楼主: enndub
Altera Quartus Prime 16.0 Win64 Crack + Lic (with DSP Builder)
发表于 2016-9-23 17:17:49 | 显示全部楼层
Thank u really...
发表于 2016-9-25 07:12:59 | 显示全部楼层
回复 2# enndub
发表于 2016-9-25 07:15:54 | 显示全部楼层
回复 1# enndub
发表于 2016-9-25 11:34:36 | 显示全部楼层
Thanks!
发表于 2016-9-26 13:34:39 | 显示全部楼层
万分感谢
发表于 2016-9-26 14:33:44 | 显示全部楼层
it doesn't work with dsp builder + quartus prime 16.0.2.222 + matlab 2015b...
Java exception occurred:
com.altera.dspbuilder.common.DSPBuilderException: Unable to obtain a DSP Builder license. Please check that your LM_LICENSE_FILE environment variable is set to a valid license file or license server. LM_LICENSE_FILE is currently "".
        at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(Unknown Source)
发表于 2016-9-26 15:15:54 | 显示全部楼层
    well i got that... the license file of quartus prime 16.0 update 2 doesn't contain dsp builder license, so copy this to the quartus license, it works
  1. FEATURE C4D5_512A alterad 2037.12 01-dec-2037 uncounted B8B9912B9FDD \
  2.         VENDOR_STRING=7fkcz2dzAE7VAszbjLTzXH \
  3.         HOSTID=XXXXXXX SIGN="104A 713D 79E4 B387 DBEF 5356 \
  4.         52CB 67AB FE02 4702 E2B0 A729 486E F24A 436B 0FE6 0353 6B08 \
  5.         4AC5 E799 6256 36C3 AAF5 BEDB 6851 3CAA 8333 0AC2 B5F5 750B"
    复制代码
发表于 2016-9-29 20:44:51 | 显示全部楼层
楼主威武
发表于 2016-9-30 08:34:33 | 显示全部楼层
很及时嘛。
发表于 2016-10-1 11:54:30 | 显示全部楼层
good thxs
GMT+8, 2025-12-15 12:08 , Processed in 0.021346 second(s), 5 queries , Gzip On, Redis On.
