查看: 1112|回复: 0
[招聘] 【Marvell全职】Silicon Validation/Application Engineer
发表于 2014-10-22 10:10:27 | 显示全部楼层 |阅读模式
Job Title: Silicon Validation/Application Engineer
Department: Channel system
Description:
Silicon Validation Engineering group forRead Channels is responsible for validating all read channel devices designedby Marvell. The activities also include performance measurement and automationof the tools used for validating the read channel. The group is alsoresponsible for the hardware and software design of all tools required for theabove two activities.
Qualifications:
B.S.E.E + 2 year experience or M.S.E.E + 0years.
Experience working in an IC testingenvironment with equipment such as Oscilloscopes and AWG's is desired but notrequired.
Proficiency with Matlab or Python isdesired but not required.
Direct experience with Read Channels andhard disk drives is desired, but not required.
Responsibility:
- Design and execute system level testsfor complex mixed signal ICs using standard test equipment such asOscilloscopes, network analyzers, etc.
- Work with designers to debug, understandand document new designs.
Provide technical documentation,descriptions and information to Field Application Engineers, Test Engineers andcustomers.
- Write and maintain software used toautomate bench testing. This is done in the MATLAB environment for now; maymove to other tools in future.
- Generate professional validation reportsand comparative performance analysis of the read channel devices.
- Work with DSP and design teams to findthe best optimization procedures for Marvell read channel products.
- Make sure we can showcase the best readchannel performance on customer drives.
If you have any interest in the position, please send your bilingual resume as attachments to emilyye@marvell.com or marvellresume@126.com
Subject of your email should be “Your Name_University_Applied Position Title”
GMT+8, 2025-12-27 02:30 , Processed in 0.014169 second(s), 4 queries , Gzip On, Redis On.
