楼主: OpenHans
Cadence IC616 + MMSIM 141 安装
发表于 2015-10-14 15:58:50 | 显示全部楼层
回复 9# OpenHans
i changed my linux distribution because i was' t able to launch SPECTRE on centos 5.11.
Maybe due to an error on configuring my bashrc file, but i am not sure.
So i installed before cadence on ubuntu 12 with suggested additional packages which you can find on some online guides.
At least i reinstall all cadence products.
Good look
发表于 2015-10-17 20:03:43 | 显示全部楼层
export MMSIM_ROOT="/opt/cadence/installs/MMSIM141"
export PATH=$MMSIM_ROOT/tools/binPATH
export PATH=$MMSIM_ROOT/tools/dfII/binPATH
export PATH=$MMSIM_ROOT/tools/spectre/binPATH
export PATH=$MMSIM_ROOT/tools/ultrasim/bin:$PATH
发表于 2015-11-4 13:10:26 | 显示全部楼层
发表于 2016-10-12 11:41:10 | 显示全部楼层
我用的是打包的虚拟机安装的cadence ic616 请问安装好后怎么启动ic616啊 在终端中输入什么 小白一个 求解答
发表于 2016-11-24 04:07:15 | 显示全部楼层
centos有时冲突,我现在还是用RHLE
发表于 2017-4-7 11:39:42 | 显示全部楼层
thank you
发表于 2017-4-11 12:06:36 | 显示全部楼层
who know it?
发表于 2017-12-6 12:04:48 | 显示全部楼层
有人有解决方法吗
发表于 2023-4-16 22:36:46 | 显示全部楼层
putechen 发表于 2015-10-12 11:07
我前段时间也碰到这个问题,虽然暂时解决了,但是还没没想通。
1.最开始用ic51+51自带的spectre,source了i ...
我去试试,你说的这几种情况
GMT+8, 2025-12-25 23:23 , Processed in 0.017329 second(s), 3 queries , Gzip On, Redis On.
