查看: 20591|回复: 11
[求助] VCS 调起来遇到错误,求帮助:Error-[NOA] Null object access
发表于 2016-5-5 14:37:10 | 显示全部楼层 |阅读模式
/p/inway/addons/fv/sv_packages/external/ovm/ovm-2.1.2/src/base/ovm_globals.svh, 168
  The object at dereference depth 0 is being used before it was
  constructed/allocated.
  Please make sure that the object is allocated before using it.
  #0 in ovm_report_warning at
  /p/inway/addons/fv/sv_packages/external/ovm/ovm-2.1.2/src/base/ovm_globals.svh:168
  #1 in \ovm_factory::register  at
  /p/inway/addons/fv/sv_packages/external/ovm/ovm-2.1.2/src/base/ovm_factory.sv:77
  #2 in \ovm_object_registry#(ovm_pkg:vm_objection,"ovm_objection")::get  at
  /p/inway/addons/fv/sv_packages/external/ovm/ovm-2.1.2/src/base/ovm_registry.svh:210
  #3 in ovm_pkg
compile 和 elaboration都没有问题,调VCS的时候刚启动起来就报这样的错,求帮助啊。
谢谢
发表于 2016-5-5 18:54:55 | 显示全部楼层
应该是对应的某个属性或者objec没有new
发表于 2016-5-9 09:27:16 | 显示全部楼层
楼上正解
发表于 2018-6-26 21:30:47 | 显示全部楼层
回复 2# 周嬷嬷
赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞
发表于 2019-6-16 21:19:20 | 显示全部楼层
请问楼主,怎么找到没有new的object?
发表于 2019-6-25 19:25:27 | 显示全部楼层
同问
发表于 2019-7-25 14:14:53 | 显示全部楼层
在报错的附近,用assert(object!=null)判断一下。
发表于 2019-8-28 10:12:55 | 显示全部楼层
请问找到了吗
发表于 2019-8-28 10:42:23 | 显示全部楼层
请问为什么我这样操作不行,说object没有声明
发表于 2019-8-28 11:17:53 | 显示全部楼层
assert的目的就是判断object是否实例化
GMT+8, 2025-10-7 09:36 , Processed in 0.045629 second(s), 5 queries , Gzip On, Redis On.
