楼主: aurorasite
cadence spb172 linux
发表于 2017-10-11 08:57:24 | 显示全部楼层
thanks
发表于 2017-10-18 14:28:15 | 显示全部楼层
感谢楼主,这个需要学习一下
发表于 2017-10-24 10:59:24 | 显示全部楼层
这个的看看,感谢!
发表于 2017-10-29 14:49:03 | 显示全部楼层
谢谢分享
发表于 2018-8-8 11:25:53 | 显示全部楼层
有人安装成功过吗?为什么我装的时候提示缺很多文件,比如下面这些:
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsFileManager31.09-p004lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroPlace17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/concptGblModify16.60-a002lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/hpf17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/lmanutils17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/oaExeRH72Gcc32302.00-s137lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/lmanext17.20-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/plot64b35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbrteDoc17.20-p004.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbioANDoc17.20-p001.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/rfsipPcellIndep17.20-p006.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/projmgrDoc17.20-p002.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/apdIndep17.20-p008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/standardinte17.20-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/chdlPICXil17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cadencehelpJavaPI02.30-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/concptSetup17.20-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/hedElab64b35.15-p009lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/strokeEditor17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroSkill17.20-p008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroTransltr17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/smi17.20-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/rfsipPcell17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsCommon35.15-s001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/libexpDoc17.20-p007.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroInstall17.20-p009lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsCmonJava35.15-p004lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ddbpi17.20-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbproprefDoc17.20-p004.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/oainstallDoc22.50-p004.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/rfpcbcnSKILL16.60-b003lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/specctraQuest17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/deHDLUtilDoc17.20-p007.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ptfDoc17.20-p005.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/licenseDoc11.70-p002.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/view3DDoc17.20-p001.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdnWrapper06.01-s041.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/plotVersa35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbsqtutDoc17.20-p002.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/rfsipOaLayout17.20-d001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/creferHDL17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cadencehelpSupport02.30-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/capProgShared16.60-d022lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sipCommon17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sipVirtuosoSkl17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/lmanbase17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pspCapNetmain17.20-d001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroSigritySI17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pspiceserverProg17.20-b001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/productServer17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/veditUGDoc17.20-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/uiReplay64b35.15-p021lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/keymapDoc02.10-p041.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/rfsipCoreCxt17.20-p008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/symphony35.15-p004lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbsqrefDoc17.20-p002.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sipcommonDoc17.20-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/rfpcbfeugDoc17.20-p002.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/mpsJava35.15-p006.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/utils_hlib17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdnOAWrap04.00-p002lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/edif3dehdlDoc17.20-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbopgcommonDoc17.20-p009.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ddBaseIndep35.15-p009.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/skooprefDocC06.16-s008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsCommonIndep35.15-p007.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pxlmsgDoc17.20-p004.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroPCB16.20-a010lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cviewHDLDoc17.20-p006.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/dfIIbase61.00-s009lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/lbs35.15-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsJavaUI35.15-p004lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/archiver17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsfspDoc17.20-p005.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/conceptPSpice17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/skdevrefDocC06.16-s016.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/psetup17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/spgAnalysUtil17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroIDF17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ckSysConf02.00-p106lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroMfg17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/bom17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/hlib_standard17.00-d001.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ems35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pspCapInterface17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/skipcrefDocC06.16-s007.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/gdm35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbStartPageDoc17.20-p001.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/caeviewshdl17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroViewer17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/chdlPICAlt17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/mps64b35.15-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroNetin17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/fetBase17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cir31.09-p002lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/designmgr17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/markers17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cir64b34.13-d005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/uiReplay35.15-p021lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/skillDev64b35.15-p008lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/hedElab35.15-p009lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/lmanexp17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ddBaseOA64b35.15-p009lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sprouteIndep17.20-p008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pspiceserverIndep17.20-b001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/fetCommonUtils17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/virtuos64b35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/consMgrIndep17.20-p010.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/installDoc03.30-p001.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsCmonJava64b35.15-p004lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sproute17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/edbconfig16.00-d003lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pwizard17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/olecs17.20-d010lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdsLibManager31.09-p004lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sklanguserDocC06.16-s009.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/skillDev35.15-p008lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroIgout17.00-d037lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ckSysConfDoc02.00-p001.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroPlot17.20-p010lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/chdlPICAct17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ercdx17.20-p006lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/ckplusHDLDoc17.20-p005.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pcbcommonDoc17.20-p006.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cdnOAWrapIndep04.00-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroStrm17.20-p018lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cbBrowser17.20-p005lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/algroSigrityPI17.20-p019lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/caiuserDoc06.16-s023.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sklangrefDocC06.16-s014.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/icpIndep17.20-p008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/gdm64b35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/pspiceserverCore17.20-b001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/iotaIndep05.00-p037.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/veditWNDoc17.20-p003.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/fecpmDoc17.20-p007.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/plot35.15-p007lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/cadencehelpWrp02.00-p001lnx86.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/sigXpIndep17.20-p008.t.Z was not found.
com.util.ISException:The file /home/penty/Documents/Allegro/SPB17.20.000_lnx86.Base/CDROM1/kits/mps35.15-p006lnx86.t.Z was not found.
发表于 2018-8-8 11:28:46 | 显示全部楼层
回复 18# putechen
发表于 2018-8-8 11:29:48 | 显示全部楼层
回复 18# putechen
   根本装不上嘛,提示缺一大堆文件,你能装上?
发表于 2018-8-8 11:31:00 | 显示全部楼层
回复 18# putechen
发表于 2018-8-8 16:31:20 | 显示全部楼层
回复 1# aurorasite
    thanks for sharing
发表于 2018-10-10 22:42:44 | 显示全部楼层
谢谢楼主分享
GMT+8, 2025-11-25 19:14 , Processed in 0.052541 second(s), 3 queries , Gzip On, Redis On.
