查看: 1354|回复: 0
[招聘] 芯得职位 多多
发表于 2015-8-12 17:57:07 | 显示全部楼层 |阅读模式
HSS/DDR Application Engineer
简历发 [url=mailtoffer@hi-talent.net]offer@hi-talent.net[/url]
Responsibilities:
HSS/DDR Application Engineer is working oncutting-edge High Speed SerDes (HSS) and DDR IP engagement and support forHI-TALENT’S CLIENT COMPANY worldwide clients. By employing the industry leadingtools, state of the art methodology, and innovative semiconductor leadingtechnologies ranging from 32nm to 14nm and beyond, you will be participatingin:
?Provide direct technical customer supportand assistance to enable customers to successfully use HSS/DDR in their chip
?Engage in hardware bring up and qualitytest support, including issue debug, electrical parameter measurement andHSS/DDR interface/register analysis
?Enable physical integration of HSS/DDR inbackend design process
?Provide customer feedback on requirementsfor HSS/DDR to internal development team
?Provide customer reference of board levelcircuit design on HSS/DDR interface
?Write application notes and reviewspecifications for HSS/DDR
Requirements:
?ME/EE/CS or background in related areas.
?At least 3 years industry applicationengineering experience.
?Experience and knowledge in one or more ofthe following areas:
HSS or DDRcustomer application support
Hardwarebring up and quality test support
High speedlink or memory interface protocols including JEDEC, PCIE and CEI
High speed linkor memory interface design and verification experience is a plus
High speedboard design and validation experience is a plus
?Good understanding of chip backend designflow and methodology.
?Able to conduct flexible hour technicalmeetings, seminars and trainings to customers.
?Business travel within greater Chinaregion is required.
?Good English skills, communication skills,and willingness to work with a global team. Skill in other languages is a plus.
?Good learning competency, self-motivated,and ability to work in diverse areas in a flexible and dynamic environment.
Analog Design Engineer
is working on cutting-edge Analog andMixed-signal IP development for HI-TALENT’S CLIENT COMPANY worldwide clients,including High Speed Serial Links, PLL, ADC/DAC, etc. By employing the industryleading tools, state of the art methodology, and innovative semiconductorleading technologies ranging from 32nm to 14nm and beyond, you will be participatingin the definition, design, layout, and characterization of the analog andmixed-signal circuits.
Requirements:
ME/EE or background in related areas.
At least 2 years industry analog design orverification experience.
Able to design circuits that operateeffectively within the process window, and supervise layout floorplan anddesign.
Demonstrate good knowledge and experiencein advanced analog and mixed-signal circuit design, experience in one or moreof the following circuits, is a plus: Bias, Bandgap, Voltage Regulators
VCO, Charge Pump, Clock Divider, PFD
Driver / Receiver
Serializer / Deserializer
Phase Interpolator
Familiar with transistor level circuit EDAtools (Virtuoso, Spectre, HSPICE, etc.).
Good understanding of advancedsemiconductor technology process and device physics.
Experience with system level modeling andsimulation by MATLAB, Verilog-A or C/C++ is a plus.
Logic Verification Engineer
is working on cutting-edge Digital andMixed-signal IP development for HI-TALENT’S CLIENT COMPANY worldwide clients,including High Speed Serial Links, Protocols, Memory Interface, etc. Byemploying the industry leading tools, state of the art methodology, andinnovative semiconductor leading technologies ranging from 32nm to 14nm andbeyond, you will be participating in the front-end logic verification or mixedsignal verification.
Requirements:
Research and/or development experience inone or more of the following areas:
Logic verification on the basis of thetarget system specification
Mixed-signal model verification on advancedtechnologies
Proficiency in programming and/or scriptinglanguages is a plus
Knowledge on Protocols, High Speed Serdesor DDR is a plus
Experience in one or more of the followingapplication domains, is a plus
High performance computing system,processor, chipset and ASICs
High end communication, networking, mobileand data center applications
Digital signal processing, sensor andInternet of Things
Other emerging IT technology and industryareas
Memory Design Engineer
简历发 offer@hi-talent.net
is working on cutting-edge embedded MemoryIP development for HI-TALENT’S CLIENT COMPANY worldwide clients, includingSRAM, RA, RF, TCAM, ROM, etc. By employing the industry leading tools, state ofthe art methodology, and innovative semiconductor leading technologies rangingfrom 32nm to 14nm and beyond, you will be participating in:
Evaluate and optimize memory architectureand methodology in cutting-edge technology
Design full custom circuits in the embeddedmemory arrays Simulate,verify and analyze memory functionality, performance and statistical margin
Perform functional verification,characterization and model-to-hardware correlation
Requirements:
ME/EEor background in related areas.
At least 2 years industry circuit design orverification experience.
Experience in one or more of the followingembedded or standalone memory products/circuits: SRAM, DRAM, Flash, RA, RF,TCAM, ROM, etc.
Experience with statistical circuitanalysis and simulation is a plus.
Chip Design Engineers/BackendEngineer
are working on cutting-edge SoC (System ona Chip), ASIC, High Performance Processor, Chipset, Digital/Analog and Mix-signalCircuit IP design for our clients inside and outside of HI-TALENT’S CLIENTCOMPANY. By employing the industry leading tools, state of the art methodology,and innovative semiconductor technologies ranging from 45nm to 14nm and beyond,you will be participating in the development of :
Back-end implementation and optimization
Package and electrical design,
Electronic Design Automation (EDA) &methodology development and deployment
Chip hardware validation
Requirements:
CS/EE or background in areas related todigital or analog chip design
2 year+ work experience
Research and development experience in oneor more of the following areas:
ASIC back-end design methodology: Knowledgeof floor planning, physical design, timing, DFT, signal/power integrity, packaging,synthesis, and other back-end activities
EDA algorithm, tool, and methodologydevelopment.
Experience/knowledge in analog andmixed-signal IP design, test and evaluation with Bulk CMOS, BiCMOS, SiGe, orSOI technologies
- Proficiency in Verilog/VHDL, andfamiliarity with programming and scripting languages is a significant plus
Experience in one or some of theapplication domains, will be a plus
High performance computing (servers)system, processor, chipset and ASICs
Communication, networking and wirelessapplications
Digital signal processing and RISCProcessor architecture
Digital media, audio/video graphic andgaming processing
Consumer electronics applications
High Speed Interface/Serdes applications
Good software background and strong C/C++skill
Other emerging technology and industryareas
Good English skills, communication skills,and willingness to work with a global team. Skill in other languages will be aplus.
Good learning competency and ability towork in diverse areas in a flexible environment
Best Regards
Jane.Jin 金娟
Principal Consultant & General Manager @ Hi-Talent Consulting Co.,Ltd.
上海芯得企业管理咨询有限公司
上海芯相会企业管理咨询有限公司
Mob:            18502155252
E-Mail:         Jane-Jin@hi-talent.com
微信:       xinde_jane
QQ:             1600548210
Weibo:          http://weibo.com/u/1716864892
webside
www.hi-talent.cn
GMT+8, 2025-12-28 10:21 , Processed in 0.048444 second(s), 7 queries , Gzip On, Redis On.
