查看: 1270|回复: 0
[招聘] 【Marvell全职】Senior ASIC Design Engineer
发表于 2014-11-3 14:02:01 | 显示全部楼层 |阅读模式
Job Title: Senior Engineer,ASIC Design
Department: IC R&D
Derived fromhistoric Data Storage and Datacom IC R&D, the IC R&D - Shanghai developand implement advanced digital signal processing technologies and integrateadvanced mixed-signal technologies for Storage Read Channel, Gigabit Ethernet,SATA PHY, Digital TV and other products. The digital design group is dynamic, excitingand rewarding, with many opportunities for professional growth for a motivatedcandidate.
You enjoy tofollow through from circuit architecture conception to circuit implementationand verification, and to master the challenges of advanced deep sub-micronprocess technologies. You will also work on pure ASIC flow or full custom ASICdesign flow to achieve high speed clock requirement of Giga Hz level and lowpower design target. You work closely with your peers, system architects,application engineers, field application engineers, and product engineers tofind the optimal and most cost efficient solution for our customers. We provideample opportunity to put your creativity to test.
Description:
- Design anddevelop high-speed and low power digital circuits for the digital signal processingcore of the different product lines using state-of-the-art IC designmethodologies and design flows.
- Designhigh-speed data paths to implement arithmetic functions and signal processingalgorithms.
- Write RTL codefor high-speed and multi-clock domain designs.
- Performfunctional verification of designs on block and chip level.
- Performsynthesis and pre- and post-layout timing closure.
- Oversee andguide layout and physical verification activities.
- Contribute testspecifications and support evaluation of the design in coordination withapplication and product engineering.
- Provide designdocumentation, descriptions and information to application engineers, fieldapplication engineers, product engineers, and customers.
Qualifications:
-MSEE with 2+years
-Understanding thebasic Analog/digital circuit building blocks.
-Able to usespice, verilog and layout tools for circuit and logic design
-Able to performfunctional and timing verification for circuit and logic design
-Understanding Cand Perl programming.
If you have any interest in the position, please send your bilingual resume as attachments to emilyye@marvell.com or marvellresume@126.com
Subject of your email should be “Your Name_University_Applied Position Title”
GMT+8, 2025-12-27 04:36 , Processed in 0.011061 second(s), 4 queries , Gzip On, Redis On.
