楼主: snk88
ADS2015.01 win64/linux patch
发表于 2015-6-10 19:37:13 | 显示全部楼层
正在学习这个软件,下下来看能不能用
发表于 2015-6-13 02:32:52 | 显示全部楼层
非常感谢,正在找呢
发表于 2015-6-14 16:25:16 | 显示全部楼层
为什么无法运行Simulate,运行进度窗口提示不能运行,信息如下:
Simulation Messages
Error detected by hpeesofsim during circuit set up `SP1'.
    An appropriate license for linear features is not available.  This
    feature must be licensed before it can be used.
        FlexLM error message:
        Linear Simulator
        The desired vendor daemon is down
        Possible Causes:
        1. lmgrd process is running, but not the agileesofd vendor daemon. The software was able to contact the license server (lmgrd), but the vendor daemon (agileesofd) did not respond.
        2. agileesofd vendor daemon has crashed or has been terminated.
        3. lmgrd process was shut down manually or via LMTools with -x lmdown option
        4. On Windows platform, this could be caused by waking up from Sleep or Hibernation mode.
        5. The logfile was unable to be removed.
        Troubleshooting Tips:
        1. Check the license server's debug log file and try lmreread.
        2. Reboot your system to restart the license service.
        3. Use LMTools to clear your previous setup first, then restart license setup wizard to re-configure your license.
        4. Shut down the lmgrd process and check that lmgrd or agileesofd processes are no longer running. Restart the license server.
        5. Stop lmgrd via kill pid (UNIX) withough -9 argument or stop the lmgrd process through the Windows Task Manager or Windows Service.
        6. Close all processes that are reading the logfile.
        License Requested:  sim_linear
        License path:  D:\Keysight\EEsof_License_Tools\license.lic
Status / Summary
hpeesofsim (*) 430.shp Dec  7 2014
    (64-bit windows built: 12/07/14 09:11:55)
Copyright Keysight Technologies, 1989-2015.
发表于 2015-6-15 11:09:31 | 显示全部楼层
回复 1# snk88
楼主,你这个LIC没法防真附件这份设计,请楼主解决一下,谢谢!
ChannelSimulatorTutorial_wrk.zip (734.2 KB , 下载次数: 34 )
 楼主| 发表于 2015-6-15 19:30:05 | 显示全部楼层
回复 314# cxt668
试试,我只是搬运工,对应的hostid改成你自己的
  1.     FEATURE sim_channel agileesofd 4.1 31-dec-2050 uncounted VENDOR_STRING="5404a625f11b : GBZBNJV GRFDGPJ WELDCYP BHAUBBO WUIDLJV HYMDIBJ TYMYMXU RJ" HOSTID=5404a625f11b ISSUER="Pizote Azure" SIGN="0248 375D C285 29F0 9898 859B 8717 0DD0 BBF4 FBAC 9A00 8290 6835 E3B2 B38C 49B3 E72C 30FC 398E D7FD 4B01"
  2. FEATURE e_sim_trans_conv_pk8 agileesofd 4.1 31-dec-2050 uncounted VENDOR_STRING="5404a625f11b : ELPDJAN GYHN1AO CTFGPHE ULXJOAM GOCRZDW SMSNWVZ UMJQ1LP VSONSDD HSOIWZO FDDJ" HOSTID=5404a625f11b ISSUER="Pizote Azure" SIGN="02FF 55AB D956 79F8 963E 58A1 EA5E 409B 0087 8A9D B802 9F49 A65B 1E88 7A15 8117 CE59 EEBE 8A48 7942 DC0E"
  3. FEATURE b_ads_inclusive agileesofd 4.1 31-dec-2050 uncounted VENDOR_STRING="5404a625f11b : UQHKXFP AQCOTQN LFDDJFR IPUCZLM DJYBBHM WYYNBHH EKYANVH HUJJOLS EFRDA" HOSTID=5404a625f11b ISSUER="Pizote Azure" SIGN="0011 2828 F273 2374 848F 646A 40C4 DFDD FE4E 7674 7E02 43B6 4B66 29AA AAC0 1C9C 84D6 AEDE 65A0 5989 371A"
    复制代码
发表于 2015-6-16 20:17:03 | 显示全部楼层
回复 2# jitongw
感谢啊。
发表于 2015-6-18 01:56:42 | 显示全部楼层
yarak kürek
发表于 2015-6-18 01:57:26 | 显示全部楼层
sikikler
发表于 2015-6-18 23:38:13 | 显示全部楼层
Empro 3D Components的feature能加一下么?多谢。。
发表于 2015-6-24 23:53:25 | 显示全部楼层
希望有用,已经解压
GMT+8, 2025-12-7 17:39 , Processed in 1.904829 second(s), 6 queries , Gzip On, Redis On.
