查看: 7953|回复: 17
[求助] 关于guardring
发表于 2015-7-28 11:06:16 | 显示全部楼层 |阅读模式
请问如何对mos管进行自动围一圈guardring?
发表于 2015-7-28 13:35:20 | 显示全部楼层
skill 或許有
发表于 2015-7-28 14:36:10 | 显示全部楼层
回复 1# maomaoyu2000
IC616里面有fluid guardring, 很方便
 楼主| 发表于 2015-7-28 15:14:37 | 显示全部楼层
回复 3# jian1712
请问fluid guardring是什么?在哪可以找到?5141有吗?
发表于 2015-7-28 15:17:50 | 显示全部楼层
回复 4# maomaoyu2000
5141没有,你安心用MPP吧
发表于 2015-7-28 19:25:41 | 显示全部楼层
标题
回复 5# jian1712
    如果在xl下再配合mpp可以实现
 楼主| 发表于 2015-7-29 09:34:26 | 显示全部楼层
回复 6# trumen
   这样是可以的,但是space 是怎么确定的,也就是说mos管和guardring 的距离是怎么设置的?
发表于 2015-7-29 09:48:54 | 显示全部楼层
你的tf file 要有以下的guard-ring 相關設定
; LX RULES
lxRules(
lxMPPTemplates(
;( name [masterPath] [offsetSubpaths] [encSubPaths] [subRects] )
;  masterPath:
;  (layer [width] [choppable] [endType] [beginExt] [endExt] [justify] [offset]
;  [connectivity])
;  offsetSubpaths:
;  (layer [width] [choppable] [separation] [justification] [begOffset] [endOffset]
;  [connectivity])
;  encSubPaths:
;  (layer [enclosure] [choppable] [separation] [begOffset] [endOffset]
;  [connectivity])
;  subRects:
;  (layer [width] [length] [choppable] [separation] [justification] [space] [begOffset] [endOffset] [gap]
;  [connectivity] [beginSegOffset] [endSegOffset])
;  connectivity:
;  ([I/O type] [pin] [accDir] [dispPinName] [height] [ layer]
;   [layer] [justification] [font] [textOptions] [orientation]
;   [refHandle] [offset])
  (NTap_1CT_Ring
    (("OD" "drawing")        1.0        nil        flush        0.0        0.0        center        0.0)
    nil
    ((("NW" "drawing")        -0.4        nil        0.4        -0.4)
     (("SN" "drawing")        -0.5        nil        0.5        -0.5)
     (("IN" "drawing")        0.05        t        -0.05        0.05)
    ((("CO" "drawing")        0.4        0.4        t        -0.7        left        0.6        -0.3        -0.3        minimum        nil        0.0        0.0)
  (NTap_2CT_Ring
    (("OD" "drawing")        2.0        nil        flush        0.0        0.0        center        0.0)
    nil
     (("CO" "drawing")        0.4        0.4        t        -1.7        left        0.6        -0.3        -0.3        minimum        nil        0.0        0.0)
  (NTap_2CT
    nil
    ((("NW" "drawing")        -0.4        nil        0.4        0.4)
     (("SN" "drawing")        -0.5        nil        0.5        0.5)
     (("IN" "drawing")        0.05        t        -0.05        -0.05)
  (NTap_1CT
    nil
  (PTap_1CT_Ring
    nil
    ((("SP" "drawing")        -0.5        nil        0.5        -0.5)
  (PTap_2CT_Ring
    nil
  (PTap_1CT
    nil
    ((("SP" "drawing")        -0.5        nil        0.5        0.5)
  (PTap_2CT
    nil
) ;lxMPPTemplates
发表于 2015-7-29 09:51:16 | 显示全部楼层
; LX RULES
lxRules(
lxMPPTemplates(
;  masterPath:
;  [connectivity])
;  offsetSubpaths:
;  [connectivity])
;  encSubPaths:
;  [connectivity])
;  subRects:
;  connectivity:
  (NTap_1CT_Ring
    nil
  (NTap_2CT_Ring
    nil
  (NTap_2CT
    nil
  (NTap_1CT
    nil
  (PTap_1CT_Ring
    nil
  (PTap_2CT_Ring
    nil
  (PTap_1CT
    nil
  (PTap_2CT
    nil
) ;lxMPPTemplates
发表于 2015-7-29 09:54:46 | 显示全部楼层
bindkey是 shift + g  你試試看
GMT+8, 2025-9-19 02:59 , Processed in 0.019018 second(s), 5 queries , Gzip On, Redis On.
