查看: 1877|回复: 1
[招聘] 【美光上海招聘】Senior Firmware Validation Engineer
发表于 2014-10-14 14:24:32 | 显示全部楼层 |阅读模式
急招Senior Firmware Validation Engineer一名,是Post-Silicon Validation。工作地点在上海外高桥自贸区。
有意者请发简历至ysheng@micron.com
JD 如下:
This job is  responsible forvalidating Micron internal developed UFS device on below area:
Develop and code test case to validateinternal designed FW and identify the bug with high quality and shortthroughput time
Identify and report UFS device issueson designed test platform and support the DOE (design of experiment) datacollection plus analysis
Validate the hardware protocol fitsthe JEDEC standard
Publish the final validation report tomarketing
Experience in script dev such aspython and perl
• Strong software design, coding anddebug skills.
• Proven skills to understand andclarify the technical notes independently, such as SAS/SATA/UFS JEDEC
• Knowledge of embedded system
• Experienced with lab tools: LA, OSC,TRACE, in circuit emulators
• Experience of working in a multi-timezone and distributed team environment.
• Good teamwork
UFS product is a cutting edgemanaged memory product in industry. This is targeting to be used on high endmobile device and/or tablets for data storage by providing high troughtputperformance with low power consumption.
 楼主| 发表于 2014-10-17 15:02:54 | 显示全部楼层
自己顶
GMT+8, 2025-12-25 08:27 , Processed in 0.019815 second(s), 5 queries , Gzip On, Redis On.
