_GENESISe_all SK_Inspect
12:44:57 (snpslmd) SK_Inspect_all    SK_Ligament    SK_LigamentFE
12:44:57 (snpslmd) SK_LigamentFE_all SK_Ligament_all SK_Mesh1D
12:44:57 (snpslmd) SK_Mesh1D_all    SK_Mesh2D    SK_Mesh2D_all
12:44:57 (snpslmd) SK_Mesh3D    SK_Mesh3D_all    SK_Noffset-2D
12:44:57 (snpslmd) SK_Noffset-2D_all SK_Noffset-3D    SK_Noffset-3D_all
12:44:57 (snpslmd) SK_OptimISE-DOE SK_OptimISE-DOE_all SK_OptimISE-Iterative
12:44:57 (snpslmd) SK_OptimISE-Iterative_all SK_OptimISE-RSMOpt SK_OptimISE-RSMOpt_all
12:44:57 (snpslmd) SK_OptimISE-Statistical SK_OptimISE-Statistical_all SK_ProcessExplorer
12:44:57 (snpslmd) SK_ProcessExplorer_all SK_Prolyt    SK_Prolyt_all
12:44:57 (snpslmd) SK_Tdx        SK_Tdx_all    SK_Tecplot
12:44:57 (snpslmd) SK_Tecplot_all    SK_Ted        SK_Ted_all
12:44:57 (snpslmd) SK_alien2lig    SK_alien2lig_all SK_amat-calib
12:44:57 (snpslmd) SK_amat-calib_all SK_emw        SK_emw-farfield
12:44:57 (snpslmd) SK_emw-farfield_all SK_emw-nonuniform-3d SK_emw-nonuniform-3d_all
12:44:57 (snpslmd) SK_emw-sdevice    SK_emw-sdevice_all SK_emw-static
12:44:57 (snpslmd) SK_emw-static_all SK_emw-thermal    SK_emw-thermal_all
12:44:57 (snpslmd) SK_emw-uniform-3d SK_emw-uniform-3d_all SK_emw_all
12:44:57 (snpslmd) SK_sde        SK_sde3d    SK_sde3d_all
12:44:57 (snpslmd) SK_sde_all    SK_AN-Impl3D    SK_AN-Impl3D_all
12:44:57 (snpslmd) SK_Dessis    SK_Dessis-3D    SK_Dessis-3D_all
12:44:57 (snpslmd) SK_Dessis-DensityGrad SK_Dessis-DensityGrad_all SK_Dessis-Ferro
12:44:57 (snpslmd) SK_Dessis-Ferro_all SK_Dessis-FloatingGate SK_Dessis-FloatingGate_all
12:44:57 (snpslmd) SK_Dessis-GateLeakage SK_Dessis-GateLeakage_all SK_Dessis-Hetero
12:44:57 (snpslmd) SK_Dessis-Hetero_all SK_Dessis-Hydro SK_Dessis-Hydro_all
12:44:57 (snpslmd) SK_Dessis-LED    SK_Dessis-LED_all SK_Dessis-Laser
12:44:57 (snpslmd) SK_Dessis-Laser_all SK_Dessis-MixedMode SK_Dessis-MixedMode_all
12:44:57 (snpslmd) SK_Dessis-Mono-Semicond SK_Dessis-Mono-Semicond_all SK_Dessis-MonteCarlo
12:44:57 (snpslmd) SK_Dessis-MonteCarlo_all SK_Dessis-Noise SK_Dessis-Noise_all
12:44:57 (snpslmd) SK_Dessis-Optic SK_Dessis-Optic_all SK_Dessis-PMI
12:44:57 (snpslmd) SK_Dessis-PMI_all SK_Dessis-Parallel SK_Dessis-Parallel4
12:44:57 (snpslmd) SK_Dessis-Parallel4_all SK_Dessis-Parallel_all SK_Dessis-Radiation
12:44:57 (snpslmd) SK_Dessis-Radiation_all SK_Dessis-Reliability SK_Dessis-Reliability_all
12:44:57 (snpslmd) SK_Dessis-Schroedinger SK_Dessis-Schroedinger_all SK_Dessis-SiGe
12:44:57 (snpslmd) SK_Dessis-SiGe_all SK_Dessis-Thermo SK_Dessis-Thermo_all
12:44:57 (snpslmd) SK_Dessis-Traps SK_Dessis-Traps_all SK_Dessis-VectorOptic
12:44:57 (snpslmd) SK_Dessis-VectorOptic_all SK_Dessis-kpGain SK_Dessis-kpGain_all
12:44:57 (snpslmd) SK_Dessis_all    SABERRT_ADI    SABERRT_ADI_MEMSSE
12:44:57 (snpslmd) SABERRT_AP2633    SABERRT_FE    SABERRT_FE_MEMSSE
12:44:57 (snpslmd) SABERRT_HIL    SABERRT_HIL_MEMSSE SABER_BUNDLE
12:44:57 (snpslmd) SABER_DEV_MM    SABER_DEV_MMP    SABER_GUIDE
12:44:57 (snpslmd) SABER_GUIDE_MEMSSE SABER_HARNESS    SABER_HARNESS_NETLISTER
12:44:57 (snpslmd) SABER_IF    SABER_INTERFACE SABER_INTERFACE_MEMSSE
12:44:57 (snpslmd) SABER_LEAPFROG_MM SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM
12:44:57 (snpslmd) SABER_MODELSIM_PLUS_MM_MEMSSE SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE
12:44:57 (snpslmd) SABER_MODELSIM_VLOG_MM SABER_PLUGNSIM_MM SABER_QSIM_MM
12:44:57 (snpslmd) SABER_QVSPRO_MM SABER_RT_MM    SABER_RT_MM_MEMSSE
12:44:57 (snpslmd) SABER_RUNTIME    SABER_SCOPE    SABER_SCOPE_MEMSSE
12:44:57 (snpslmd) SABER_SCOPE_NETLIST SABER_SIMMATRIX_MM SABER_SIMULATOR
12:44:57 (snpslmd) SABER_SIMULATOR_MEMSSE SABER_SKETCH    SABER_SKETCH_MEMSSE
12:44:57 (snpslmd) SABER_SKETCH_NETLIST SABER_SKETCH_NETLISTER SABER_SKETCH_NETLISTER_MEMSSE
12:44:57 (snpslmd) SABER_TSP    SABER_VERILOG_MM SABER_VERILOG_MM_MEMSSE
12:44:57 (snpslmd) SABER_VHDLAMS    SABER_VHDLAMS_MEMSSE SABER_VIEWSIM_MM
12:44:57 (snpslmd) SABER_VIEWSIM_MM_MEMSSE SC-BC        SC-COSIM
12:44:57 (snpslmd) SC-FPGA        SC-HLS        SC-KAZAM
12:44:57 (snpslmd) SC-RTL        SCAN_TOOL    SCAN_TOOL_MEMSSE
12:44:57 (snpslmd) SENSITIVITY    SENSITIVITY_MEMSSE SGE-DC-Interface
12:44:57 (snpslmd) SGE-EDIF-Interface SGE-Tool    SGE-VHDL-Interface
12:44:57 (snpslmd) SGE-Verilog-Interface PhysOpt        PhysOpt-Beta
12:44:57 (snpslmd) PhysOpt-Beta-CTS PhysOpt-Beta-Milkyway PhysOpt-Beta-Route
12:44:57 (snpslmd) PhysOpt-Beta-SI PhysOpt-ClockTree PhysOpt-Extraction
12:44:57 (snpslmd) PhysOpt-GUI    PhysOpt-Hierarchy PhysOpt-Integration
12:44:57 (snpslmd) PhysOpt-MV    PhysOpt-Onroute PhysOpt-Parallel
12:44:57 (snpslmd) PhysOpt-Route    PhysOpt-Route-TD PhysOpt-Routing
12:44:57 (snpslmd) PhysOpt-SI    PhysOpt-Ultra    PhysOpt-VH
12:44:57 (snpslmd) PhysOpt-XG    PlanetPL    PlanetRTL
12:44:57 (snpslmd) Power-Analysis    Power-Optimization Power-Optimization-Beta1
12:44:57 (snpslmd) Power-Optimization-Beta2 Power-Optimization-Upgrade PrimeRail
12:44:57 (snpslmd) PrimeRail-New-Technology PrimeRail-adv    PrimeRail-static
12:44:57 (snpslmd) PrimeTime    PrimeTime-New-Technology PrimeTime-PX
12:44:57 (snpslmd) PrimeTime-PX-New-Technology PrimeTime-PX-Statistical PrimeTime-Plus
12:44:57 (snpslmd) PrimeTime-SI    PrimeTime-VX    PrimeTime_gui
12:44:57 (snpslmd) ProMA-L1    ProMA-L2    ProMA-LD
12:44:57 (snpslmd) ProMA-P1    ProMA-P2    ProMA-PD
12:44:57 (snpslmd) ProcessExplorer ProcessExplorer_all ProcessExplorer_ise
12:44:57 (snpslmd) ProcessExplorer_ise_all Prolyt        Prolyt_all
12:44:57 (snpslmd) Prolyt_ise    Prolyt_ise_all    Protocol-Compiler-Analysis
12:44:57 (snpslmd) Protocol-Compiler-COutput Protocol-Compiler-FML Protocol-Compiler-Synth
12:44:57 (snpslmd) Protocol-Compiler-UI PsynGui-AARender PsynGui-ChipMap
12:44:57 (snpslmd) RTL-Analyzer    RTL-Analyzer-DAP RTL-Analyzer-Shell
12:44:57 (snpslmd) RTL-Analyzer-Shell-DAP RTL-Power-Analysis OPT_TEMPLATE_LIB
12:44:57 (snpslmd) OPT_TEMPLATE_LIB_MEMSSE ORCA2A        ORCA2TB
12:44:57 (snpslmd) ORCA3C        ORCA3FPSC    ORCA3L
12:44:57 (snpslmd) ORCA4E        OptimISE-DOE    OptimISE-DOE_all
12:44:57 (snpslmd) OptimISE-DOE_ise OptimISE-DOE_ise_all OptimISE-Iterative
12:44:57 (snpslmd) OptimISE-Iterative_all OptimISE-Iterative_ise OptimISE-Iterative_ise_all
12:44:57 (snpslmd) OptimISE-RSMOpt OptimISE-RSMOpt_all OptimISE-RSMOpt_ise
12:44:57 (snpslmd) OptimISE-RSMOpt_ise_all OptimISE-Statistical OptimISE-Statistical_all
12:44:57 (snpslmd) OptimISE-Statistical_ise OptimISE-Statistical_ise_all NanoTime
12:44:57 (snpslmd) NanoTime-PathMill-Shared NanoTime-ultra    Noffset-2D
12:44:57 (snpslmd) Noffset-2D_all    Noffset-2D_ise    Noffset-2D_ise_all
12:44:57 (snpslmd) Noffset-3D    Noffset-3D_all    Noffset-3D_ise
12:44:57 (snpslmd) Noffset-3D_ise_all MACH1        MACH2
12:44:57 (snpslmd) MACH3        MACH4        MACH5
12:44:57 (snpslmd) MAX3000A    MAX7000        MAX7000A
12:44:57 (snpslmd) MAX7000AE    MAX7000B    MAX7000E
12:44:57 (snpslmd) MAX7000S    MAX9000        MC-Pro
12:44:57 (snpslmd) MC-Pro-RP    MC-Retime    MCE
12:44:57 (snpslmd) MCE-Base    MCE-Eval    MCE-Lib-ALU
12:44:57 (snpslmd) MCE-Lib-Arith1    MCE-Lib-Arith2    MCE-Lib-Arith3
12:44:57 (snpslmd) MCE-Lib-Logic    MDAM        MDCA
12:44:57 (snpslmd) MDHJ        MDLT        MDOD
12:44:57 (snpslmd) MDPD        MDTC        MICROCOSM_LIB
12:44:57 (snpslmd) MICROCOSM_LIB2    MICROCOSM_LIB2_MEMSSE MICROCOSM_LIB3
12:44:57 (snpslmd) MICROCOSM_LIB3_MEMSSE MICROCOSM_LIB4    MICROCOSM_LIB4_MEMSSE
12:44:57 (snpslmd) MICROCOSM_LIB5    MICROCOSM_LIB5_MEMSSE MICROCOSM_LIB6
12:44:57 (snpslmd) MICROCOSM_LIB6_MEMSSE MICROCOSM_LIB7    MICROCOSM_LIB7_MEMSSE
12:44:57 (snpslmd) MICROCOSM_LIB_MEMSSE MIF-Reader    MIF-Writer
12:44:57 (snpslmd) MODEL_ARCHITECT MODEL_ENCRYPTION MODEL_ENCRYPTION_MEMSSE
12:44:57 (snpslmd) MODEL_SYNTHESIS MODEL_SYNTHESIS_MEMSSE MODPEX
12:44:57 (snpslmd) MODPEX_AQUEDUCT MODPEX_ASIM    MODPEX_ATFT
12:44:57 (snpslmd) MODPEX_AWB    MODPEX_CTC    MODPEX_ELDO
12:44:57 (snpslmd) MODPEX_MARELLI    MODPEX_NOPOWER    MODPEX_PTFT
12:44:57 (snpslmd) MODPEX_SABER    MODPEX_STATIS    MODPEX_TVS
12:44:57 (snpslmd) MONTE_CARLO    MONTE_CARLO_MEMSSE MOS_TOOL
12:44:57 (snpslmd) MOS_TOOL_MEMSSE MOTIVE-PrimeTime MOTOR_DCPM_TOOL
12:44:57 (snpslmd) MOTOR_DCPM_TOOL_MEMSSE MV-Astro-Opt    MV-Opt
12:44:57 (snpslmd) MVerilog    MWAPIaccess    MWAPIdev
12:44:57 (snpslmd) Magellan    Magellan-Shell    Magellan-Sim
12:44:57 (snpslmd) Magellan-TB    Mesh1D        Mesh1D_all
12:44:57 (snpslmd) Mesh1D_ise    Mesh1D_ise_all    Mesh2D
12:44:57 (snpslmd) Mesh2D_all    Mesh2D_ise    Mesh2D_ise_all
12:44:57 (snpslmd) Mesh3D        Mesh3D_all    Mesh3D_ise
12:44:57 (snpslmd) Mesh3D_ise_all    Millennium-ATPG-EE Millennium-ATPG-STD
12:44:57 (snpslmd) Millennium-Beta Millennium-DRC    Millennium-Eval
12:44:57 (snpslmd) Millennium-FS    Mixed-Language    Mixed-Paradigm
12:44:57 (snpslmd) LINK_MATLAB    LINK_MATLAB_MEMSSE LINK_XMATH
12:44:57 (snpslmd) LMCSwift    LMCSwift_Net    LMCSwift_Node
12:44:57 (snpslmd) LOAD_TOOL    LOAD_TOOL_MEMSSE LTL-100
12:44:57 (snpslmd) LTL-100_CIF    LTL-100_GDS    LTL-100_NDW
12:44:57 (snpslmd) LTX_LIBRARY    Laker_AMS    Laker_L1
12:44:57 (snpslmd) Laker_L2    Laker_L3    Laker_T1
12:44:57 (snpslmd) Laker_T1_LE    Laker_Viewer    Laker_iDRC
12:44:57 (snpslmd) Laker_iLVS    Ligament    LigamentFE
12:44:57 (snpslmd) LigamentFE_all    LigamentFE_ise    LigamentFE_ise_all
12:44:57 (snpslmd) Ligament_all    Ligament_ise    Ligament_ise_all
12:44:57 (snpslmd) JUAOPAS        JUAPlan        JUATime
12:44:57 (snpslmd) JUAUD        JUAdvOptA    JUAdvOptB
12:44:57 (snpslmd) JUClock        JUDP        JUOPAS
12:44:57 (snpslmd) JUPlan        JUTime        JUUD
12:44:57 (snpslmd) JUVS        Jupiter        JupiterXT
12:44:57 (snpslmd) JupiterXT_VF    IQBUS_AUTHOR    IQBUS_AUTHOR_MEMSSE
12:44:57 (snpslmd) IQBUS_DESIGNER    IQBUS_LIB    IQBUS_LIB_MEMSSE
12:44:57 (snpslmd) Inspect        Inspect_all    Inspect_ise
12:44:57 (snpslmd) Inspect_ise_all Interface-Shell Interfise_all
12:44:57 (snpslmd) HARNESS_CATIA    HARNESS_MCADREAD HARNESS_PROCABLE
12:44:57 (snpslmd) HARNESS_UNIGRAPHICS HDL        HDL-Advisor
12:44:57 (snpslmd) HDL-Advisor-Estimator HDL-Advisor-Estimator-Package HDL-Advisor-Package
12:44:57 (snpslmd) HDL-Advisor-Shell HDL-Advisor-Shell-Estimator HDL-Advisor-Shell-Estm-Package
12:44:57 (snpslmd) HDL-Advisor-Shell-Package HDL-Compiler    HDL-Compiler-Old
12:44:57 (snpslmd) HDL-Compiler-SystemVerilog HDL2SC_mixed    HDL2SC_verilog
12:44:57 (snpslmd) HDL2SC_vhdl    HERCULES-CRYPT_XREF_DATA HERCULES-DISTRIBUTED
12:44:57 (snpslmd) HERCULES-DISTRIBUTED-2 HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4
12:44:57 (snpslmd) HERCULES-DISTRIBUTED-4 HERCULES-DP_MT    HERCULES-EXPLORER_DRC
12:44:57 (snpslmd) HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_LVS HERCULES-FINDSHORT
12:44:57 (snpslmd) HERCULES-NETLIST HERCULES-RUN_TRAN HERCULES_DEBUGGER
12:44:57 (snpslmd) HERCULES_DEVICE HERCULES_DRC    HERCULES_ERC
12:44:57 (snpslmd) HERCULES_HDRC    HERCULES_HDRC-HTML HERCULES_HERC-ADV
12:44:57 (snpslmd) HERCULES_HERC-BASIC HERCULES_HLPE    HERCULES_HLVS
12:44:57 (snpslmd) HERCULES_HLVS-DEBUG HERCULES_HLVS-HTML HERCULES_LVS
12:44:57 (snpslmd) HERCULES_MANAGER HERCULES_MASK    HERCULES_RCE
12:44:57 (snpslmd) HERCULES_VUE    GENESISe    GENESISe_all
12:44:57 (snpslmd) GENESISe_ise    GENESISe_ise_all Galaxy-AdvCTS
12:44:57 (snpslmd) Galaxy-AdvOpt    Galaxy-AdvRules Galaxy-AdvTech
12:44:57 (snpslmd) Galaxy-Beta    Galaxy-CCS    Galaxy-CTMesh
12:44:57 (snpslmd) Galaxy-Common    Galaxy-DFT    Galaxy-DFY
12:44:57 (snpslmd) Galaxy-FP    Galaxy-FP-AdvCTS Galaxy-FP-AdvTech
12:44:57 (snpslmd) Galaxy-FP-Hier    Galaxy-FP-MV    Galaxy-FlipChip
12:44:57 (snpslmd) Galaxy-GUI-PNR    Galaxy-GUI-PSYN Galaxy-ICC
12:44:57 (snpslmd) Galaxy-IU    Galaxy-Internal-Only Galaxy-MCMM
12:44:57 (snpslmd) Galaxy-MV    Galaxy-PNR    Galaxy-PSYN
12:44:57 (snpslmd) Galaxy-Power    Galaxy-Prototype Galaxy-SPG
12:44:57 (snpslmd) Galaxy-Zroute    Galaxy_FP_Beta    Galaxy_MultiRoute4
12:44:57 (snpslmd) Galaxy_MultiRoute8 Galileo        Galileo-GUI
12:44:57 (snpslmd) Galileo-Internal-Only Galileo-PSYN    Galileo-PnR
12:44:57 (snpslmd) Gate2LayoutCorrelation Gate2RTLCorrelation Gsim_dump_advance
12:44:57 (snpslmd) Gsim_dump_basic Gsim_framework_advance Gsim_framework_basic
12:44:57 (snpslmd) Gsim_snapshot    Gsim_wave    Floops-1D
12:44:57 (snpslmd) Floops-1D-MC    Floops-1D-MC_all Floops-1D-MC_ise
12:44:57 (snpslmd) Floops-1D-MC_ise_all Floops-1D_all    Floops-1D_ise
12:44:57 (snpslmd) Floops-1D_ise_all Floops-2D    Floops-2D-MC
12:44:57 (snpslmd) Floops-2D-MC_all Floops-2D-MC_ise Floops-2D-MC_ise_all
12:44:57 (snpslmd) Floops-2D_all    Floops-2D_ise    Floops-2D_ise_all
12:44:57 (snpslmd) Floops-3D    Floops-3D-MC    Floops-3D-MC_all
12:44:57 (snpslmd) Floops-3D-MC_ise Floops-3D-MC_ise_all Floops-3D_all
12:44:57 (snpslmd) Floops-3D_ise    Floops-3D_ise_all Floops-Parallel4_all
12:44:57 (snpslmd) Floops-Parallel_all Formality    Formality-Beta1
12:44:57 (snpslmd) Formality-Beta2 Formality-DV    Formality-Distributed
12:44:57 (snpslmd) Formality-E1    Formality-ESP    Formality-TX
12:44:57 (snpslmd) Formality-TransForm Formality-Transit Fridge-GUI
12:44:57 (snpslmd) Fridge-Interpolator Fridge-Simulation FLEX10K
12:44:57 (snpslmd) FLEX10KA    FLEX10KB    FLEX10KE
12:44:57 (snpslmd) FLEX6000    FLEX8000    FLE_main
12:44:57 (snpslmd) FL_cosim_run    FL_ice_run    FL_multichip_partition
12:44:57 (snpslmd) FL_recalc    FPGA-Compiler    FPGA-Express
12:44:57 (snpslmd) FPGA-Express-32OODx-Optimizer FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer
12:44:57 (snpslmd) FPGA-Express-A3200DX-Optimizer FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer
12:44:57 (snpslmd) FPGA-Express-APEX2-Optimizer FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr
12:44:57 (snpslmd) FPGA-Express-EP20k-Optimizer FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer
12:44:57 (snpslmd) FPGA-Express-EPF8k-Optimizer FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer
12:44:57 (snpslmd) FPGA-Express-GAT FPGA-Express-ISP4000-Optimizer FPGA-Express-ISP5000-Optimizer
12:44:57 (snpslmd) FPGA-Express-MERCURY-Optimizer FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer
12:44:57 (snpslmd) FPGA-Express-Open-Optimizer FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base
12:44:57 (snpslmd) FPGA-Express-VHDL-Training FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base
12:44:57 (snpslmd) FPGA-Express-XC3k-Optimizer FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer
12:44:57 (snpslmd) FPGA-Express-XC9k-Optimizer FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer
12:44:57 (snpslmd) FPGA-Express-isp3K-Optimizer FPGA-Express-isp4K-Optimizer FPGA-Express-isp5K-Optimizer
12:44:57 (snpslmd) FPGA-Express-isp6K-Optimizer FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer
12:44:57 (snpslmd) FPGA-HDL-Bundle FPGA-Library-Compiler FPGA-Option
12:44:57 (snpslmd) FPGA-VHDL-Bundle FPGA_Express-APROA-Optimizer Emlab
12:44:57 (snpslmd) Emlab-Dessis    Emlab-Dessis_all Emlab-Dessis_ise
12:44:57 (snpslmd) Emlab-Dessis_ise_all Emlab-Farfield    Emlab-Farfield_all
12:44:57 (snpslmd) Emlab-Farfield_ise Emlab-Farfield_ise_all Emlab-Nonuniform-2D
12:44:57 (snpslmd) Emlab-Nonuniform-2D_all Emlab-Nonuniform-2D_ise Emlab-Nonuniform-2D_ise_all
12:44:57 (snpslmd) Emlab-Nonuniform-3D Emlab-Nonuniform-3D_all Emlab-Nonuniform-3D_ise
12:44:57 (snpslmd) Emlab-Nonuniform-3D_ise_all Emlab-Static    Emlab-Static_all
12:44:57 (snpslmd) Emlab-Static_ise Emlab-Static_ise_all Emlab-Thermal
12:44:57 (snpslmd) Emlab-Thermal_all Emlab-Thermal_ise Emlab-Thermal_ise_all
12:44:57 (snpslmd) Emlab-Uniform-2D Emlab-Uniform-2D_all Emlab-Uniform-2D_ise
12:44:57 (snpslmd) Emlab-Uniform-2D_ise_all Emlab-Uniform-3D Emlab-Uniform-3D_all
12:44:57 (snpslmd) Emlab-Uniform-3D_ise Emlab-Uniform-3D_ise_all Emlab_all
12:44:57 (snpslmd) Emlab_ise    Emlab_ise_all    Enterprise
12:44:57 (snpslmd) Enterprise_VO    Equation-Reader Equation-Writer
12:44:57 (snpslmd) Espresso-Reader Espresso-Writer Estm-HDL-Advisor
12:44:57 (snpslmd) Estm-HDL-Advisor-Package E3        E5
12:44:57 (snpslmd) E502        E505        E520
12:44:57 (snpslmd) ECL-Compiler    ECO-Compiler    EDIF-Netlist-Read-DC
12:44:57 (snpslmd) EDIF-Netlist-Write-DC EDIF-Netlist-Writer EDIF-Reader
12:44:57 (snpslmd) EDIF-Schematic-Writer EDIF_NETLISTER    EDIF_NETLISTER_MEMSSE
12:44:57 (snpslmd) ELGRECO_Davis    ELGRECO_DesignCenter ELGRECO_Simulator
12:44:57 (snpslmd) ENACE        ENACS        EV-ACCESS
12:44:57 (snpslmd) EV-ACCESS_UTIL    EXCALIBUR_ARM    EXCALIBUR_MIPS
12:44:57 (snpslmd) EXPT_EDITOR    EXPT_EDITOR_MEMSSE EXPT_EDITOR_PLUS
12:44:57 (snpslmd) EXPT_EDITOR_PLUS_MEMSSE Devise        Devise-3D
12:44:57 (snpslmd) Devise-3D_all    Devise-3D_ise    Devise-3D_ise_all
12:44:57 (snpslmd) Devise_all    Devise_ise    Devise_ise_all
12:44:57 (snpslmd) Dfisetools    Dfisetools-Topo_all Dfisetools_all
12:44:57 (snpslmd) Dfisetools_ise    Dfisetools_ise_all Dios-3D_all
12:44:57 (snpslmd) Dios-MC_all    Dios-PDEF_all    Dios-SDO_all
12:44:57 (snpslmd) DiosSmall_all    Dios_all    Dip
12:44:57 (snpslmd) Dip_all        Dip_ise        Dip_ise_all
12:44:57 (snpslmd) Dessis-Optic    Dessis-Optic_all Dessis-Optic_ise
12:44:57 (snpslmd) Dessis-Optic_ise_all Dessis-PMI    Dessis-PMI_all
12:44:57 (snpslmd) Dessis-PMI_ise    Dessis-PMI_ise_all Dessis-Parallel
12:44:57 (snpslmd) Dessis-Parallel4 Dessis-Parallel4_all Dessis-Parallel4_ise
12:44:57 (snpslmd) Dessis-Parallel4_ise_all Dessis-Parallel_all Dessis-Parallel_ise
12:44:57 (snpslmd) Dessis-Parallel_ise_all Dessis-Radiation Dessis-Radiation_all
12:44:57 (snpslmd) Dessis-Radiation_ise Dessis-Radiation_ise_all Dessis-Reliability
12:44:57 (snpslmd) Dessis-Reliability_all Dessis-Reliability_ise Dessis-Reliability_ise_all
12:44:57 (snpslmd) Dessis-Schroedinger Dessis-Schroedinger_all Dessis-Schroedinger_ise
12:44:57 (snpslmd) Dessis-Schroedinger_ise_all Dessis-SiGe    Dessis-SiGe_all
12:44:57 (snpslmd) Dessis-SiGe_ise Dessis-SiGe_ise_all Dessis-Thermo
12:44:57 (snpslmd) Dessis-Thermo_all Dessis-Thermo_ise Dessis-Thermo_ise_all
12:44:57 (snpslmd) Dessis-Traps    Dessis-Traps_all Dessis-Traps_ise
12:44:57 (snpslmd) Dessis-Traps_ise_all Dessis-VectorOptic Dessis-VectorOptic_all
12:44:57 (snpslmd) Dessis-VectorOptic_ise Dessis-VectorOptic_ise_all Dessis-kpGain
12:44:57 (snpslmd) Dessis-kpGain_all Dessis-kpGain_ise Dessis-kpGain_ise_all
12:44:57 (snpslmd) Dessis_all    Dessis_ise    Dessis_ise_all
12:44:57 (snpslmd) Dessis        Dessis-3D    Dessis-3D_all
12:44:57 (snpslmd) Dessis-3D_ise    Dessis-3D_ise_all Dessis-BONSIM_all
12:44:57 (snpslmd) Dessis-DensityGrad Dessis-DensityGrad_all Dessis-DensityGrad_ise
12:44:57 (snpslmd) Dessis-DensityGrad_ise_all Dessis-Ferro    Dessis-Ferro_all
12:44:57 (snpslmd) Dessis-Ferro_ise Dessis-Ferro_ise_all Dessis-FloatingGate
12:44:57 (snpslmd) Dessis-FloatingGate_all Dessis-FloatingGate_ise Dessis-FloatingGate_ise_all
12:44:57 (snpslmd) Dessis-GateLeakage Dessis-GateLeakage_all Dessis-GateLeakage_ise
12:44:57 (snpslmd) Dessis-GateLeakage_ise_all Dessis-Hetero    Dessis-Hetero_all
12:44:57 (snpslmd) Dessis-Hetero_ise Dessis-Hetero_ise_all Dessis-Hydro
12:44:57 (snpslmd) Dessis-Hydro_all Dessis-Hydro_ise Dessis-Hydro_ise_all
12:44:57 (snpslmd) Dessis-LED    Dessis-LED_all    Dessis-LED_ise
12:44:57 (snpslmd) Dessis-LED_ise_all Dessis-Laser    Dessis-Laser_all
12:44:57 (snpslmd) Dessis-Laser_ise Dessis-Laser_ise_all Dessis-MixedMode
12:44:57 (snpslmd) Dessis-MixedMode_all Dessis-MixedMode_ise Dessis-MixedMode_ise_all
12:44:57 (snpslmd) Dessis-Mono-Semicond Dessis-Mono-Semicond_all Dessis-Mono-Semicond_ise
12:44:57 (snpslmd) Dessis-Mono-Semicond_ise_all Dessis-MonteCarlo Dessis-MonteCarlo_all
12:44:57 (snpslmd) Dessis-MonteCarlo_ise Dessis-MonteCarlo_ise_all Dessis-Noise
12:44:57 (snpslmd) Dessis-Noise_all Dessis-Noise_ise Dessis-Noise_ise_all
12:44:57 (snpslmd) DesignWare    DesignWare-1394 DesignWare-1394-Source
12:44:57 (snpslmd) DesignWare-6811-Source DesignWare-8051 DesignWare-8051-Source
12:44:57 (snpslmd) DesignWare-8051MCU DesignWare-AMBA-tlm DesignWare-ARMCORES-tlm
12:44:57 (snpslmd) DesignWare-BIST DesignWare-BIST-Source DesignWare-Cardbus
12:44:57 (snpslmd) DesignWare-Developer-MGI DesignWare-ETHERNET DesignWare-ETHERNET-Source
12:44:57 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
12:44:57 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
12:44:57 (snpslmd) DesignWare-ISA-PnP DesignWare-MEMCTL-Source DesignWare-MGI
12:44:57 (snpslmd) DesignWare-MPEG DesignWare-MPEG-Source DesignWare-MPEG2
12:44:57 (snpslmd) DesignWare-MPEG2-Source DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source
12:44:57 (snpslmd) DesignWare-MemoryBist DesignWare-MemoryBist-Source DesignWare-PCI
12:44:57 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
12:44:57 (snpslmd) DesignWare-PCIbasic DesignWare-Package DesignWare-SystemIO
12:44:57 (snpslmd) DesignWare-SystemIO-Source DesignWare-TCA    DesignWare-TCA-Source
12:44:57 (snpslmd) DesignWare-USB    DesignWare-USB-Source DesignWare-USB2
12:44:57 (snpslmd) DesignWare-USB2-Source DesignWare-VERA Designware-Basic
12:44:57 (snpslmd) Designware-Developer Designware-FPGA-Basic DV
12:44:57 (snpslmd) DVAM        DVCA        DVHJ
12:44:57 (snpslmd) DVLT        DVOD        DVPD
12:44:57 (snpslmd) DVTC        DW-Developer    DW-IP-Consultant
12:44:57 (snpslmd) DW-IP-DEBUG    DW-IP-Developer DWC-AHB-ICTL-Source
12:44:57 (snpslmd) DWC-AHB-Source    DWC-AMBA-Fabric-Source DWC-APB-Advanced-Source
12:44:57 (snpslmd) DWC-APB-ICTL-Source DWC-APB-Periph-Source DWC-DMA-Controller-Source
12:44:57 (snpslmd) DWC-DMAC-Source DWC-GPIO-Source DWC-I2C-Source
12:44:57 (snpslmd) DWC-INTC-CNTL-Source DWC-MEMCTL-Source DWC-RAP-Source
12:44:57 (snpslmd) DWC-RTC-Source    DWC-SSI-Source    DWC-TIMERS-Source
12:44:57 (snpslmd) DWC-UART-SRC    DWC-UART-Source DWC-WDT-Source
12:44:57 (snpslmd) DataExpansion    DataExpansionCoverage DataExpansionSim
12:44:57 (snpslmd) DataReplay    DataReplaySim    Debussy
12:44:57 (snpslmd) Debussy_shared    Design-Analyzer Design-Analyzer-DAP
12:44:57 (snpslmd) Design-Budgeting Design-Compiler Design-Estimator
12:44:57 (snpslmd) Design-Estimator-FPI Design-Expert    Design-Vision
12:44:57 (snpslmd) DesignSource    DesignSource-Estimator-Package DesignSource-Package
12:44:57 (snpslmd) DesignTime    DC-Beta        DC-Cadence-Interface
12:44:57 (snpslmd) DC-Expert    DC-Extension    DC-FPGA-Accelerator
12:44:57 (snpslmd) DC-FPGA-Add-On    DC-FPGA-Add-On-to-DC DC-FPGA-INCREMENTs
12:44:57 (snpslmd) DC-Falcon-Interface DC-Layout-Interface DC-Min-Area-Retime
12:44:57 (snpslmd) DC-SDF-Interface DC-Topographical DC-Ultra
12:44:57 (snpslmd) DC-Ultra-Features DC-Ultra-INCREMENTs DC-Ultra-Opt
12:44:57 (snpslmd) DC-XG        DC64        DCExpert-PrimeTime
12:44:57 (snpslmd) DCM-Delay-Calculation DCT-Congestion    DCT-GUI
12:44:57 (snpslmd) DESIGNSTAR    DESIGNSTAR_NET    DESIGNWARE-AMBA-VIP
12:44:57 (snpslmd) DESIGNWARE-ETHERNET-VIP DESIGNWARE-I2C-VIP DESIGNWARE-REGRESSION
12:44:57 (snpslmd) DESIGNWARE-SIO-VIP DESIGNWARE-USB-VIP DESIGNWARE-VERIFICATION
12:44:57 (snpslmd) DIODE_TOOL    DIODE_TOOL_MEMSSE DRCYCLE_TOOL
12:44:57 (snpslmd) DRCYCLE_TOOL_MEMSSE DS-Schem-Gen    DS-Schem-Gen-Estimator-Pa
12:44:57 (snpslmd) DS-Schem-Gen-Estimator-Package DS-Schem-Gen-Package DS-Verinet
12:44:57 (snpslmd) DS-Verinet-Estimator-Pack DS-Verinet-Estimator-Package DS-Verinet-Package
12:44:57 (snpslmd) DS-Vhdlnet    DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package
12:44:57 (snpslmd) DS-Vhdlnet-Package COVENTOR_LIB10    COVENTOR_LIB10_MEMSSE
12:44:57 (snpslmd) COVENTOR_LIB11    COVENTOR_LIB11_MEMSSE COVENTOR_LIB12
12:44:57 (snpslmd) COVENTOR_LIB12_MEMSSE COVENTOR_LIB13    COVENTOR_LIB13_MEMSSE
12:44:57 (snpslmd) COVENTOR_LIB14    COVENTOR_LIB14_MEMSSE COVENTOR_LIB15
12:44:57 (snpslmd) COVENTOR_LIB15_MEMSSE COVENTOR_LIB8    COVENTOR_LIB8_MEMSSE
12:44:57 (snpslmd) COVENTOR_LIB9    COVENTOR_LIB9_MEMSSE CRS_COVERMETER
12:44:57 (snpslmd) CRS_VCM        CRS_VCS        CRS_VCSi
12:44:57 (snpslmd) CXp_Analysis    CXp_CircuitEnvironment CXp_GUI
12:44:57 (snpslmd) CmMonitor    CmView        CoCentric-FXD-GUI
12:44:57 (snpslmd) CoCentric-FXD-Interpolator CoCentric-FXD-Simulation CoCentric-SYS-Davis
12:44:57 (snpslmd) CoCentric-SYS-DesignCenter CoCentric-SYS-HWSimIF CoCentric-SYS-HWflow
12:44:57 (snpslmd) CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000 CoCentric-SYS-RDK-docsis
12:44:57 (snpslmd) CoCentric-SYS-Simulator Columbia    ColumbiaTE
12:44:57 (snpslmd) CoverMeter    CoverMeterOBC    CoverMeterOBCVCSAMSCompiler
12:44:57 (snpslmd) Cyclone-Code-Generator Cyclone-Core    Cyclone-Elaborator
12:44:57 (snpslmd) Cyclone-GUI    Cyclone-HDL-Analyzer Cyclone-Simulator
12:44:57 (snpslmd) Cyclone-VHDL-Analyzer Cyclone-cosim    COSSAP_adpcm
12:44:57 (snpslmd) COSSAP_adsl    COSSAP_amr    COSSAP_arm
12:44:57 (snpslmd) COSSAP_bde    COSSAP_celp    COSSAP_chart
12:44:57 (snpslmd) COSSAP_cw_filter_hdl COSSAP_cw_filter_sds COSSAP_dab
12:44:57 (snpslmd) COSSAP_dcg_ad21020 COSSAP_dcg_ansic COSSAP_dcg_ariel32c
12:44:57 (snpslmd) COSSAP_dcg_fe    COSSAP_dcg_gc    COSSAP_dcg_krc
12:44:57 (snpslmd) COSSAP_dcg_lsic30s COSSAP_dcg_m96000 COSSAP_dcg_mp
12:44:57 (snpslmd) COSSAP_ddk_arm    COSSAP_ddk_devlp COSSAP_ddk_dsp16000
12:44:57 (snpslmd) COSSAP_ddk_dsp1610 COSSAP_ddk_hawk COSSAP_ddk_nec
12:44:57 (snpslmd) COSSAP_ddk_oak    COSSAP_ddk_pine COSSAP_ddk_ssp16xx
12:44:57 (snpslmd) COSSAP_ddk_tic5x COSSAP_ddk_tic5xx COSSAP_dect
12:44:57 (snpslmd) COSSAP_dvb    COSSAP_ecc    COSSAP_gsmdve
12:44:57 (snpslmd) COSSAP_gsmdve_utils COSSAP_gsmefrsc COSSAP_gsmeq
12:44:57 (snpslmd) COSSAP_gsmfrcc    COSSAP_gsmhrsc    COSSAP_gsmphy
12:44:57 (snpslmd) COSSAP_is136    COSSAP_is95    COSSAP_matlab
12:44:57 (snpslmd) COSSAP_mfd    COSSAP_mpeg2    COSSAP_pdc
12:44:57 (snpslmd) COSSAP_qed    COSSAP_sds    COSSAP_srcfd
12:44:57 (snpslmd) COSSAP_vcg_generic COSSAP_vcg_synopsys COSSAP_vcg_vantage
12:44:57 (snpslmd) COSSAP_vdefcg    COSSAP_vdefcg_vlgxl COSSAP_vsiccg
12:44:57 (snpslmd) COSSAP_vsiccg_cyc COSSAP_vsiccg_mti COSSAP_vsiccg_mtivlg
12:44:57 (snpslmd) COSSAP_vsiccg_vcs COSSAP_vsiccg_vlgxl COSSAP_vsivcg
12:44:57 (snpslmd) COSSAP_vsivcg_vlgxl COSSAP_xdcg    COSSAP_xvcg
12:44:57 (snpslmd) COSSAP_xvsi    CA-CP-Advanced    CA-CP-Basic
12:44:57 (snpslmd) CA-CP-Standard    CA-Chip-Edit    CA-Foundation
12:44:57 (snpslmd) CA-Frame    CA-Hier-Timer    CA-Optimization
12:44:57 (snpslmd) CA-Timer    CA-Utils    CADENCE_DIVA_NETLISTER
12:44:57 (snpslmd) CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE CADENCE_NETLISTER
12:44:57 (snpslmd) CADENCE_NETLISTER_MEMSSE CBA-ApolloGA-Interface CBA-Blk-Export
12:44:57 (snpslmd) CBA-Blk-Import    CBA-CadenceSE-Interface CBA-DS-Beta
12:44:57 (snpslmd) CBA-Frame    CBA-Logical-DS    CBA-Logical-MA
12:44:57 (snpslmd) CBA-Physical-DS CBA-Physical-MA CBA-Transport
12:44:57 (snpslmd) CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen CD-GDI
12:44:57 (snpslmd) CD-GDII-Link    CD-MSSC-Cross-Probe CD-MSSC-Netlist
12:44:57 (snpslmd) CD-Model-Developer CD-Present-Builder CD-Present-Layer-Gen
12:44:57 (snpslmd) CD-REX        CD-Vhdlgen-GUI    CD-Vhdlgen-Gen
12:44:57 (snpslmd) COMPONENT_LIBRARY COMPONENT_LIBRARY_MEMSSE CONCEPT_FRAMEWAY
12:44:57 (snpslmd) CONCEPT_NETLISTER COOLRUNNER    COOLRUNNER2
12:44:57 (snpslmd) CORENL_CHAR    CORENL_CHAR_MEMSSE COSIM-LFG
12:44:57 (snpslmd) COSIM-MTI    COSIM-NCV    COSIM-SRO
12:44:57 (snpslmd) COSIM-VCS    COSIM-VXL    COSMOS
12:44:57 (snpslmd) COSMOS_GUIDE    COSMOS_SKETCH    COSMOS_SKETCH_BACK_ANN
12:44:57 (snpslmd) COSMOS_SKETCH_NETLISTER COSMOS_VO    BASIC_ANALYSES
12:44:57 (snpslmd) BASIC_ANALYSES_MEMSSE BATCH_MEASURE    BATCH_MEASURE_MEMSSE
12:44:57 (snpslmd) BATT_TOOL    BATT_TOOL_MEMSSE BC-FPGA
12:44:57 (snpslmd) BC-FPGA-HDL    BC-FPGA-VHDL    BC-HDL
12:44:57 (snpslmd) BC-Schedule    BC-VHDL        BETA_LIBRARY
12:44:57 (snpslmd) BOA-BRT        BUILD_DATE    BUILD_NUMBER
12:44:57 (snpslmd) BUNDLE_MCAD_PROJECTION Behavioral-Analyzer Behavioral-Compiler
12:44:57 (snpslmd) A3200DX        A42MX        A500K
12:44:57 (snpslmd) A54SX        A54SXA        A7
12:44:57 (snpslmd) AIM_DEBUG    AIM_DEBUG_MEMSSE AIM_DECRYPT
12:44:57 (snpslmd) AIM_DEVELOPER    AIM_DEVELOPER_MEMSSE AIM_ENCRYPT
12:44:57 (snpslmd) ALTGEN1        ALTGEN2        AN-Impl3D
12:44:57 (snpslmd) AN-Impl3D_all    AN-Impl3D_ise    AN-Impl3D_ise_all
12:44:57 (snpslmd) APACM        APATD        APCS
12:44:57 (snpslmd) APDP        APEX20K        APEX20KC
12:44:57 (snpslmd) APEX20KE    APEXII        APGA4AP
12:44:57 (snpslmd) APGACS        APGADP        APGAHPO
12:44:57 (snpslmd) APGASolar    APGASolarII    APGATime
12:44:57 (snpslmd) APGApwr        APHPO        APPower
12:44:57 (snpslmd) APSolar        APSolarII    APTime
12:44:57 (snpslmd) APXtalk        APpwr        ARKOS-A
12:44:57 (snpslmd) ARKOS-B        ARKOS-C        ARKOS-D
12:44:57 (snpslmd) ARKOS-E        ARKOS-Ice    ARKOS-Mcomp
12:44:57 (snpslmd) ARKOS-Rtlcomp    ARKOS-Scomp    ARKOS-Simul
12:44:57 (snpslmd) Astro        Astro-Express    Astro-MV
12:44:57 (snpslmd) Astro-Rail    Astro-Xtalk    AstroBeta
12:44:57 (snpslmd) AstroExp    AstroGA        AstroRail
12:44:57 (snpslmd) AstroRailSA    AstroSpecialBeta AstroXtalk
12:44:57 (snpslmd)
12:44:57 (snpslmd) Licenses are case sensitive for TE_CATS
12:44:57 (snpslmd)
12:44:57 (snpslmd) EXTERNAL FILTERS are OFF
12:44:57 (lmgrd) snpslmd using TCP-port 51446
12:44:57 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  everest  extremed  hscd  innologd  ISE-TCADd  knights  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
08/01/2017 12:44:58 (snpslmd) ------------------------------------------------------------------
08/01/2017 12:44:58 (snpslmd) Checking the integrity of the license file....
08/01/2017 12:44:58 (snpslmd) Valid SSS feature found.
08/01/2017 12:44:58 (snpslmd) The feature is needed to enable the other keys in your license file.
08/01/2017 12:44:58 (snpslmd) Licensed to mammoth//ZWT 2006
08/01/2017 12:44:58 (snpslmd) Siteid: 19688, Server Hostid: 708bcd4c981b, Issued on: 12/28/2012
12:45:03 (snpslmd) Failed to open socket to lmgrd, Exiting
12:45:03 (snpslmd) EXITING DUE TO SIGNAL 37 Exit reason 5
12:45:03 (lmgrd) snpslmd exited with status 37 (Communications error)
12:45:03 (lmgrd) Since this is an unknown status, license server
12:45:03 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
12:45:03 (lmgrd) REStarted snpslmd (internet tcp_port 37571 pid 25246)
12:45:03 (snpslmd) FlexNet Licensing version v11.12.1.2 build 152538 x64_lsb
12:45:03 (snpslmd) lmgrd version 11.6, snpslmd version 11.12
发表于 2020-2-3 12:09:39 | 显示全部楼层
楼主后来解决了吗
发表于 2020-3-2 12:44:06 | 显示全部楼层
thankss
发表于 2020-4-18 11:29:39 | 显示全部楼层
did you solve it ?
GMT+8, 2025-12-28 12:20 , Processed in 0.016023 second(s), 3 queries , Gzip On, Redis On.
