查看: 2013|回复: 2
[招聘] 美满电子校园招聘
发表于 2016-3-4 10:42:37 | 显示全部楼层 |阅读模式
美满电子,创芯世界!
Smart Life, Smart Lifestyle!
接触核心技术,全球无缝沟通,创芯世界,等你硅队!
美满电子快速通道--投递简历至china-hr-staffing@marvell.com,邮件标题格式为“姓名-学校-意向职位-地点-中国顶级开发网”。
上海
SoC Platform部门: IC Design Engineer (SOC)/ Software Engineer
CSI部门: Datacom System Engineering - Software Engineer/Datacom Analog Engineer/Datacom Digital Engineer
Wireless Technology部门: GPS software engineer
Video部门:Software Engineer
南京
Wireless Technology: GPS software engineer
Central Engineering: Analog IC Layout (Nanjing)-CE
成都
具体要求:
上海
*SoC Platform: IC Design Engineer (SOC)
 Responsibilities:
-Work on IP and chip design;
-Understanding architecture and protocols;
-RTL design and verification;
-Documentation;
-Work closely with FPGA team for pre-silicon prototyping;
-Work closely with software team for driver developments;
-Travelling to US is not mandatory, but sometimes required.
Qualifications:
-MS or PHD in EE;
-Good understanding of digital IC design;
-Good team work spirit and strong problem solving skills;
-Knowledge of Synthesis, STA and DFT is a plus;
-Knowledge of SystemVerilog and UVM is a plus;
*SoC Platform: Software Engineer
 Description:
In this position, you will be working with the system architects, technical leaders and other developers to contribute to embed Linux BSP.
You will be responsible for the detailed development specifications, system performance profiling and you also will work with the validation team to ensure the system is thoroughly tested.
 Qualifications:
-Master in Electronic Engineering or Computer Science major
-Strong in c/c++/assembly programming skills
-Deep understanding about SOC system
-Good at Linux kernel and driver development
-Hardware debugging experience is a plus
-Experience with PCIE, USB, memory controller or NAND
-FLash is a plus
-Fluent communication in English
*CSI: Datacom System Engineering - Software Engineer
 Description:
This is an entry level, software engineering oriented system engineer position. The engineer will be part of the vertical system engineering team composed with hardware engineering, software engineering, firmware engineering, FPGA design engineering, signal integrity engineering, and others. The IC products to work with include Ethernet PHY/NIC/Switch/SoC, high speed SerDes based PHYs, DTV front end components, PLC PHYs, and so on. System engineering team is responsible for many post silicon engineering efforts like product validation, platform development, collateral development, technical support and so on.
 Qualifications:
-Test Automation Software Development.
-GUI Tool Software Development.
-Driver Software Development.
-Manufacturing Software Development.
-Department/Enterprise Software Tool Development.
-BS/MS in EE/CE/CS.
-Must have good C/C++ program skill.
-Must be familiar with MS Window system.
-Must have good knowledge with computer system and data network system.
-Must be willing to work in a multi-tasking, fast pace, team oriented working environment.
-Must be able to quickly absorb different kinds of knowledge and apply them in the works.
-Working experience on software development are preferred.
-Familiarity with MS .net, Ethernet and network protocols are some pluses.
*Wireless Technology: GPS software engineer
 Responsibilities:
-Design and optimize algorithms for GNSS and/or hybrid positioning system based on
GPS/GNSS, WiFi, BT (BLE), inertial sensors, etc;
-Develop and optimize hybrid positioning software based on existed codebase;
-perform algorithm and code optimization based on customer's requirement;
-Make documents on algorithm design, simulation results, software implement and test cases.
 Qualifications:
-Master or PHD in EE, CS or geomatics with the knowledge on GPS or hybrid positioning technologies;
-Familiar with programming languages, including C/C++, Matlab and Python, etc.
-Understanding on ARM core architecture and embedded system;
-Good personality and communication skills.
*Video: Software Engineer
 Responsibilities:
The candidate will be responsible for video decoder & encoder(MPEG2/MPEG4/H264/H265/VP8/VP9) driver development, integration and bug fixing, he will act as core development engineer to support AE team resolving critical bugs and also participating resolving system level video pipeline related issues.
 Qualifications:
-Master degree in Electrical Engineering or Computer Science
-C development experience;
- Experience of one of MPEG2/MPEG4/H264/H265/VP8/VP9 decoder or encoder
*Datacom Analog Designer
 Responsibilities:
Become a member of a world-class analog design team in providing high performance analog and mixed mode circuits for leading data communications and networking products, in 1gig and 10gig data rate. Designers have opportunities to design high performance analog-to-digital converters (ADC), digital-to-analog converters (DAC), filter, adaptive equalizers, clock and data recovery (CDR) circuits, and phase-locked loop (PLL) or other timing circuits. Team members participate in circuit architecture, circuit implementation, design review, layout, and silicon validation.
 Qualifications:
-High performance CMOS analog design experience for communications
-Design experience in analog-to-digital converter (ADC), including but not limited to flash, 2-step (sub-ranging, folding), pipeline, cyclic, sigma delta, and other techniques.
-Design experience in digital-to-analog converter (DAC) for driving high precision output, -such a 50ohm line driver.
-Design experience in filters and/or equalization, including but not limited to continuous time filter, discrete-time filters, finite-impulse response (FIR) filter, or decision-feedback equalizer (DFE).
-Design experience in Serdes and timing circuits such as PLL, CDR, TX and RX functions.
-Design experience in other analog functions is a plus, such as bandgap, regulator, crystal oscillator, etc.
-Knowledge in signal processing and communication theories is a plus.
*Datacom Digital Designer
 Job Description:
Become a member of a world-class digital design team in providing high performance digital circuits for leading data communications and networking products, in 1gig and 10gig data rate. Team members participate in circuit architecture, circuit implementation, design review, layout, and silicon validation.
 Job Requirement:
-Participate in the architecture, design and verification of highly integrated networking SoC products.
-Job function include block level micro-architecture design, RTL implementation and verification,
-logic synthesis, timing analysis, test pattern generation and silicon validation.
MINIMUM REQUIREMENTS / EDUCATION:
-M.S.E.E with knowledge of logic design using Hardware Description Language and related design tools.
-Knowledge of communication protocols such as Ethernet is preferred.
南京
 Responsibilities:
 Qualifications:
 *Central Engineering: Analog IC Layout (Nanjing)-CE
  Responsibilities
Be a part of the Central Analog design team. Your main responsibility is custom analog layout. You will be responsible for all levels of analog layout from block level up to the Analog top level integration and verification. You will communicate and get directions from experienced analog design engineers to ensure high quality.
  Qualifications
-Bachelor Degree of Electronics, Electronic Engineering or equivalen -Good communication skills in English.
-Be familiar with Unix OS.
-Understanding basic characteristic of transistor, resistor, capacitor and diode.
-Experience with Cadence or Silicon Canvas layout tools is plus.
-Experience with DRC/LVS verification tools is plus
成都
 Responsibilities:
-Documentation;
 Qualifications:
-MS or PHD in EE;
关于Marvell
Marvell (纳斯达克代码:MRVL) 是全球领先的完整芯片解决方案及Kinoma软件提供商,旨在实现 “Smart Life and Smart Lifestyle”。Marvell公司拥有从存储、物联网 (IoT) 、云基础设施、数字娱乐到家庭内容交付的多元化产品组合,将完整的平台设计与业界领先的性能、安全性、可靠性和效率相结合。作为消费电子、网络和企业系统的强大核心,Marvell公司令合作伙伴及其客户始终站在创新、性能和大众诉求的最前沿。Marvell公司致力于提高大众的生活体验,通过为世界各地的用户提供移动性和易于访问的服务,为社交网络、生活和工作增添价值。更多公司信息,请浏览公司网页
发表于 2016-3-17 18:35:26 | 显示全部楼层
请问版主  招收实习生吗?
发表于 2016-3-18 09:19:07 | 显示全部楼层
回复 1# Hwangbo
听说马威尔不是要卖了吗?
GMT+8, 2025-12-14 01:25 , Processed in 0.042636 second(s), 5 queries , Gzip On, Redis On.
