Responsibilities:
IP Application Engineer is working on cuttingedge Complex IP (such
as PLL, DDR/LPDDR, USB, MIPI, High Speed SerDes, etc.) engagement and support for
XX worldwide clients with especial focus on China clients. By employing
the industry leading tools, state of the art methodology, and innovative semiconductor leading
FinFET and FDSOI technologies ranging from 32nm, 22nm to 14nm, 7nm and beyond, you will
be participating in:
● Provide direct technical customer support and assistance to enable customers to
successfully use Complex IP in their chip
● Engage in hardware bring up and quality test support, including issue debug, electrical
parameter measurement and Complex IP interface/register analysis
● Enable physical integration of Complex IP in backend design process
● Provide customer feedback on requirements for Complex IP to internal development team
● Provide customer reference of board level circuit design on related interface
● Write application notes and review specifications for Complex IP
Requirements:
1. ME/EE/CS or background in related areas.
2. At least 3 years industry application engineering experience.
3. Experience and knowledge in one or more of the following areas:
● Complex mixedsignal IP customer application and usage support, such as PLL, DDR/LPDDR, USB, MIPI, HSS, etc.
● Hardware bring up and quality test support
● High speed link or memory interface protocols including JEDEC, PCIESIG, IEEE and OIF
● High speed link or memory interface design and verification experience is a plus
● High speed board design and validation experience is a plus
4. Good understanding of ASIC design flow and methodology.
5. Able to conduct flexible hour technical meetings, seminars and trainings to customers.
6. Business travel within greater China region is required.
7. Good English skills, communication skills, and willingness to work with a global team. Skill
in other languages is a plus.
8. Good learning competency, selfmotivated, and ability to work in diverse areas in a flexible and dynamic environment.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“凯轶—KT咨询”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“凯轶—KT咨询”即可添加,欢迎大家关注!
或者直接扫我哦
