查看: 3606|回复: 0
上海猎头网pc技术招聘职位
发表于 2004-5-25 00:09:32 | 显示全部楼层 |阅读模式
上海猎头网pc技术招聘职位
■■上海猎头网为企业和个人提供专业的猎头服务。对个人完全免费。未经您本人同意,我们不会向任何第三方透露你的个人信息,包括姓名
、住址、联系方式和目前所在公司。
■■以下为本公司受客户委托正在招聘的职位,您可以把您的意向、主要建立和期望收入,发送到我们的猎头服务信箱:hr@100job.net
■■您也可以通过访问http://www.100job.net来了解更多信息和进行人才报价。当然您也可以用一下方式进行联络和咨询:
     qq:37558689
     msn:weibin_1@hotmail.com
■■职位列表
  ◇◇Staff Hardware Engineer
  ◇◇Sr. Hardware Engineer
  ◇◇Staff BIOS Engineer
  ◇◇Sr. PC Board (Layout) Designer 3
详细信息如下:
■■Staff Hardware Engineer
Critical Job Elements
Works as a hardware development engineer in the China Design Center.
Candidate will initially be a part of a small engineering team working in the design, fabrication, and validation of Intel
Architecture products and systems.
Work includes the specification, implementation, fabrication, modification, and evaluation of printed circuit board
assemblies and systems.
Candidate will be expected to work closely with the project team to ensure the on schedule delivery of working prototypes and
production units.
Strong leadership and interpersonal skills as well as familiarity with, and the ability to follow, ISO 9001:2000 processes
are required.
Solid communication skills, both written and verbal, in English and Chinese, are also required.
Qualifications
Requires BS or MS degree in Electrical Engineering, or Computer Engineering or equivalent with at least 7 years of  Intel
Architecture design experience.
Expert knowledge of Intel Architecture design, associated buses (PCI, PCI-X, Hublink 2.0, DDR266, etc.) and standard PC
motherboard interfaces interfaces (SCSI, IDE, 10 base T, 100 base TX. and Gigabit Ethernet, etc.) is required. Knowledge of
DC-DC converter and/or VRM design is highly desirable.
Work assignments require knowledge of digital and analog design techniques, a high degree of creativity, good communication
skills and the ability to work independently or as part of a team.
Design experience with ORCAD Capture CIS and/or Concept, ALLEGRO, Phoenix BIOS cores, VERILOG, Lattice, XILINX and/or ALTERA
tools is highly desirable but not required.
■■Sr. Hardware Engineer
Candidate will be expected to work closely with the project team to ensure the delivery of working prototypes and production
units.
Good communication skills, both written and verbal in Chinese and English, as well as familiarity with, and the ability to
follow, ISO 9001:2000 processes are desired in this position.
Qualifications
Requires BS or MS degree in Electrical Engineering, or Computer Engineering or equivalent with at least 5 years of Intel
Solid knowledge of Intel Architecture chipsets, associated buses (PCI, PCI-X, Hublink 2.0, DDR266, etc.), and standard PC
Knowledge of DC-DC converter and/or VRM design is highly desirable.
■■Staff BIOS Engineer
Works as the lead BIOS engineer of the China Design Center.
Candidate will initially work in a small engineering team in the design, fabrication, and validation of Intel Architecture
Candidate will be expected to work closely with the project team and is wholly responsible for the BIOS programming required
to ensure the delivery of working prototypes and production units.
are required.
Qualifications
Architecture design experience. Solid level knowledge of Intel Architecture hardware design is required. Work assignments
require a high degree of creativity, a strong sense of ownership for his or her projects, advanced engineering skills,
excellent communication skills, and the ability to work independently or as part of a team. Candidate will possess a solid
working knowledge of Phoenix NuBIOS, ServerBIOS, or FirstBIOS cores, as well as C programming and Intel Assembly language.
Candidate should have significant experience with initial debug and “bring-ups” of new Intel Architecture designs and the
use of debugging tools such as American Arium ICE, oscilloscopes, and logic analyzers. Candidate should posses general
knowledge of, or familiarity with, current technologies such as ACPI, APM, SMI, PNP, PCI, USB, SMBIOS, DMI, IPMI, multi-boot,
MP, PXE, etc.. A basic understanding of circuitry and logic design is required and a basic understanding of device drivers is
a plus.
■■Sr. PC Board (Layout) Designer 3
Perform high-density, digital/analog PTH/SMT Printed Circuit Board layout with Cadence Allegro v15.x. Understand the company
’s Design For Manufacturability/Design For Test thrusts, communicate these requirements to engineering peers, and ensure
compliance during layout.  Also, comprehend controlled impedance, matched length, and EMI/EMC requirements during layout.
Implement design rules/procedures to ensure designs are free of layout process defects.  Support delivery of timely, accurate
PCB design and complete documentation.  Good communication skills, both written and verbal in Chinese and English, as well as
familiarity with, and the ability to follow, ISO 9001:2000 processes are desired in this position
Qualifications
Varied board-related technical background with working knowledge of board fabrication processes and board assembly processes.
Experience with blind/buried vias, buried resistance, buried capacitance, and alternative board construction techniques.
Thorough knowledge of IPC and other industry standards,  Experience with Cadence Allegro, good knowledge of PC-based computer
systems, both hardware and software. Above-average organizational skills with ability to manage multiple projects
simultaneously. Ability to work with little supervision, interface directly with engineering peers.  Ideal candidate would
have an associate’s degree, and a minimum of 10 years of layout experience.
GMT+8, 2025-12-15 03:30 , Processed in 0.019788 second(s), 8 queries , Gzip On, Redis On.
