查看: 2184|回复: 0
ubuntu下sentaurus 工具栏中的help-training启动不了firefox的解决方法
发表于 2017-1-14 17:41:46 | 显示全部楼层 |阅读模式
ubuntu下sentaurus 工具栏中的help-training启动不了firefox:/usr/lib/firefox/firefox:  ..../tcad/current/amd64/lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/firefox/firefox)
解决方法是:1. rm .../tcad/current/amd64/lib/libstdc++.so.6
                     2. ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 .../tcad/current/amd64/lib/libstdc++.so.6
如下,可以看到Tutorial啦。哈哈
TCAD Sentaurus Tutorial
These modules are intended as an introduction to using the TCAD Sentaurus tool suite. They are designed specifically for new users and provide examples with which to begin using the tools.
ModuleDescription
[url=]Tool Overview[/url]An overview of the TCAD Sentaurus tool suite is presented.
Module Time: 30 minutes
[url=]Sentaurus Workbench[/url]Sentaurus Workbench is the primary graphical front end that integrates TCAD Sentaurussimulation tools into one environment. It is used to design, organize, and run simulations.
Module Time: 3 hours and 30 minutes
[url=]Sentaurus Process[/url]Sentaurus Process is a complete and highly flexible multidimensional processmodeling environment. It constitutes a solid base for process simulation.
Module Time: 6 hours and 10 minutes
[url=]TCAD Sentaurus–IC WorkBench EV Plus Interface[/url]The TCAD Sentaurus–IC WorkBench EV Plus interface is used to process mask information such that it can be used in Sentaurus Process.
Module Time: 1 hour
[url=]Sentaurus Topography 3D[/url]Sentaurus Topography 3D is an advanced three-dimensional simulator for evaluating and optimizing critical topography-processing steps such as etching and deposition.
GMT+8, 2025-12-27 10:40 , Processed in 0.011261 second(s), 4 queries , Gzip On, Redis On.
