楼主: min4max
Cadence全套新版IC工具套件(2015年底版本),包括IC617以及其他工具套件
发表于 2016-1-20 16:46:57 | 显示全部楼层
此贴牛, 必须顶!
发表于 2016-1-20 17:32:14 | 显示全部楼层
回复 2# min4max
   大神,为什么新版软件不见readme里面提到:#=====================================================================
# Terms and Conditions of Use
Please read these Terms carefully prior to downloading or using the products. You must protect
the product(s) from unauthorized reproduction, publication, use or distribution. If any product
or portion thereof is copied to or used on a computer connected to a network, you must ensure
that the product may not be used or copied by unlicensed persons.
To help ensure that only authorized copies of Cadence software are being used, Cadence is implementing
monitoring technologies that will obtain and transmit to Cadence non-proprietary data in the event
a Cadence software product is tampered with.
No data will be collected or transmitted unless unauthorized
modifications to Cadence software product(s) are made or an unauthorized hosting of the Cadence license
server or software is detected.
By downloading the product(s), you confirm that you have the authority to act on behalf of your employer.
By downloading or using the product(s) you hereby agree to the use of such technology and transmission
of such non-proprietary data by Cadence.
是不是他们又将加密方式变回原来的了?
发表于 2016-1-20 19:02:55 | 显示全部楼层
求大神上传新版JasperGold啊!
求大神上传新版JasperGold啊!
求大神上传新版JasperGold啊!
发表于 2016-1-20 19:04:06 | 显示全部楼层
PS:CTOS新版叫Stratus了
发表于 2016-1-20 23:10:09 | 显示全部楼层
感谢感谢
发表于 2016-1-21 09:53:22 | 显示全部楼层
支持!!!!!!!!!!!!!!
发表于 2016-1-21 10:04:45 | 显示全部楼层
回复 1# min4max
谢谢。是否有任何正在进行的工作,以防止软件给家里打电话?
发表于 2016-1-21 10:06:08 | 显示全部楼层
thank you very much!
发表于 2016-1-21 10:16:19 | 显示全部楼层
I didn't see calibre in pandu folder? Where can I download it? Thank you!
发表于 2016-1-21 10:22:49 | 显示全部楼层
lz,thank you for your work  for chinese IC !
GMT+8, 2025-12-12 15:54 , Processed in 0.020616 second(s), 4 queries , Gzip On, Redis On.
