查看: 5587|回复: 2
[讨论] LVS疑问
发表于 2016-6-14 17:03:23 | 显示全部楼层 |阅读模式
各位:
在LVS runset文件中看到有如下2条语句,不知道是啥意思?
LVS SPICE REPLICATE DEVICES    YES
LVS SPICE STRICT WL                  YES
发表于 2016-6-24 10:33:26 | 显示全部楼层
LVS SPICE STRICT WL {NO | YES | NONE}
Parameters
• NO
Keyword that instructs LVS to interpret any SPICE netlist parameter beginning with a W as
width and beginning with an L as length. This applies to M devices. This is the default
behavior if you do not specify this statement.
• YES
Keyword that instructs LVS to interpret only the letter “W” for width and only the letter “L”
for length in SPICE netlists. This applies to M devices.
• NONE
width and beginning with an L as length. This applies to M devices and to X devices
instantiated as MOSFETs.
发表于 2016-6-24 10:36:27 | 显示全部楼层
LVS SPICE REPLICATE DEVICES {NO | YES}
Parameters
• NO
Specifies that the M property in SPICE netlists does not cause physical copies of elements
owning M parameters to be made in the SPICE netlist. This is the default if you do not
include this statement in a rule file.
• YES
Specifies that the M property in SPICE netlists causes creation of multiple physical copies
of elements owning M parameters in the SPICE netlist.
GMT+8, 2025-9-17 15:21 , Processed in 0.011487 second(s), 3 queries , Gzip On, Redis On.
