查看: 23517|回复: 37
求救啊!QRC (EXT13.2) 在Virtuoso里找不到
发表于 2014-9-25 04:00:15 | 显示全部楼层 |阅读模式
QRC 在Virtuoso Layout里显示“Loading QRC menu”,查了下说是环境设置问题,我检查自己的.bashrc看了没问题。
接着查,又有人说是64位软件在32位OS上的问题。我想到的redhat的确是32位的,并且在启动virtuoso时会有提示说64位不支持,“forced to use 32bit”,我接着又去查了下一个cadence安装教程“RHEL_6安装Cadence ic616和MMSIM13。pdf”,里面提到过一句“6:ic616打补丁(安装包中patch河skf为64为专用)” 。
现在不知道怎么解决了,请大家给我出出注意吧!
.bashrc如下:
################                 Bash for Cadence
export CADENCE_HOME=/home/tyyang/cadence
export CDS_LIC_FILE=5280@tyyang
export LANG=C
export CDS=$CADENCE_HOME/ic616/installs
export LM_LICENSE_FILE=/home/tyyang/cadence/ic616/installs/share/license/license.dat
# Some of these variables are used by various other tools.
# Set them to be safe
export CDSDIR=$CDS
export CDSHOME=$CDS
export CADENCE_DIR=$CDS
export CDS_INST_DIR=$CDS
# Set Spectre defauts and netlisting mode
export SPECTRE_DEFAULTS=-E
export CDS_Netlisting_Mode=Analog
# This environment variable enables Spectre HB
export CDS_SPECTRERF_FBENABLE=1
# Turn on the Palette feature.  LSW no longer works, but many new features available
export CDS_USE_PALETTE
#Support for 64-bit executables (this should be set for 64-bit hosts)
export CDS_AUTO_64BIT=ALL
## Master IC PATH
## Set it before system PATH
export PATH=$CDSDIR/binCDSDIR/tools/dfII/binCDSDIR/tools/binCDSDIR/tools/plot/bin:$PATH
## Cadence Analog Simulators (MMSIM) - Spectre, SpectreRF
export MMSIMHOME=$CADENCE_HOME/mmsim13/installs
export PATH=$MMSIMHOME/bin:$MMSIMHOME/tools/bin:$PATH
## Cadence QRC Extraction (EXT) - parasitic extraction for RLCK
##这里是QRC的设置
## Note: QRC must appear in the PATH before Assura executables
export QRC_HOME=$CADENCE_HOME/ext132/installs
export PATH=$QRC_HOME/bin:$QRC_HOME/tools/bin:${PATH}
## Cadence Assura (ASSURA) - DRC. LVS, parasitic extraction
##这里是DRC,LVS的设置
## These executables should be on the PATH after DFII executables
export ASSURAHOME=$CADENCE_HOME/assura414/installs
export PATH=${PATH}:$ASSURAHOME/bin:$ASSURAHOME/tools/bin:$ASSURAHOME/tools/assura/bin
alias lmli='/home/tyyang/cadence/ic616/installs/tools/bin/lmgrd -c /home/tyyang/cadence/installs/ic616/share/license/license.dat'
## Set up OA
## All Cadence tools (Assura, MMSIM, ....) should be reconfigured to use
## master IC OA PATH if they were not done so during install (use the
## iscape install utility in $CADHOME to reconfigure).
export OA_HOME=$CDSDIR/oa_v22.43.018
## Set up for Cadence unsupported systems such as Ubuntu Linux
export OA_UNSUPPORTED_PLAT="linux_rhel50_gcc44x"
## LD_LIBRARY_PATH variable should not be used whenever possible.
## Rules for handling LD_LIBRARY_PATH:
## Never ever set LD_LIBRARY_PATH globally.
## If you are forced to set LD_LIBRARY_PATH, do so only as part of a wrapper.
#export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$CDSDIR/tools/lib/64bit"
## Specify a search order for .cdsenv
## Load .cdsenv in working directory ($CWD) if it exists, otherwise
## .cdsenv in $HOME directory if it exists.
export CDS_LOAD_ENV=CSF
## Set up NCSU CDK
## This is optional for educational purpose; use foundry provided PDKs
## instead for production projects by including foundry PDKs in cds.lib
## in the working directory.
#export CDK_DIR=/opt/PDKs/ncsu-cdk-1.6.0.beta
## browser setup for Cadence Help
export MOZILLA_HOME=/usr/bin/firefox
发表于 2014-9-25 09:08:47 | 显示全部楼层
把这个去掉  应为你的OS是32bit
 楼主| 发表于 2014-9-25 09:38:02 | 显示全部楼层
回复 2# chipless
注释掉了! 但是问题依旧,还是木有QRC,有QRC那个按钮,点开下拉菜单只有一个,写着loading QRC menu。
发表于 2014-9-25 11:59:28 | 显示全部楼层
回复 3# the_rebrith
   你单独启动qrc呢   终端里面 qrc&
 楼主| 发表于 2014-9-25 13:37:17 | 显示全部楼层
回复 4# chipless
好的!!感谢!明早我试下然后告诉你!!(时差党。。。)
 楼主| 发表于 2014-9-25 22:34:56 | 显示全部楼层
回复 4# chipless
我试了qrc&,提示command not found,但的确安装了ext13.2了,也用cadence.pat, cadence_patch.sh和sfk patch过了。还有可能是什么问题呢? 请帮我出出注意吧! 谢谢谢谢!!
 楼主| 发表于 2014-9-26 07:46:30 | 显示全部楼层
回复 4# chipless
我又发现了疑点,就是我现在在用IBM 8HP做设计,每次要source个脚本:#!/bin/bash
# enviornment file for IBM_PDK (8hp)
#export AMS=/ad/eng/opt/ibm-cmos/IBM_PDK
# VAR FOR EXT 13.2, not used by Cadence, but a convientient place to define it
# path/bin is exported at the end of this file
export QRC_HOME=/home/tyyang/cadence/ext132/installs
# IC package install directory
export CDS=/home/tyyang/cadence/ic616/installs
# use assura 414
export ASSURAHOME=/home/tyyang/cadence/assura414/installs
# MMSIM PACKAGE (7.2)
export MMSIM=/home/tyyang/cadence/mmsim13/installs
# cadence license server
# prevent assura from using LD_ASSUME_KERNEL
export NO_ASSUME_KERNEL=yes
# add the .cdsenv file from CWD, and save to the CWD
export CDS_LOAD_ENV=CWD
# everyone's locks should be local, so don't wait too long for clsbd
export CLS_CLSBD_CONNECT_TIMEOUT=5
# students don't want to learn vim
export EDITOR=gedit
# some helpful defaults
export SKIP_CDS_DIALOG=t
export CDS_LOG_PATH='.'
# export our PATHs
pathmunge () {
    if ! echo $PATH | /bin/egrep -q "(^|$1($|" ; then
    PATH=$PATH1
    fi
#define binaries for Cadence
pathmunge $CDS/tools/bin
pathmunge $CDS/tools/dfII/bin
# EXT 13.2 with QRC must be exported before ASSURA
pathmunge $QRC_HOME/bin
# define binaries for Assura
pathmunge $ASSURAHOME/tools/bin
pathmunge $ASSURAHOME/tools/assura/bin
# define binaries for MMSIM72
pathmunge $MMSIM/tools/bin
pathmunge $MMSIM/bin
export PATH
#export LD_LIBRARY_PATH=\
#/lib:\
#/usr/lib:\
#$CDS/tools/lib:\
#$CDS/tools/dfII/verilogIn/lib
这里的pathmunge是干什么用的啊? 会不会和我的.bashrc冲突呢? (上面的路径都是对的)
请不要放弃我啊!
发表于 2014-9-26 13:09:12 | 显示全部楼层
回复 7# the_rebrith
   没有QRC 的set path添加上 export PATH=$QRC_HOME/binQRC_HOME/tools/bin{PATH}
或者你可以先source IBM的bashrc 然后source你自己的
qrc能用命令启动 那么virtuoso里面就应该有了
 楼主| 发表于 2014-9-27 01:14:05 | 显示全部楼层
回复 8# chipless
我有这句话的呀~ 在1楼贴的script里呢 难道你说的是加到我IBM的bash里面?
发表于 2014-9-27 22:28:36 | 显示全部楼层
顶贴拿积分
GMT+8, 2025-9-21 04:11 , Processed in 0.026203 second(s), 5 queries , Gzip On, Redis On.
