查看: 2369|回复: 2
Calibre Interactive pipo not found
发表于 2016-3-29 20:46:01 | 显示全部楼层 |阅读模式
Hi everbody,
I have Installed IC610, MMSIM12, Assura and Calibre 4.12 x86_cal_2011.2_34.26 ON  the Ubuntu 10.04 32 'bit the OS.
I got a problem with Calibre interactive below,
screen_shot
screen_shot
*** Calibre Interactive: Exporting layout for library "tsmc18rf", cell "transistor", view "layout" ***
sh: pipo: not found
I follwed the link below for Calibre install.
http://bbs.eetop.cn/viewthread.php?tid=311773&highlight=calibre%2B2011.2
Bashrc file contains the lines here.
lmlim1 = Alias' / usr / local / Mentor / Calibre 2011 / x86_cal_ 2011.2 _34.26 / bin / lmgrd -c /usr/local/mentor/lic/license.dat '
  Alias lmlim2 =' / usr / local / Mentor / Calibre 2011 / x86_cal_ 2011.2 _34.26 / bin / lmstat -c /usr/local/mentor/lic/license.dat '
  Export MGC_HOME = / usr / local / Mentor
  Export CALIBRE_HOME = $ MGC_HOME / Calibre 2011 / x86_cal_ 2011.2 _34.26
  Export = $ MGC_HOME MGLS_LICENSE_FILE / LIC / the license.dat :$MGLS_LICENSE_FILE
  Export $ CALIBRE_HOME the PATH = / bin :$the PATH
I went through the " Creating AN Interface to the Cadence Virtuoso" in the Help section. But found NO solution to it.
sh: pipo: not found
Do you have any idea to solve it?
Thanks.
发表于 2017-2-9 03:25:32 | 显示全部楼层
May be rule file error
发表于 2018-5-15 19:44:42 | 显示全部楼层
GOOD MATEIRAL
GMT+8, 2025-12-30 11:33 , Processed in 0.015647 second(s), 5 queries , Gzip On, Redis On.
