楼主: gsailor
cst2014不支持远程桌面?
发表于 2014-10-25 16:24:56 | 显示全部楼层
你有GPU么
发表于 2014-11-7 09:57:32 | 显示全部楼层
请问13版本你找到支持远程的方法了吗?
发表于 2014-11-7 09:58:23 | 显示全部楼层
回复 4# laonan007
   请教一下,应该如何修改?
发表于 2014-11-10 09:57:52 | 显示全部楼层
回复 13# markkcq
    那人就是个装,你没看过回帖没 没得用小家子气
发表于 2015-4-28 22:17:14 | 显示全部楼层
请问各位CST远程桌面的问题解决了么
发表于 2015-5-14 16:22:11 | 显示全部楼层
同问啊~有谁解决了CST 2014远程桌面使用的问题呢
发表于 2015-5-14 16:22:59 | 显示全部楼层
回复 16# xiaomujita
The difference between node-locked and floating license
There are two basic types of license types: nodelocked and floating. These license types define whether one or more users may use the specific software application at a time.
Nodelocked License
A node-locked license is an encrypted "key" that is locked to a specific machine or dongle. The license is uncounted, meaning that there can be an unlimited number of simultaneous runs (by any one user) on the single machine.
Floating License
A network floating license allows a user to use a license from any machine that can access the identified license server. An encrypted "key" is locked to a license server host that runs the FLEX license server daemon. The license is "counted," meaning that the FLEX license manager keeps track of the number of "seats" hosted by that server.
发表于 2015-5-14 16:26:48 | 显示全部楼层
回复 15# aauan1047 Nodelocked vs. Floating License Usage
Nodelocked License Usage
When an application is NODELOCKED, it can run only on the machine that the application is installed on. Nodelocked applications are most appropriate for:
  • Non-networked system environments
  • Users who require constant software availability
When a FLOATING license is loaded onto a network server, it can be made available to anyone on the same network. The number of concurrent users is limited by the licensing software to a negotiable predetermined number of users. Floating license applications are most appropriate for:
  • Customers who want to make the application available to as many people as possible without buying the application for everyone
  • Infrequently used applications where the amount of time spent using an application is usually short and irregular
发表于 2015-5-14 18:30:37 | 显示全部楼层
咋个修改license啊 尝试了N多 都不可以
发表于 2015-5-22 21:18:14 | 显示全部楼层
fdsafas
GMT+8, 2025-12-25 07:02 , Processed in 0.023070 second(s), 5 queries , Gzip On, Redis On.
