查看: 2408|回复: 1
[求助] TQ2440 gflash erase
发表于 2015-6-23 11:25:42 | 显示全部楼层 |阅读模式
悬赏10资产未解决
开发板TQ2440,在erash nor flash时发现如下问题:Open On-Chip Debugger 连接正常,
但是gflash erase process时发现:
Error: Address translation failure
Warn : memory read caused data abort (address: 0x00000020, size: 0x2, count: 0x1)
Warn : memory read caused data abort (address: 0x00000022, size: 0x2, count: 0x1)
Warn : memory read caused data abort (address: 0x00000024, size: 0x2, count: 0x1)
 楼主| 发表于 2015-6-23 11:28:46 | 显示全部楼层
Open On-Chip Debugger 0.6.0-dev-snapshot
For bug reports, read
Info : only one transport option; autoselect 'jtag'
DEPRECATED! use 'adapter_khz' not 'jtag_khz' 6000 kHz
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
Info : device: 4 "2232C"
Info : deviceID: 341266712
Info : SerialNumber: FTXLZBZEA
Info : Description: USB<=>JTAG&RS232 A
Info : clock speed 6000 kHz
Info : JTAG tap: s3c2440.cpu tap/device found: 0x0032409d (mfg: 0x04e, part: 0x0324, ver: 0x0)
Info : Embedded ICE version 2
Info : s3c2440.cpu: hardware has 2 breakpoint/watchpoint units
GMT+8, 2025-9-17 03:05 , Processed in 0.017346 second(s), 6 queries , Gzip On, Redis On.
