查看: 2870|回复: 4
推荐一个研究STT-RAM用的模型
发表于 2015-3-11 11:23:36 | 显示全部楼层 |阅读模式
给大家推荐一个研究STT-RAM用的模型,可以模拟不同MTJ配置下STT-RAM的延迟和功耗特性。
模型由University of Virginia开发,使用hspice 2011编译 mtj_hplp_1.0.0.zip (80.2 KB , 下载次数: 25 )
发表于 2015-3-11 19:38:27 | 显示全部楼层
下来看看
发表于 2015-5-8 19:15:20 | 显示全部楼层
你好,我怎么运行时报错呀?
hsp-vacomp: Warning: Variable 'min_float' in module 'ElectronTrans' is never set.
hsp-vacomp: Warning: Variable 'min_float' in module 'IncUpTransDown' is never set.
hsp-vacomp: Warning: Variable 'min_float' in module 'IncUpTransUp' is never set.
hsp-vacomp: Warning: Variable 'min_float' in module 'IncDownTransUp' is never set.
hsp-vacomp: Warning: Variable 'min_float' in module 'IncDownTransDown' is never set.
hsp-vacomp: Error: Nodes which are accessed must have a discipline specified.
hsp-vacomp:         ['MTJ.va',200]
** error **
During Verilog-A Device processing:
    Failed to compile the Verilog-A File,
        'c:\users\zhy\desktop\eetop.cn_mtj_hplp_1.0.0\MTJ.va'.
  lic: Release hspice token(s)
你遇到过这种情况吗?
发表于 2017-4-18 16:38:39 | 显示全部楼层
你好,运行时报错了这种算是什么情况?
hsp-vacomp: Synopsys HSPICE Verilog-A Compiler Version 1.52.021608.
hsp-vacomp: Copyright (C) 2008 Synopsys, Inc. All Rights Reserved.
hsp-vacomp:
hsp-vacomp: Error: syntax error
hsp-vacomp:         ['MTJ.va',24]
hsp-vacomp:           real rand_noise = 0.0;              //Random number sequence variable
hsp-vacomp:                           ^
** error **
    Failed to generate the loadable component names file from the Verilog-A File,
         'MTJ.va'.
               ***** job aborted
还有,MTJ.va文件中,
`include "disciplines.vams"
`include "constants.vams"
这两个文件是什么?怎么没有?
发表于 2018-1-10 16:48:20 | 显示全部楼层
下来看看
GMT+8, 2025-12-25 11:23 , Processed in 0.024330 second(s), 8 queries , Gzip On, Redis On.
