查看: 3816|回复: 4
ADS2015 仿真出错求助
发表于 2016-10-23 02:40:55 | 显示全部楼层 |阅读模式
ADS2015 版图仿真显示如下错误,原理图仿真也出现了如下的错误
License check returned: Momentum Object
The desired vendor daemon is down
Possible Causes:
1. lmgrd process is running, but not the agileesofd vendor daemon. The software was able to contact the license server (lmgrd), but the vendor daemon (agileesofd) did not respond.
2. agileesofd vendor daemon has crashed or has been terminated.
3. lmgrd process was shut down manually or via LMTools with -x lmdown option
4. On Windows platform, this could be caused by waking up from Sleep or Hibernation mode.
5. The logfile was unable to be removed.
Troubleshooting Tips:
1. Check the license server's debug log file and try lmreread.
2. Reboot your system to restart the license service.
3. Use LMTools to clear your previous setup first, then restart license setup wizard to re-configure your license.
4. Shut down the lmgrd process and check that lmgrd or agileesofd processes are no longer running. Restart the license server.
5. Stop lmgrd via kill pid (UNIX) withough -9 argument or stop the lmgrd process through the Windows Task Manager or Windows Service.
6. Close all processes that are reading the logfile.
License Requested:  mom_obj
License path:  H:\ADS_2015.01\ADS2015_01\EEsof_License_Tools\bin\license.lic
--- ERROR ---------------------------------------------------------------------
License not available
相关帖子
发表于 2016-10-26 22:43:00 | 显示全部楼层
我也遇到这个问题了
发表于 2016-10-27 15:43:34 | 显示全部楼层
谢谢分享!
发表于 2019-7-11 14:41:57 | 显示全部楼层
ohdarling 发表于 2016-10-26 22:43
我也遇到这个问题了
我也遇到了 请问你解决了吗
发表于 2019-7-15 18:27:58 | 显示全部楼层
ads 本身的lic管理器 没有成功运行   你的lic设置有问题.
GMT+8, 2025-12-27 13:09 , Processed in 0.015647 second(s), 5 queries , Gzip On, Redis On.
